Old 10-09-2016, 05:38 AM   #155
notout86
Drives: GTS 86 auto
Originally Posted by shellslinger View Post
Sway bars. I can't get up my driveway without three wheeling it. Also, I don't track my car so it was pretty much a useless mod.
Does your car have the torsen diff. & if it does, do you get a sound like marbles rolling around when one rear wheel is up in the air?
A couple of times recently I heard marbles and now I wonder if a rear wheel up was the reason.
GTS86 Auto (Australia)
Old 10-09-2016, 01:00 PM   #156
shellslinger
Drives: Whiteout FRS
Yeah I guess you could say so. But it sounds like abs is kicking in or something.
shellslinger is offline   Reply With Quote
The Following User Says Thank You to shellslinger For This Useful Post:
notout86 (10-09-2016)
Old 10-10-2016, 12:41 PM   #157
kch
Senior Misanthrope
kch's Avatar
That's probably the ABS. A Torsen-type diff is great on the road, but fails completely when one wheel is up in the air.
The Following User Says Thank You to kch For This Useful Post:
notout86 (10-10-2016)
Old 10-10-2016, 10:50 PM   #158
jxl00
Drives: scion frs 2014
berk track pipe. also, honestly after all my mods I think the car was designed well as stock and any performance mods are a waste of money.
jxl00 is offline   Reply With Quote
The Following User Says Thank You to jxl00 For This Useful Post:
weederr33 (10-10-2016)
Old 10-10-2016, 11:10 PM   #159
Bowen
Powered by Crickets
Bowen's Avatar
Drives: 14' SWP MT Limited BRZ
Disagree, wider tires and UEL headers+tune are a game changer. Smoothing that torque curve out has made the car much more enjoyable.
Sent from my Nexus 6P using Tapatalk
Build Thread / OFT Stage 2, Tomei UEL, Perrin Resonated, ST Coils, 2 Sets of Wheels, Rally Armor, TOMS Tails.
Bowen is offline   Reply With Quote
The Following 3 Users Say Thank You to Bowen For This Useful Post:
PollosHermanos (10-11-2016), SlammedSilly (10-11-2016), Th3rdSun (10-11-2016)
Old 10-10-2016, 11:13 PM   #160
irod1021
irod1021's Avatar
Drives: 2013 Red FR-S
I was about to say the same
Sent from my SM-G935T using Tapatalk
irod1021 is offline   Reply With Quote
Old 10-11-2016, 10:23 AM   #161
PollosHermanos
PollosHermanos's Avatar
Drives: 2014 SWP BRZ Limited 6SP
Same here. World of difference.
[closes browser window full of coil over options]
1990 Laser RS - Lights go up, lights go down ||1992 MX-6 Coupe - Hah ... no || 2001 Integra GSR - Almost rice. Risotto || 2003 IS300 - A nice car but no fun. || 2011 Stage I GTI - Lots of fun. Would buy another
2014 BRZ - That BRZ. So hot right now.
PollosHermanos is offline   Reply With Quote
Old 10-11-2016, 11:11 AM   #162
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
Originally Posted by daiheadjai View Post
Not sure I'd agree. Throttle response felt much better with the lightweight pulley.
It was immediately noticeable after installing, and uninstalling (returning the car to stock) that shifts were smoother and rev-matching easier (throttle blips responded faster).
You won't get any power out of it - you just access what you have a bit sooner.
Plus the crank rotation is no longer dampened and will in the long run cause issues which is a really neato mod.
driftartist is offline   Reply With Quote
Old 10-11-2016, 11:42 AM   #163
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
This has been debunked for boxer engines. Wouldn't mess with the pulley if an inline though.
Sent from my SGH-I747M using Tapatalk
daiheadjai is offline   Reply With Quote
Old 10-11-2016, 01:31 PM   #164
driftartist
Kurenai Samurai
I understand why that would make sense, but thats not what rebello racing in the ca bay area says. and while a boxer engine has considerably less vibration and torsion, it is still possible to do damage over time. You are correct on the inline engines but it still applies to the boxer as well.
Old 10-11-2016, 01:40 PM   #165
Bowen
Powered by Crickets
Bowen's Avatar
Not hating on coils! I have a set of ST's myself :P
Old 10-11-2016, 02:36 PM   #166
daiheadjai
daiheadjai's Avatar
It seems to an issue that should be fairly easy to determine.
I haven't seen/read much about older Subarus grenading their engines (and lightweight pulleys have been around for a long time).
I had free time on my hands, so I took a look around (good research anyways, as I still have my crank pulley from my BRZ - in case I get another one down the road):
http://forums.nasioc.com/forums/show...5&postcount=13
I did more search trying to see for myself that the aftremarket lightened crank pulley really does damage to our boxer engines. I found nothing to prove that and instead i came across this post by Subaru Rep. He said...
According to the tech guys at SOA the boxer engine balances itself WITHOUT the aid of ANY form of dampener.
The pistons counter-balance the engine.
This is also helped by the fact that the crank uses 5 main bearings just like most other engines do except that our crank is about 1/2 the size of thiers so its able to withstand around 10 tons of preasure at any given point.
The main reason for a dampener is to help prevent crank walk and since the engine does not have to fight gravity in its running cycle there is no crank walk and hence no need for a dampening system.
I also found some posts by manufacturers (Vishnu, Unorthodox racing, etc...) discussing these lightened pulleys and they all back up what is said above. It was basically pointed out that stock crank pulley for Subaru is plainly just a crank pulley...not a Harmonic Balancer as also pointed out by SOA itself!
http://www.ft86club.com/forums/showp...94&postcount=9
Interesting info.
This comment from the above is also enlightening (pun intended?):
Scooby921 Thursday, September 03, 2015 5:13 PM
As a former design engineer for crankshaft dampers I just wanted to point out a couple important items.
The crankshaft damper has nothing to do with engine balance and vibrations. Motion and oscillation of the powertrain, as an assembly, is addressed by your engine mounts, transmission mounts, and potentially roll restrictors.
The purpose of a crankshaft damper is to reduce the angular twist / deflection of the crankshaft. Combustion creates pressure. Pressure becomes load into the connecting rod which creates torque on the crankshaft. That torque creates deflection of the shaft as it's not infinitely stiff. Depending on the material, journal offset, length of the shaft, and loads created in the cylinders you can see several degrees of angular deflection in the crankshaft. I've seen an OEM crankshaft which displayed 7° of deflection without a damper. With the damper it was under 2°.
The mass of the crank damper and the stiffness of the spring element (the rubber part) are vital to the effectiveness of the damper. They control the resonant frequency of the damper and impact the effective damping. If you change the mass or change the spring stiffness you change the frequency at which it operates. If you don't have enough mass, even at the correct frequency, you don't provide sufficient damping. An incorrectly tuned damper could actually make things worse.
Two seemingly-different conclusions from what appear to be credible sources.
I guess it's one of those "do it if you're comfortable" mods.
Old 10-11-2016, 03:52 PM   #167
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
Good thread...feels like confession...
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
The Following User Says Thank You to paiceyfan For This Useful Post:
Tcoat (10-11-2016)
Old 10-11-2016, 07:16 PM   #168
UFO
Drives: 2013 Scion FR-S, 2014 Audi S4
I installed a Bayson R front lip: like the fit and it looks good on the car. But, the only function it serves is that it prevents me from being able to slide my low profile jack under the car. I had to buy some low profile ramps so that I can slide my low profile jack under the lip .
If that's the worst thing I've done then I'm pretty happy!
UFO is offline   Reply With Quote
What is the worst looking FRS/BRZ ever? TRD-X Scion FR-S / Toyota 86 GT86 General Forum 438 02-03-2015 08:58 PM
Worst Comparison Ever... RockTown07 Scion FR-S / Toyota 86 GT86 General Forum 26 05-06-2014 02:31 PM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 02:36 PM
The worst looking wheels ever? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 10-08-2012 05:52 PM
Top 10 worst car deals, really? drifter BRZ First-Gen (2012+) — General Topics 20 08-23-2012 06:53 PM
