Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
Drives: 2013 Scion FR-S + 2011 Yamaha R6
Suspension Issues
- Fortune Auto 500 Coilovers using 8k Swift springs on radial bearings in the front. 20 clicks.
- Fortune Auto 500 Coilovers using 6k Swift springs in the rear. 17 clicks. - Whiteline 20mm adjustable front sway bar. - Whiteline 18mm adjustable rear sway bar. - Enkei RPF1 18x9.5 wheels. - Hankook Ventus V12 Evo 2 245/35/18 tires. The suspension was fairly dialed in on stock wheels. It still needed some work. I thought about getting stiffer springs. A shop installed RPF1 wheels + 245 tires recently. My suspension is now totally out of whack. ( T _ T ) All Aspects Motorsports will work on it soon. I was hoping to run a NASA HPDE1 this month. Any suggestions for further enhancements? :/ I will continue diving through the forums. |
#2 |
Shibby!
Drives: '14 White FR-S, '01 turbo mini taco
What exactly does "out of whack" mean?
The Following User Says Thank You to Toyarzee For This Useful Post: | G-Man (10-06-2016) |
#3 |
The Gunshine State
Drives: '14 BRZ Limited
I assume the wheels were balanced with the install? Maybe it needs an alignment.
![]() Current DD: M235i |
#4 |
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
"totally out of whack" is not a useful description of the problem. (If you want suggestions for how to get the susspension "in whack")
#5 |
Drives: Subaru BRZ
#6 | |
Sent from my Nexus 6P |
#7 |
The Gunshine State
What size offset are the wheels? Sounds like the ET is too low and you're having rubbing issues.
#8 |
LMGTFY
Drives: 13 FRS, 91 Miata
First things first.
Did you properly preload the coilovers? Did you corner balance yet? |
#9 |
Shibby!
Corner balance a bit excessive... At minimum a traditional alignment is likely necessary. Also, how low are you?
I'm betting alignment was possibly shit beforehand and it was accentuated with the increase in contact patch. When were coilovers installed, by whom, and was it aligned afterward? Don't worry this sounds minor and you can run your race if you get this squared away soon |
The Following User Says Thank You to Toyarzee For This Useful Post: | Shark_Bait88 (10-06-2016) |
#10 | |||||
I highly doubt this is causing issues. :/ Quote:
![]() Quote:
![]() Quote:
I am thinking about additional suspension upgrades before touching the gearbox or engine. Aaron from All Aspects Motorsports has basically told me there is no need for additional upgrades except maybe FI until I have plenty of hours under my belt. |
#11 |
Suggestion for good brake pads and brake fluid and track spec alignment.
#12 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
I find your spring rates odd? I have 7k front and 8k rear if I remember right. You want more spring in the rear IMO to help balance the car as you have to account for motion ratios.
#13 |
#14 | ||
The Following User Says Thank You to Fenix For This Useful Post: | go_a_way1 (10-06-2016) |
FS: Custom Bilstein suspension/coilovers | Kostamojen | Brakes, Suspension, Chassis | 11 | 11-21-2016 03:21 PM |
Suspension Super Sale ISC Suspension | KW | Tein | Cusco and More | OCRaceShop.com | Brakes, Suspension, Chassis | 14 | 08-26-2015 10:43 AM |
Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! | mothespaceman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 08-14-2015 05:06 PM |
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
Anybody with no issues? | tdoggy57 | Scion FR-S / Toyota 86 GT86 General Forum | 49 | 08-04-2012 03:41 PM |
