Old 10-03-2016, 01:20 AM   #29
Cartman
Drives: GT86
Originally Posted by Pat View Post
While type of usage has something to do with longevity, I would argue maintenance is significantly more important. I've had four cars over the last 15 years including the current BRZ. The previous three cars had more than 100 track days on them and a total of 575,000 miles. I don't drive like a grandma, but am meticulous about maintenance. People are always surprised how many miles my cars have on them after seeing and driving them.
How often did you replace the trans oil... I replaced mine every 10K miles until it broke (The amsoil fluid it had had 9K when the bearings let go)... now I'm replacing it every 2-3 events or 5K miles whichever comes first.
Cartman is online now   Reply With Quote
Old 10-03-2016, 02:48 AM   #30
hmmmm........what makes you think that your transmission "broke" because the oil had 9,000 miles on it ...... ??
Old 10-03-2016, 08:33 AM   #31
Pat
Pat's Avatar
Drives: 2023 BRZ
I think I replaced the trans oil about every 100,000 miles in previous cars. I never had a problem with them. In this car I replace the trans oil with Motul at a minimum annually. I also changed it after break in on the original transmission and the replacement transmission (replaced under warranty).
I really like the BRZ. It's a lot of fun and a screaming bargain for the level of performance. That said, it is a $25,000 car. In my book that's an economy car. It's not well made, and that goes for the transmission, too.
Old 10-03-2016, 12:41 PM   #32
Cartman
Drives: GT86
The guy I quoted saying maintenance is part of longevity... The real reason is this transmission sucks, uses little oil and easily overheats at the track.
Anyways, mine was replaced under warranty.
Old 10-03-2016, 01:03 PM   #33
hmmmmm.........how much power are you putting through your car's transmission ..... ??
Old 10-03-2016, 02:52 PM   #34
Cartman
Drives: GT86
I'm N/A, 175whp on the Mustang dyno I take it too... which is close to 190whp on a dynojet
Old 10-05-2016, 03:23 PM   #35
seant2h
Drives: 2013 BRZ 6MT LTD
I have 104,500 miles on a 2013 BRZ Limited
I changed the Spark plugs and all 4 brake pads at 100k (rear were ok but front were close which is why I changed them)
Throw out bearing at 88k and going into the shop for that again this Friday
Change accessory belt when trouble shooting the squeak which was the TOB
Fuel level sender sensor (P0462) needs to be replaced... waiting to do the fuel filter
Driver left seat bolster wear
Windshield & front bumper beat up from highway driving
I am on the second set of OEM tires
Regular oil changes
Manual Trans and Diff changed once
No other fluids have been changed
I have had a borla EL, JDL UEL and OFT and those are gone. I still have a catted nameless op/fp, q300 and K&N air filter. I'm running OEM tires on Legacy GT wheels and winter tires on OEM wheels.
All of that said, I still love my car and hope that I get to put another 100,000 miles on it but I hate the throw out bearing.
Last edited by seant2h; 10-06-2016 at 11:21 AM. Reason: added new accessory belt & fuel level sender
seant2h is offline   Reply With Quote
Old 10-05-2016, 05:04 PM   #36
Bowen
Powered by Crickets
Bowen's Avatar
Drives: 14' SWP MT Limited BRZ
Regular oil changes
That's impressive!
Haven't changed your engine coolant though?
Build Thread / OFT Stage 2, Tomei UEL, Perrin Resonated, ST Coils, 2 Sets of Wheels, Rally Armor, TOMS Tails.
Bowen is offline   Reply With Quote
Old 10-05-2016, 05:25 PM   #37
seant2h
Originally Posted by Bowen View Post
That's impressive!
Nope I haven't changed the coolant. The next on my list is to change the brake fluid. I'll probably do that when I put on the winter tires because I found my vacuum bleeder which was packed away when I moved into a new house
Oh, I forgot to add that I changed the accessory belt when I was troubleshooting the squeaking that turned out to be the TOB.
Old 10-05-2016, 05:30 PM   #38
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
That's impressive!
I used one of 'em suction/vacuum tools to change mine. Butt dyno says I got +5 more hp lmao
Old 10-05-2016, 05:38 PM   #39
Teseo
Drives: frs
I changed the Spark plugs and all 4 brake pads at 100k (rear were ok but front were close which is why I changed them)7
Regular oil changes
Why dumped headers and oft?
Old 10-05-2016, 10:30 PM   #40
seant2h
It was too loud and not worth it... All bark no bite. It's not that it wasn't faster with that setup but if I did it all over again I would probably just skip the header and strap on a barely used supercharger purchased on from a forum member.
Old 10-06-2016, 11:26 AM   #41
seant2h
I forgot something else which I've updated in my original post..
Fuel level sensor A (P0462) needs to be replaced... waiting to do the fuel filter
I get a CEL light for this code about 50% of the time that I get really low on gas... by really low I mean I can fit at least 11 gallons of fuel in the tank to fill it up.
Buddy Club Racing Spec Damper, Buddy Club Ball Joints, Megan Extended Tie Rods, etc Chase Bays Brakes, Suspension, Chassis 14 02-03-2016 09:14 PM
New to the FR-S Club Ensanety Scion FR-S / Toyota 86 GT86 General Forum 15 04-20-2015 10:03 AM
2000 honda civic si 33k miles on body 3k miles with turbo kit Anthony7515 Cars for Sale/Trade 3 07-28-2014 09:10 AM
sk frs brz club frs baby CANADA 0 05-26-2013 02:35 AM
