#113 | |
Project Shadow
Drives: 2015 BRZ Limited 6MT
It's not necessarily weak, however with a twin plate clutch or heavy duty clutch and extra pressure on a stronger fork will wear or mushroom the pivot eventually. The stronger pivot just gives a little extra longevity. No one has complained about the stock pivot failing, this was created to give a little extra security due to other vehicle applications that had stronger forks installed also had their pivots fail like in a few Nissan vehicles. So really past experiences, and from what velox said, it wasn't that hard or expensive to create.
#114 |
Drives: BRZ, STI, GT350R, Supra, 987.2
So here's something interesting that happened to this clutch fork pivot, a local car at that!
![]() ![]() ![]() ![]() The last picture is what makes me question what broke what. Which part broke first (TOB or Pivot) to cause the fork to rub against the bell housing. I don't truly have an answer, my guess would be TOB started to fail, causing a bending moment to be placed on the pivot which caused the pivot to ultimately fail. That's just a guess though, car has over 120k miles on it. He drove the car like this for 20 or so miles to get it home one day, then to the shop the next. Thanks, Eric Last edited by VerusEric; 08-29-2017 at 05:06 PM. |
| The Following User Says Thank You to VerusEric For This Useful Post: | Drakiv (09-15-2016) |
#115 | |
Drives: '14 981CS, '99 NB1
| The Following User Says Thank You to johan For This Useful Post: | VerusEric (09-16-2016) |
#116 | |
Site Moderator
Drives: ichi 86 Project
| The Following User Says Thank You to ichitaka05 For This Useful Post: | Drakiv (09-15-2016) |
#117 |
Drives: RX-7 / BRZ
@VeloxEric, any idea when the next batch of forks will be ready? Back order status problems
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
#118 | ||
Thanks, Eric Last edited by VerusEric; 09-17-2016 at 12:53 AM. |
| The Following 3 Users Say Thank You to VerusEric For This Useful Post: |
#119 | |
Drives: 2014 Argento FRS
Happy to hear this, I made an order from ft86speed factory last week and eager to receive and install the fork Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to SoCalArgento For This Useful Post: | VerusEric (09-20-2016) |
#120 |
Drives: RHD Gt86
when will these be back in stock?
I check ft86speedfactory and it says back ordered
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission |
#121 | |
These come with a nice black oxide coating now. Pictures are below. This coating serves the same purpose as powder coat, corrosion resistance. Going this route reduces our lead time for a final product to keep it on the shelf more readily. ![]() ![]() Thanks, Eric Last edited by VerusEric; 08-29-2017 at 05:06 PM. |
| The Following 2 Users Say Thank You to VerusEric For This Useful Post: | Kris86 (09-21-2016), SoCalArgento (09-20-2016) |
#122 |
Drives: 2013 FR-S Whiteout MT
So if I'm on the freeway above 60mph and I down shift from 6 to 5, 5th will grind. Do you guys think this clutch fork will solve the issue?
When in doubt, throttle out!
#123 |
Drives: 2014 GT86
If all the other gear changes are fine, imho problem is not clutch related, but rather worn synchros of that gear.
#124 | |
Thanks, Eric |
#125 | |
Project Shadow
Maybe, maybe not. It's hard to say without knowing anything else. But I have been running it on a stock clutch and it has been nothing short of amazing in feel. I have a lot of other transmission work as well, but I can definitely tell the difference with this fork in the pedal feel.
#126 | |
| Verus Engineering Brake Cooling Kit | VerusEric | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 100 | 07-15-2023 10:18 PM |
| Modular Hood Louver Kit - Verus Engineering | VerusEric | Cosmetic Modification (Interior/Exterior/Lighting) | 276 | 07-08-2023 04:03 PM |
| Verus Engineering Rear Wing Development | VerusEric | Tracking / Autocross / HPDE / Drifting | 203 | 07-05-2021 09:15 AM |
| Verus Engineering Billet Transmission Beta Tester Run | VerusEric | Engine, Exhaust, Transmission | 62 | 04-26-2020 01:44 PM |
| ▀▄▀▄ Vivid Racing | Cusco 86/BRZ Clutch Release Fork and Pivot Set | vividracing | Transmission and Driveline | 0 | 07-12-2016 01:32 PM |
