Old 10-04-2016, 11:49 AM   #1667
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Originally Posted by Luftwaffel View Post
Already all removed. I forgot to tilt the S/C to let it drain and got it all over my garage.
Can anyone provide specs on the crush washers that go on the HPFP low pressure fuel feed banjo bolt?
What's the deal with these posts Luft? Why you taking it off?
Old 10-04-2016, 12:23 PM   #1668
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
Don't care for the power delivery, throttle response seems sluggish no matter who I have tune it, so maybe this is a supercharger-ism, fuel trims range from negative fucked up to positive fucked up and bounce from one extreme to the other. Stalling constantly in the first few hours of an ECU reset.
Main reason? I miss the punch of a turbo.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
Luftwaffel is offline   Reply With Quote
The Following User Says Thank You to Luftwaffel For This Useful Post:
BigFatFlip (10-04-2016)
Old 10-04-2016, 12:44 PM   #1669
SuperDave
SuperDave's Avatar
Drives: DAT Rally Blue BRZ
How much are you selling it for?
SuperDave is offline   Reply With Quote
Old 10-04-2016, 12:55 PM   #1670
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Probably 4k but I need to get two minor parts warrantied through Edelbrock first.
Old 10-04-2016, 12:58 PM   #1671
Nitro22
Nitro22's Avatar
Drives: Scion FR-S (Hot Lava)
Wasn't sure if anyone posted this yet. Seems like a good time to buy if anyone's on the fence.
October 1 until December 31, 2016
Nitro22 is offline   Reply With Quote
The Following 4 Users Say Thank You to Nitro22 For This Useful Post:
Freude am Fahren (10-04-2016), menikmati (10-05-2016), SuperDave (10-04-2016), Uplink (10-05-2016)
Old 10-04-2016, 04:26 PM   #1672
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Stopped by CSG this morning to have the EO tune loaded onto my car (thanks @CSG Mike). I didn't notice anything different between this tune and the original one except that on the freeway, I did feel some slight hesitation between 3k and 4k in 4th gear doing a couple of pulls. I didn't notice it in the street in 1st and 2nd gear but it's still early to tell.
i haven't had any issues with my original tune; the only hesitation i felt was in the first half mile before the car had warmed up from a cold start, and it was very slight. I'll see how this EO tune works from a cold start.
shiumai is offline   Reply With Quote
Old 10-04-2016, 04:50 PM   #1673
Coltonscool
Drives: WSP FRS, S13 240sx
Originally Posted by taiguy View Post
Spoke with Topher over at Edelbrock and he said that there's a newer configuration file that's been released since mine came out (mine is from May 2016) and to try that out.
Your problem is most likely your bypass valve. I had the same codes and idling issues and had the valve replaced under Edelbrock warranty and it fixed it no problem.
Below ive posted a video of my car that points to whether or not your valve is leaking.
https://www.facebook.com/nwiebmer/vi...4411980792329/
@taiguy
Coltonscool is offline   Reply With Quote
The Following User Says Thank You to Coltonscool For This Useful Post:
taiguy (10-05-2016)
Old 10-04-2016, 05:19 PM   #1674
BigFatFlip
BigFatFlip's Avatar
Bummer, sucks that you were having trouble with it. I've been taking note on your uninstall since I might be parting out my car, but for an entirely different reason. Love the car with it, but the family is growing and may have to move up to 4 doors.
Old 10-04-2016, 05:57 PM   #1675
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Ah well, is what it is. I hesitate to call going with this kit a mistake. It's still the best put together FI kit I've seen in a while.
Some things I can recommend to anyone reading this for install or uninstall now or in the future:
- Use a different color fluid than blue in your supercharger. That way you know where to start looking when you have a leak.
- Put all hardware in plastic baggies and label them.
- Take note of what factory hoses went where, or you will be confused if you remove the supercharger.
- Dont get a fuel line popper. They suck and don't work anyway. Instead, shove a paper clip in each side of the quick correct to depress the internal tabs.
- When working with the fuel rails, connect the fuel crossover line (blue clips) to the rail first, then rotate the rail down onto the injectors. Trust me on this.
Old 10-04-2016, 10:45 PM   #1676
Freude am Fahren
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
Sweet! Glad I didn't jump on the $300 off earlier in the year! I think the time has come...
(though I'm still having serious thoughts about an M2... Grr)
-XXR 527 18x8.75 +35
-Nameless 2.5" OP/FP Combo (Coming soon) & Axleback
-SBD 500X (Waiting on coating to install)
-Southbend SBD500X Clutch
Freude am Fahren is offline   Reply With Quote
Old 10-05-2016, 01:52 AM   #1677
menikmati
Drives: 2015 BRZ, 2005 STI, 2024 Type R
*Sees rebate*
*Looks at bank account*
Shit, I have some work to do from now until the end of the year...
menikmati is offline   Reply With Quote
The Following User Says Thank You to menikmati For This Useful Post:
funwheeldrive (10-05-2016)
Old 10-05-2016, 11:02 AM   #1678
caschnd1
Drives: 2013 Subaru BRZ
Annoying when you already paid full price + shipping a couple months ago :-/
2013 Subaru BRZ - AT - Satin White Pearl - Edelbrock Supercharger
2016 Subaru WRX STi - World Rally Blue Pearl
caschnd1 is offline   Reply With Quote
Old 10-05-2016, 12:12 PM   #1679
CSG Mike
CSG Mike's Avatar
We're ready when you are!
Also, you can stack this with CSG's free D-box offer
Old 10-05-2016, 12:13 PM   #1680
CSG Mike
CSG Mike's Avatar
CSG has always shipped kits for free!
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
