Old 10-10-2016, 11:32 AM   #15
Amillionoh7
Amillionoh7's Avatar
Drives: 13' Raven FRS n 92 Camaro
most likely its just everything heat cycling. When we make ready a new car at work they always smell like they are on fire. But then again i work at a ford dealer. i bought my frs used so no sure what they smell like new
Amillionoh7 is offline   Reply With Quote
Old 10-10-2016, 01:19 PM   #16
Originally Posted by ThisGuyRett View Post
I had the dipstick gasket replaced when I first bought the car and had white smoke coming out of it. There is no visible oil leaks anywhere. I had it on a lift over the weekend changing the transmission and diff fluid.
As for the front brakes, there is no dragging from what I can see. I'll check next time I drive if the smell is stronger around the brake area.
Sent from my SM-N920V using Tapatalk
A dragging (stuck) brake pad will usually heat up the wheel ....... simply feel the hub of the wheel and compare left and right wheels .....
Old 10-10-2016, 01:46 PM   #17
Pat
Pat's Avatar
Drives: 2023 BRZ
You're pretty low. Are your tires rubbing on something? Maybe the fender liner?
Old 10-10-2016, 02:03 PM   #18
Well, now, it would seem to me, that if something is burning/smoking in the front half of your car and it smells like "plastic/rubber" burning ....... that something is making contact with your car's exhaust system.
So, I would suggest you get it up on a rack/ramps and carefully check all around all exhaust pieces, for something touching a part of that system.
OR, if it smells like "Lucas smoke", check the wiring carefully .......
Old 10-10-2016, 11:43 PM   #19
ThisGuyRett
This Guy
ThisGuyRett's Avatar
Drives: 2015 Halo FR-S M/T
I have Clearancs between the tire and fender. No rubbing whatsoever.
ThisGuyRett is offline   Reply With Quote
Old 10-10-2016, 11:44 PM   #20
ThisGuyRett
This Guy
Will do!
Old 10-11-2016, 07:53 PM   #21
ThisGuyRett
This Guy
Hey guys. I did an oil change yesterday. Today I drove and I didnt smell that smelly smell at all today. Checked the headers all the way back to axle back to see if there was any contact anywhere. Nothing. I hope the smell stays away. Im just wondering how did an oil change resolve the issue, or make it less noticeable.
Thanks for all the input. I'll be monitoring it for the next few days to see if the smell comes back. Ill keep yall posted.
Old 10-11-2016, 08:08 PM   #22
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
You must have teen children
guybo is offline   Reply With Quote
Old 10-11-2016, 09:24 PM   #23
I have eaten nothing but turkey for three days. I am now noticing an odd smell every once in a while. It is usually preceded by a weird vibrating sound.
Old 10-11-2016, 09:37 PM   #24
winstonscifi
winstonscifi's Avatar
Drives: 2015 Firestorm Red Scion FR-S
Location: Plymouth Minnesota - just west of Minneapolis
Did you do the oil change, or did the shop do it. Maybe they found a piece of plastic on the hot part of the engine and threw it out. When I brought my new FR-S home from the dealership, I opened the hood and found the red cover for the battery post off and stuck among the cables. They had jumped the car at some point, and it was just sitting there. I put it on the battery post. Now, if that had come loose and lodged itself on the engine, it could have melted....and caused some smells...I'd check the top of the engine - it is a boxer after all, so there is some horizontal space there that could attract some stuff that could heat up. Maybe I'm just paranoid...
winstonscifi is offline   Reply With Quote
Old 10-11-2016, 09:52 PM   #25
ThisGuyRett
This Guy
Lol
I did the oil change my self. I checked the top of the engine moments ago and rechecked my wiring for my fogs and nothing seems to be melted. You're not paranoid. I think I am the one whose paranoid. The car had 13xxx miles on it when i purchased and I keep thinking, " what if the owner beat the sh*t out of this car and messed up something internally and now its my problem?" <---- See? Paranoid. lol
Old 10-11-2016, 09:54 PM   #26
ThisGuyRett
This Guy
Me neither. I bought mine used too. Thats why i cant explain the smell.
Old 10-11-2016, 10:05 PM   #27
Post up a vid.
Old 10-11-2016, 10:12 PM   #28
ThisGuyRett
This Guy
Post up a vid.
A video of the smell? Lol
Nightmare driving FR-S vs driving Miata chrisngn FR-S / BRZ vs.... 64 07-06-2016 11:21 AM
Does anyone else occasionally smell a burning odor during cold weather driving? Meanderchap Scion FR-S / Toyota 86 GT86 General Forum 21 01-10-2016 02:10 AM
2015 BRZ: Strange smell after shifting and when driving in 1 gear for a while hosfordbrandon Issues | Warranty | Recalls / TSB 46 11-02-2015 02:42 AM
Anyone else notice a strange smell?? Bigedb Scion FR-S / Toyota 86 GT86 General Forum 13 07-19-2013 12:43 AM
strange smell - kerosine karlos13 AUSTRALIA 7 08-20-2012 12:50 AM
