Old 10-05-2016, 12:53 PM   #1681
Nitro22
Nitro22's Avatar
Drives: Scion FR-S (Hot Lava)
Originally Posted by Luftwaffel View Post
Ah well, is what it is. I hesitate to call going with this kit a mistake. It's still the best put together FI kit I've seen in a while.
Some things I can recommend to anyone reading this for install or uninstall now or in the future:
- Use a different color fluid than blue in your supercharger. That way you know where to start looking when you have a leak.
- Put all hardware in plastic baggies and label them.
- Take note of what factory hoses went where, or you will be confused if you remove the supercharger.
- Dont get a fuel line popper. They suck and don't work anyway. Instead, shove a paper clip in each side of the quick correct to depress the internal tabs.
- When working with the fuel rails, connect the fuel crossover line (blue clips) to the rail first, then rotate the rail down onto the injectors. Trust me on this.
Sorry to hear the supercharger is'nt working out for ya. I've experienced the opposite with mine. No hesitation or idle problems. Throttle response and low-mid range torque is perfect for autocrossing. Delicious tune has a lot to do with this, however.
I agree most universal fuel line disconnect tools do not work well. The one I have from Company 23 is made for subaru's and works like a charm. More expensive than paper clips, but worth getting in my opinion.
Nitro22 is offline   Reply With Quote
The Following 2 Users Say Thank You to Nitro22 For This Useful Post:
funwheeldrive (10-05-2016), mitch t (10-06-2016)
Old 10-05-2016, 12:59 PM   #1682
taiguy
Drives: 2013 Black BRZ Limited
Originally Posted by Coltonscool View Post
Your problem is most likely your bypass valve. I had the same codes and idling issues and had the valve replaced under Edelbrock warranty and it fixed it no problem.
Below ive posted a video of my car that points to whether or not your valve is leaking.
https://www.facebook.com/nwiebmer/vi...4411980792329/
@taiguy
Going to pay attention to that area once I have some time to throw at the car again.
In case it is the bypass valve - how hard is it to swap it out?
taiguy is offline   Reply With Quote
Old 10-05-2016, 12:59 PM   #1683
taiguy
Will second this and say the Company 23 fuel line disconnect tool worked well for me too.
The Following User Says Thank You to taiguy For This Useful Post:
Nitro22 (10-05-2016)
Old 10-05-2016, 12:59 PM   #1684
Nitro22
Nitro22's Avatar
Bummer, sucks that you were having trouble with it. I've been taking note on your uninstall since I might be parting out my car, but for an entirely different reason. Love the car with it, but the family is growing and may have to move up to 4 doors.
Say it isn't so! If you need a car with 4 doors I would be under the philosophy of "in addition to" instead of "in lieu of". =)
The Following User Says Thank You to Nitro22 For This Useful Post:
Calum (10-05-2016)
Old 10-05-2016, 01:36 PM   #1685
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
Yeah these work too but the zip tie trick is just as fast and costs a few pennies. And I don't have to get it shipped.
I pulled a stupid last night. Finished the work and went to test start, but didn't put it 100% back together. I left the DI injector controller unbolted and the car wouldn't start and I couldn't figure out why for like 30 minutes. Then I realized it gets its ground from the bracket it's bolted to.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
Luftwaffel is offline   Reply With Quote
Old 10-05-2016, 02:10 PM   #1686
caschnd1
Drives: 2013 Subaru BRZ
All the kids in our house are grown and gone. It's still nice to have the 4 door option. So I drive a 2016 STi and my wife has the supercharged BRZ. Either one is fun to drive
-Craig
2013 Subaru BRZ - AT - Satin White Pearl - Edelbrock Supercharger
2016 Subaru WRX STi - World Rally Blue Pearl
caschnd1 is offline   Reply With Quote
The Following User Says Thank You to caschnd1 For This Useful Post:
Old 10-05-2016, 03:21 PM   #1687
Calum
That Guy
Drives: 2013 asphalt FRS MT
My family car is a 2 door Golf. My kids are only 5 and 7.
Old 10-05-2016, 04:38 PM   #1688
Nitro22
Nitro22's Avatar
-Craig
My other semi-daily driver is a Honda Fit and my wife has a BMW X1 so we're good to go. My daughter is only 3 but I keep a car seat in the back of the FR-S for when I need to pick her up from school. I only remove it when I go autocross.
Calum (10-05-2016)
Old 10-05-2016, 07:00 PM   #1689
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Ya, very sad but got my priorities straight... In an ideal world, that would be the case, I'd keep the BRZ for the weekends and have a DD car, but unfortunately, having 2 cars is just not in the cards right now. On the other hand, it will just have to be a fun sedan! I'll be checking out a local Focus RS that the original customer passed on the order this week.
I'm actually also shopping around for an STI since the RS markups have been ridiculous.
Ya, I also have a car seat in the rear passenger that works just fine with my 2 yo, but don't think having her behind me and a baby seat next to her is feasible.
Not to go too far off topic, I did flash to the latest CARB tune from Edelbrock and first impressions: I can't tell the difference lol. I think there is a hint of hesitation here and there, but I positive that is due to the pedal learning and will probably go away after I've driven it some more. Either way, I'll be keeping this in my back pocket when the time comes and switch back to the DT tune since I already have the D-box.
The Following 2 Users Say Thank You to BigFatFlip For This Useful Post:
Nitro22 (10-05-2016), TofuJoe (10-05-2016)
Old 10-05-2016, 08:44 PM   #1690
Calum
That Guy
Same here, I keep a seat on the passenger side for one kid. But there's no way in hell to get two in there. Not unless you're about 4 foot fuck all and sit with your lips on the steering wheel.
Good luck with the new car.
The Following User Says Thank You to Calum For This Useful Post:
BigFatFlip (10-06-2016)
Old 10-05-2016, 10:03 PM   #1691
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Update 10/5/16 - The hesitation between 3-4k rpm is definitely noticeable through all the gears now that I paid more attention. Looks like I'm experiencing something similar to what @switchlanez did with his EO tune. At cold start, I got some idle dipping low enough that it sounded like the engine was going to stall. It also happened a couple of times when warm, which surprised me. The EO tune 'feels' more responsive than the original tune, and I'd like it better if not for the hesitation during harder acceleration. Note that there was no hesitation with the original tune. I've shared this info with Edelbrock.
shiumai is offline   Reply With Quote
Old 10-06-2016, 12:57 PM   #1692
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Has anyone been experimenting with lowering the a/w intercooler temps or IATs with this kit? I'm consistently seeing IAT of about 35 Deg F above ambient as recorded by the ECU when at normal operating temps. Thought about setting up a misting system or moving my oil cooler, though I don't want to cutout my fog light area for the coolers. Not sure a misting system would actually help that much either.
B T is offline   Reply With Quote
Old 10-06-2016, 02:27 PM   #1693
shiumai
shiumai's Avatar
I'm seeing about the same IATs as you; typically 30 deg F over ambient (based on my vent gauge plugged into the OBD2 port). i was kicking around the nutty idea of 'what would happen if someone reroutes the passenger-side air conditioning vent into the air intake?' if you normally drive with the AC on.
Old 10-06-2016, 02:34 PM   #1694
Kodename47
Kodename47's Avatar
Drives: UK GT86
Using an ideal mix of distilled water and antifreeze might help. Cosworth recommend 25% ethylene glycol I believe.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
ajc209 (10-06-2016), BigFatFlip (10-06-2016)
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
