Drives: 13 FR-S AT
I blended some 100 and 91 for a 93+ octane, man car never ran better. With a proper exhaust and header with tune I can't imagine wanting way more power. Thing gets up and moves with high octane
its no secret this car likes 93. But much pass this its kinda a waste unless your at a track day for the added knock prevention and maintaing IAM value of 1
Unless it's tuned specifically for high octane (higher than 93) you shouldn't expect to see much, if any improvement beyond 93/94. It's not surprising (if you're at sea level) using 93+ instead of typical 91 made a noticeable improvement. Are you in California? I've only ever heard Cali 91 is about as good as pisswater... Higher octane doesn't directly mean more power, just more thermal stability (resistance to knock). This means higher octane allows the engine to be tuned more aggressively before heat/knock become an issue again, which in turn means more power. The ECU is tuned to use pump gas, 93 being ideal because it's what is typically available. Higher octane means it's just easier for the ECU to stay in the happy range of it's knock compensation maps. The general idea is to use the lowest octane rating that your engine is happy with. Unfortunately, our little lumps only like the expensive stuff. |
We've extensively tested 100 octane and 91 octane setups on the dyno and on the track almost 2 years ago. What would you like to know?
Drives: 2014 SWP Limited BRZ
By what % is running 100 octane over 91 better? Hp/Tq etc.
The HP/TQ curve on the dyno on 100 octane is much smoother than the 91. We've seen gains between 2hp to as much as 6hp depending on conditions, cooldown, etc...too many factors. Let's just say average is about 3hp gain, but a much smoother and quieter operation.
![]() We recommend people to mix a few gallons of 100 octane with 91 octane on the track. It will not, however, fix any sort of DI seal failures. That has also been proven as well.
#7 | |
Drives: Diesel daily / FR-S
There is a 103 octane pump near me... and I could fill up a 5 gallon gas tank next time I go to the track. |
#8 | |
That's not a bad idea at all. Even if there's no additional power to be had, it's a nice safety net for a track day. |
#9 | ||
| Found a good place with good price for ceramic coating for headers | CamryDS | Northern California | 0 | 03-28-2014 05:03 PM |
| 100 octane race gas: 91 octane ratio? | GhostofAkina | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 02-08-2013 01:23 AM |
| 93 Octane | Smokinbuffalo | Northwest | 20 | 09-02-2012 05:24 PM |
| 93 Octane? | ashtray | BRZ First-Gen (2012+) — General Topics | 175 | 04-04-2012 12:22 PM |
