Old 05-31-2016, 10:50 AM   #155
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
Originally Posted by jarnojvv View Post
If you don not blind oncoming traffic with something in the boot and the lights on their highest setting the baseline level of the lights are set too high.
I don't drive with anything in my trunk so my baseline is fine.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
Old 10-16-2016, 07:07 AM   #156
JD001
JD001's Avatar
Drives: Subaru BRZ
Now that the 2017 Twin is out and about, does it carry any useless or redundant features?
I think the little gap between the rear spoiler and boot/trunk lid could be one..
Old 10-16-2016, 08:35 AM   #157
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
the little gap makes it a wing, not a spoiler. Definitely not useless as the aerodynamic effects are very different. Spoilers cut aerodynamic lift generated by the body, wings generate their own negative lift to fight the lift generated by the body.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
JD001 (10-16-2016)
Old 10-16-2016, 08:40 AM   #158
JD001
JD001's Avatar
Drives: Subaru BRZ
The old spoiler is a hybrid as it has sections that act as a wing and sections that spoil the air.. notice any difference from the spoiler/wingless variety of the twin?
The Following User Says Thank You to JD001 For This Useful Post:
Yoshoobaroo (10-16-2016)
Old 10-16-2016, 10:04 AM   #159
Guru Woodman
Guru Woodman's Avatar
Drives: 2015 BRZ Sport Tech CWP
Not sure it is has been mentioned before but the shift up indicator flashing (3 times no less) at ridiculously low rpm to increase fuel efficiency.
Guru Woodman is offline   Reply With Quote
The Following User Says Thank You to Guru Woodman For This Useful Post:
JD001 (10-16-2016)
Old 10-16-2016, 11:47 AM   #160
So turn it off. I turned it on just to play with it but the shift points were hilarious and it felt like I was play a game of MT Hero when I tried to hit them right on.
JD001 (10-16-2016)
Old 10-16-2016, 11:54 AM   #161
Guru Woodman
You can't turn off the shift-up indicator without also turning off the shift position indicator.
Tcoat (10-16-2016)
Old 10-16-2016, 12:01 PM   #162
AHHHHHH yes if you want the position indicator you are sort of stuck with it. I only left it on for a day or two before it bored me and I had had enough binky lights.
Old 10-17-2016, 01:59 PM   #163
iamjacob
insert witty quip here
Drives: 2016 Limited BRZ
I thought I remember seeing somewhere that the shift light was adjustable? Could you just set the shift light to a more appropriate RPM or set it to 7900 and be done with it?
iamjacob is offline   Reply With Quote
Old 10-17-2016, 02:02 PM   #164
gramicci101
Off Topic
The shift light is adjustable. I set mine for 7100. The upshift indicator and gear indicator are not adjustable, I don't think. I turned that off. I never shift as low as it wants me to, so it's just more flashing information that I don't need.
The Following User Says Thank You to gramicci101 For This Useful Post:
Tcoat (10-17-2016)
Old 10-17-2016, 02:41 PM   #165
bababooey
Drives: BRZ SWP Limited -6MT
That's interesting as I found the digital spot on as I have been through speed traps and the speeds up on the displays matched.
most of those speed display devices on the side of highway normally picks up other cars, ours is typically to low
bababooey is offline   Reply With Quote
The Following User Says Thank You to bababooey For This Useful Post:
JD001 (10-17-2016)
Old 10-17-2016, 02:47 PM   #166
We have major construction for about 50 miles of my commute right now and they have about 20 of those displays. Every one of them picks me up every single time. And I am lowered.
Old 10-17-2016, 03:38 PM   #167
bababooey
somehow misses me (ive got the unobtainium coating application ), they have construction between dallas/austin. i sometimes i crank it up about 10 mph over, if theres a gap in traffic in front of me. radar detector screaming all get out but it registers other cars around me.
could very well be the angle in relation to the ground.
Tcoat (10-17-2016)
Old 10-17-2016, 03:48 PM   #168
FX86
i've passed by one of those recently and it didn't show a number..it just said SLOW DOWN in all caps just like that after i got near it probably because it couldn't count that fast
Is sport mode useless? Limit Scion FR-S / Toyota 86 GT86 General Forum 63 05-22-2014 08:33 AM
Anyone else find 3rd gear redundant? NOHOME Scion FR-S / Toyota 86 GT86 General Forum 71 02-06-2014 01:22 AM
Useless FR-S exposure. FRSupra Scion FR-S / Toyota 86 GT86 General Forum 23 04-09-2013 06:58 PM
Search is useless Cajun Site Announcements / Questions / Issues 4 12-10-2012 04:59 PM
The Useless Web OnkelC Off-Topic Lounge [WARNING: NO POLITICS] 15 11-28-2012 04:51 PM
