Old 10-04-2016, 11:11 PM   #71
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by Speedy Nick View Post
My SRC acquired mind of its own, and decided to lower the front left ride-height by itself, after couple days of track day. The suspension expert told me that the lower bracket nut basically rotates by itself when you give full steering lock, to the point the lower bracket nut touches the spring sheet nut...
Did anyone receive inputs / solution from Tein so far?
Attachment 144041
Though not from Tein, I've between told to use a little blue loctite. I've also had the settings wander.
C
Old 10-04-2016, 11:51 PM   #72
Speedy Nick
Drives: Stock
C
my god.... i will try that, thanks
Speedy Nick is offline   Reply With Quote
Old 10-05-2016, 12:14 PM   #73
CSG Mike
CSG Mike's Avatar
Attachment 144041
Is this a CSG spec or std spec SRC?
I recommend you give West End a visit, and have them properly tighten everything up.
Old 10-05-2016, 12:46 PM   #74
Speedy Nick
Drives: Stock
It is a standard one, and West End foud this out when I recisited them for aligment adjustment... I'm looking for a proper solution on this...
Old 10-05-2016, 12:48 PM   #75
CSG Mike
CSG Mike's Avatar
They can do a 'best effort' fix for you. Most of the time it works.
Old 10-05-2016, 03:19 PM   #76
Speedy Nick
Drives: Stock
good to hear... not ideal but off to Big Willow to try it out!
The Following User Says Thank You to Speedy Nick For This Useful Post:
CSG Mike (10-05-2016)
Old 10-05-2016, 03:52 PM   #77
CSG Mike
CSG Mike's Avatar
You may want to back off your settings slightly for WSIR; the T8 bumps are pretty big at 120+.
Also make sure you pedal dance.
Old 10-05-2016, 07:02 PM   #78
kingkenny
Drives: 2014 Toyota GT86
I had the same issue ...Check the spring , see if it can rotate freely .if not , lower the perload setting , just have it enough to hold the spring while the spring can be rotate .
I guess if the spring is peload and lock too tight , it can break loose the lower collar .
kingkenny is offline   Reply With Quote
Old 10-06-2016, 08:04 PM   #79
Speedy Nick
Drives: Stock
I see... it is now pre-loaded to TEIN recommendation with their SPG... I will keep your comment in mind if it goes wrong again. Thanks.
Old 10-06-2016, 08:05 PM   #80
Speedy Nick
Drives: Stock
yeah...
Old 12-30-2018, 01:56 PM   #81
86_IT
86_IT's Avatar
I just installed my SRCs yesterday and have spent the morning testing the adjustments on a very bumpy very windy road and the amount of change each turn of the knobs makes is truly mind blowing. I'm incredibly impressed with the range of adjustability and can't wait to truly learn to fine tune the characteristics as I become more sensitive to the adjustments. I am nowhere near that point yet so I'll go off of the tested settings @CSG_mike has provided for now and learn as I adjust them at the track how each setting or combination of settings affect the characteristics of the car. Here's a shot of my rear suspension setup currently.
Instagram: 86_IT Twitter: 86_IT_BRZ Facebook: 86itbrz Youtube:86 IT
86_IT is offline   Reply With Quote
The Following 2 Users Say Thank You to 86_IT For This Useful Post:
juliog (03-22-2019), mistople (12-31-2018)
Old 01-02-2019, 06:35 PM   #82
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Depending on the version of SRCs you received, the settings will be different. CSG SRCs will have different settings from the USDM/JDM SRCs.
CounterSpace Garage is offline   Reply With Quote
Old 03-22-2019, 02:20 PM   #83
Jdmjunkie
Drives: Scion FR-S 10 Series
Getting my CSG Spec SRCs installed Tuesday, I cant't wait!
Jdmjunkie is offline   Reply With Quote
The Following 3 Users Say Thank You to Jdmjunkie For This Useful Post:
86_IT (03-26-2019), CounterSpace Garage (03-27-2019), juliog (03-22-2019)
Old 03-26-2019, 08:19 PM   #84
Jdmjunkie
Love these coilovers, drove home from the Racers Line with them on the canyon setting which was very stiff on bay area roads. When I got back home I put them to the comfort settings and drove around, I can't believe they are the same set of coils. Drives like it is on rails, I could not recommend these enough.
The Following 2 Users Say Thank You to Jdmjunkie For This Useful Post:
86_IT (03-26-2019), juliog (04-12-2019)
Tein H Tech installed pics and review JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 05-19-2013 12:22 PM
Enjuku Racing - Tein S-Tech Springs - ** ON THE SHELF ** Enjuku Racing Brakes, Suspension, Chassis 0 08-14-2012 05:06 PM
CUSCO|TEIN|KW|EIBACH|BC RACING & More! All your Suspension Needs @ Echelon Autosports Echelon Autosports Brakes, Suspension, Chassis 10 07-28-2012 01:27 PM
Subaru BRZ to compete in Super GT Racing Championship next year poormans_LFA BRZ First-Gen (2012+) — General Topics 18 11-21-2011 08:29 AM
