Drives: Raven FR-S 6MT
Help with loose wiring
Anyone know what these two orange wires are that got disconnected from this harness? The orange wires go to a little black box under the steering wheel. The photos are with the driver side panel taken off.
| The Following User Says Thank You to Terran For This Useful Post: | jcw99 (10-10-2016) |
#2 |
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
That does not look like factory wiring to me...
Note that the wires do not appear to go into a harness.
So, was this a used car? Did a dealer install an aftermarket alarm system to lower their insurance rates? What no longer functions on your car? |
#3 |
Drives: 2015 FR-S
In a Delorean, it's right beside between the front seats but in a FRS I think our Flux Capacitor is in the trunk. Could be the wiring for that. Have you tried going 88 pmh yet?
#4 |
No, everything is stock. The orange wires that you see got disconnected from the the yellow butt connectors, I pulled out that harness so that you could clearly see the orange wires that should be connected to the yellow but connectors. I tried to test and troubleshoot to see what doesn't work anymore, but I can't seem to pinpoint it
#5 |
#subaruambassador
Drives: Wheezy
It screams aftermarket or add on to me. I don't think I've ever seen a butt connector in a stock car (auto tech son agrees).
#6 |
The internet tells me that Toyota commonly uses orange wires for illumination circuits.
Do all your dash/interior lights work .. ?? humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Terran (10-10-2016) |
#7 |
Drives: 15FRS, 05MustangGT, 85Toyota truck
It is common for dealerships to add simple anti-theft devices to new cars in their stock.
If the customer opts to not pay for the device the service techs within the service dept. can disarm/disconnect the device. A little black box under the steering wheel certainly sounds like it could be such a device. Those connectors (small orange and yellow wires) are definitely not items the manufacturer would use in wiring/assembly of a new vehicle. Tapping into the large white with black tracer wire is also not factory. You have not stated what you think that 4-pin connector is for, and if it is plugged into the car's factory wiring ? Last edited by ToySub1946; 10-10-2016 at 12:00 AM. |
#8 | |
Drives: '11 Cayman , '14 Camry, '11 Tacoma
#9 |
Yes, what is that plug go to? There is a day white/black wire like that in the ignition. Those splice connectors and the 2 plug type ones are definitely not factory. Car manufacturers don't use connectors like that
| The Following User Says Thank You to Ashikabi For This Useful Post: | Terran (10-10-2016) |
#10 |
Yep, they all work.
| The Following User Says Thank You to Terran For This Useful Post: | humfrz (10-10-2016) |
#11 | |
#12 |
It goes to a female end connector on the circuit board in that area. Seems to make me think it is an aftermarket alarm from the dealer then. I opted out on the alarm when I bought the car, and I believe they did leave it in there. Thanks for your help.
#13 | |
I HATE these things... they are a total sham and wrong on so many levels: 1) They hack into the factory harnesses and reduce reliability 2) They are TERRIBLE alarms and are used for two fraudulent purposes:
#14 |
Drives: bmw x5
interesting thread, I too was having the same problem
| Gas pedal loose? | nyfries | Issues | Warranty | Recalls / TSB | 7 | 01-02-2017 05:22 PM |
| What to do with loose change | robwbright | Cosmetic Modification (Interior/Exterior/Lighting) | 35 | 04-10-2014 01:46 PM |
| Gas pedal loose | Enraged21 | Issues | Warranty | Recalls / TSB | 7 | 10-18-2013 02:18 PM |
| hood loose? | boricua FR-S | Issues | Warranty | Recalls / TSB | 3 | 09-10-2013 09:29 PM |
| Loose Glove Box | Spd229 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 12-06-2012 01:53 PM |
