| Software Tuning Discuss all software tuning topics. |
Drives: WRB BRZ
93 Octane tune at high altitudes
Hey all, I live in Wyoming, high altitude and cool for most of the year. The highest octane fuel available here is 91, and I was reading that it's primarily because the high altitude (5000+ ft) means that 93 isn't necessary. The lower density air makes for richer overall fuel mixtures, I suspect. Given this, would it be safe to run a tune meant for 93 octane on the available 91 octane fuel?
#2 | |
No real way to know unless you data log it. Since you don't have much choice, I'd say it is safe since the ecu has some correction in it. It might pull some timing if its not running well. |
#3 | |
Drives: FT86
The stock tune is meant to run best on 93 but will accomodate 91 fuel at slightly lower performance. If you have a performance aftermarket tune in the car meant for 93 then you need to run 93 or get your tune changed to a 91 compatable tune if you want to run 91 all the time |
#4 | |
Drives: Subaru BRZ Limited
With that said, I don't know nearly enough about custom tuning to advocate running a 93 tune at high altitude. |
#5 | |
Drives: FT86
#6 |
Drives: 86
the ECU is smart enough to lower ignition timing and keep the engine at safe points . takes off any knocks from it
| OFT 93 Octane tune... | Tromatic | Software Tuning | 29 | 05-21-2015 01:58 PM |
| OFT HIGH Octane Tunes? | OkieSnuffBox | Software Tuning | 5 | 05-13-2015 02:26 PM |
| Best tune for 93 octane? | smg1138 | Software Tuning | 13 | 02-15-2015 09:50 PM |
| high octane fuel + FI, tune not needed? | BRZPDX | Forced Induction | 6 | 09-30-2014 12:41 AM |
| If high octane is this good..... | F1fletch | Engine, Exhaust, Transmission | 8 | 06-12-2014 04:02 PM |
