Old 10-11-2016, 09:08 PM   #43
Amaya
Amaya's Avatar
Drives: 2015 Scion FR-S 6MT
Should have the engine out in the next couple weeks and another FA20 going in the car a few weeks after that. Pretty sure I know exactly what happened and how to prevent it from happening again. More details to come.
Sent from my SM-G900T using Tapatalk
Amaya is offline   Reply With Quote
Old 10-12-2016, 08:51 AM   #44
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
What hurts you makes you stronger. Hey slap some rods in the replacement. If you want to use factory pistons you need to shave the rod alittle, you want to balance the rods and pistons at the same time. Rods are cheap, new engines arent.
I have mixed feelings about low comp pistons out of boost.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 11-04-2016, 06:28 PM   #45
Amaya
Amaya's Avatar
Quick update: the FA20 I was going to buy didn't work out so looks like I'm going to put a V8 in it after all. But there's a twist, it won't be an LS engine.
Got the stock engine out
And the trans is out
Found a trans I think will work with the new engine
And then there's this. . . .
The Following User Says Thank You to Amaya For This Useful Post:
Kylebrz (11-04-2016)
Old 11-04-2016, 08:23 PM   #46
Ashikabi
Ashikabi's Avatar
Attachment 145493
Attachment 145494
Attachment 145496
Attachment 145495
Please tell me that's out of the RC350
Old 11-04-2016, 09:05 PM   #47
Amaya
Amaya's Avatar
Nope, it's not a V6. (It's also not a Toyota engine)
Old 11-04-2016, 11:06 PM   #48
Ashikabi
Ashikabi's Avatar
Thought the rc350 has a ~450hp v8
Old 11-04-2016, 11:24 PM   #49
Amaya
Amaya's Avatar
I believe that's the rc-f or something. The 350 has a 3.5L V6. And this engine only makes about 380hp on the stock E85 tune.
Old 11-04-2016, 11:59 PM   #50
Ashikabi
Ashikabi's Avatar
That would make sense(350z). I can't afford a Lexus so I never looked into it much lol. I just remember seeing 5L V8 making any 450hp and LOLing at the Americans shitty power to ratios
Old 11-05-2016, 11:01 PM   #51
Amaya
Amaya's Avatar
Started taking the engine apart a bit
Sosa (11-10-2016)
Old 11-10-2016, 03:23 PM   #52
Sosa
[||]--(86)--[||]
Sosa's Avatar
Drives: 2015 Firestorm FR-S
Thanks for the pictures! I love following projects like this as I'm no where near competent enough to open up an engine :-)
Do you know what causes the build up on the cylinder head? I wonder if it's a result of blow-by.
[||•]==(86)==[•||]
Sosa is offline   Reply With Quote
Old 11-10-2016, 03:45 PM   #53
Amaya
Amaya's Avatar
You mean on the top of the pistons? After the piston broke the cumbustion gasses pressurized the crankcase forcing a good bit of oil into the intake and through the engine. But there's hardly any build up.
Sosa (11-12-2016)
Old 11-12-2016, 12:38 AM   #54
Sosa
[||]--(86)--[||]
Sosa's Avatar
How embarrassing, lol. Yes, I meant piston. I'm still learning so there is a lot of info rattling around in my head causing a mix up from time-to-time... but I promise I know the difference between the two.
Thanks for the answer!
[||•]==(86)==[•||]
Old 02-07-2017, 02:51 PM   #55
nocoolname
Any updates on the LT1 swap?
2001 MR-S - long, slow, rebuild
2000 MR-S - 2zz swapped daily
2013 BRZ limited - new toy
nocoolname is offline   Reply With Quote
Old 07-17-2019, 10:22 AM   #56
Roth_nj
Drives: Brz ts
found this thread on the googles.....
i think an update is in order
Roth_nj is offline   Reply With Quote
WTB: SBD TURBO SETUP BRZ_HaVoKx Want-To-Buy Requests 5 04-08-2016 09:36 PM
Oil Catch Can for Turbo Setup tonytduc Forced Induction 15 03-23-2016 11:16 PM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring Engine, Exhaust, Bolt-Ons 8 10-30-2015 06:36 AM
So you think your JDM turbo setup is simple, huh? D K Forced Induction 6 07-27-2015 05:00 PM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring NY / NJ / CT / PA 0 10-20-2014 10:48 AM
