Old 10-06-2016, 09:59 PM   #1
notout86
Drives: GTS 86 auto
clay bar vs duct tape
I had what I thought was a brilliant idea but I was wrong.
Clay bars certainly work to drag particles off the paint, leaving it smooth. However they do drag those trapped particles over the paint leaving shallow scratches so I would not use.
I thought that if I stuck on duct tape then pulled it straight off at 90 degrees to the paint, the particles would be pulled off.
Even though I smoothed the tape on the paint and it grabbed onto the paint very hard it failed. Can anyone explain this or suggest a better way?
By the way, someone suggested the best way to feel for lack of smoothness on your paint is to feel through a plastic bay and I can confirm that method is WAY better than with a bare hand.
GTS86 Auto (Australia)
Old 10-06-2016, 10:13 PM   #2
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
VIP BRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to VIP BRZ For This Useful Post:
DAEMANO (10-07-2016), go_a_way1 (10-06-2016)
Old 10-06-2016, 10:17 PM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Hahaha just use a claybar, thats why they are there. If your claying your car the next step would be a polish. (The number of stages depends on the paints condition but in your case you likely just need a swril remover) then after that you wax the car to help prevent future build up in the paint.
You don't wipe before you shit.... well in the case wipe at all. If your gonna do step one you have to follow through with everything else. Cant skip that stuff and say its done right.
Old 10-06-2016, 10:33 PM   #4
The clay bar works by removing an almost microscopic layer off your clear coat and therefore taking the particles with it. Tape is not going to remove anything and could actually leave residue behind.
I have never had any scratches left behind when clay baring.
My method:
Wash car with dish soap to remove most of the wax.
Rinse really REALLY well.
Dry car with a synthetic chamois so no water spots (residue from the water)appear.
Use a pile of detailing spray as lubricant and turn and fold the clay frequently.
86geek (10-07-2016), go_a_way1 (10-07-2016), humfrz (10-06-2016), wparsons (10-07-2016)
Old 10-06-2016, 11:47 PM   #5
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Wow, pass on what ever your smoking buddy. Sounds like good shit.
Ok, just to tickle your pickle, once you put duck tap on the car you also leave the adhesive behind. Thus allowing more dirt than what you remove,make it worse now with added glue.
Also your car is totaled go get a Honda.
The Following User Says Thank You to Mr.ac For This Useful Post:
Old 10-06-2016, 11:55 PM   #6
IMHO, a clay bar, used with the proper lubricant, will not leave shallow scratches visible to the naked eye or that can be sensed by the human touch.
Now, if you drop it on the floor or ground and continue to use you just might be asking for trouble.
As far as the duct tape ...... I wouldn't let that stuff get near the paint of a car ..... it just may pull off more than just a few particles.
As far as checking smoothness, I find if I set my spray can of glass cleaner on the hood ..... and it slides off .......that's plenty smooth.....
Old 10-07-2016, 12:16 AM   #7
Leonardo
Country Boy 4 Life
Leonardo's Avatar
It feels better through a bag... than bare you say.
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
go_a_way1 (10-07-2016), wparsons (10-07-2016)
Old 10-07-2016, 02:00 AM   #8
notout86
Drives: GTS 86 auto
No adhesive was left behind when I pulled the tape off nor could I even see or feel where it had been applied. Mind you, I did use a polymer wax/polish a week before and I did wash the area before applying the tape. I have driven around 30km since and the taped area has not collected any more dust than the rest.
Maybe, IF you use enough detailing spray with the clay it floats over it and leaves no scratches but sooner or later .....
Old 10-07-2016, 02:14 AM   #9
swarb
No adhesive was left behind when I pulled the tape off nor could I even see where it had been applied. I did wash the area beforehand.
Use more detailing spray?
Light polish after the clay to remove the minor scratches.
Go watch some videos and learn the correct procedures from professionals.
The Following 2 Users Say Thank You to swarb For This Useful Post:
Old 10-07-2016, 02:29 AM   #10
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
Better yet take it to a professional detail shop and let them do it.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
The Following 2 Users Say Thank You to 86geek For This Useful Post:
Old 10-07-2016, 06:27 AM   #11
No "sooner or later" about it. Do it right and there are no scratches.
Tape will leave adhesive behind that is how tape works.
Why apply a polymer wax and then a week later clay bar? All you are doing is clay baring the wax not the paint.
go_a_way1 (10-07-2016), humfrz (10-07-2016), soulreapersteve (10-07-2016), wparsons (10-07-2016)
Old 10-07-2016, 11:29 AM   #12
Hot-Lava_Dave
Hot-Lava_Dave's Avatar
Drives: 2016 Hot Lava MT
If professional detailers use a clay bar, I'm pretty sure that's the safest/superior method...
Hot-Lava_Dave is offline   Reply With Quote
The Following 2 Users Say Thank You to Hot-Lava_Dave For This Useful Post:
Tcoat (10-07-2016), wparsons (10-07-2016)
Old 10-07-2016, 11:36 AM   #13
No, no, no, that isn't how it works! The pros never know anything and there always must be some better, cheaper, easier way that the Illuminati have kept hidden from us.
D_Thissen (10-07-2016), Hawk77FT (11-16-2016), Hot-Lava_Dave (10-07-2016)
Best clay bar or recommendations AVodka14 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 30 06-02-2014 03:34 PM
Clay bar new car subiestyle Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 25 02-27-2014 10:31 PM
Clay Barred. (If you want, post yours, too.) AirborneDeth FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 08-31-2013 10:15 PM
Your clay bar of choice? bdanisi Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 13 05-09-2013 01:38 PM
Clay bar really works! 6-Shift Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 12-28-2012 09:37 AM
