Old 09-15-2016, 07:17 PM   #29
ARTBRZ
Aloha!
ARTBRZ's Avatar
What's the bolt for?
I replaced the plastic clip that's holding the bumper to the fender. I was following some instruction on YouTube "how to fix bumper gap". He replaced the plastic clip with a u-nut and 10mm bolt. I thought it would be a cheap fix if it was true. FYI 10mm is too thick. 5/16 works.
ARTBRZ is offline   Reply With Quote
The Following User Says Thank You to ARTBRZ For This Useful Post:
Ashikabi (09-15-2016)
Old 09-15-2016, 08:58 PM   #30
FTemplar
Drives: BRZ Sport-tech 2013
Originally Posted by ARTBRZ View Post
The metal piece is glued to the bottom of the damaged clip. The clip will have a rough surface and a smooth surface. Put the glue on the rough surface, wait two min and apply on the clean area (broken clip). After that clamped it down with a binder clip for 15 min to let the glue harden and your good to go.
You can't really tell from this pic but the hole on the metal part will be thinner than the bumper clip but it will still fits.
I installed it on the 3rd of this month and I washed it 3 times with a pressure washer since install and its holding up.
If we look at the instructions included with the package you have to glue the metal piece to the bumper, not the clip , but if that worked for you then good for you
Sent from my MotoG3 using Tapatalk
FTemplar is offline   Reply With Quote
Old 09-15-2016, 09:16 PM   #31
ARTBRZ
Aloha!
ARTBRZ's Avatar
Haha. I called it differently. I actually followed the same instruction. The metal is glued on to bumper.
Old 10-01-2016, 10:20 PM   #32
6spd
6spd's Avatar
Drives: 2013 Raven FR-S
How long does it take to arrive from Japan to states?
6spd is offline   Reply With Quote
Old 10-01-2016, 11:18 PM   #33
FTemplar
About 2-3 weeks to Canada
The Following User Says Thank You to FTemplar For This Useful Post:
6spd (10-01-2016)
Old 10-10-2016, 08:32 PM   #34
6spd
6spd's Avatar
Ordered on 9/23, got it on 10/7 not bad!
Price is $20 USD + $15~20 Shipping fee options
Old 10-10-2016, 08:34 PM   #35
FTemplar
Cool ! Make sure to let the adhesive dry several hours before putting the bumper back on
6spd (10-10-2016)
Old 10-10-2016, 08:45 PM   #36
tonytduc
tonytduc's Avatar
watching
tonytduc is offline   Reply With Quote
Old 10-10-2016, 09:02 PM   #37
6spd
6spd's Avatar
Got them installed over the weekend, on its 3rd day now still holding up well, before I have to knee my bumper back in place almost everyday.
when I put bumper back on, the tap gave me a positive audible lock-in sound, it just felt solid and tight! hope the gorilla epoxy glue I use lasts (finger crossed)
The Following User Says Thank You to 6spd For This Useful Post:
sobrz (02-11-2017)
Old 02-11-2017, 04:48 PM   #38
sobrz
sobrz's Avatar
Just got mine (took 2-3 weeks).
I was happy to discover they now come with a set of tiny nuts and bolts.
Also, came with no instructions :/
Do you think I should attach them to the top or bottom of the bumper cover?
A "before" photo attached, hopefully I'll have a much better looking "after" photo soon!
sobrz is offline   Reply With Quote
The Following 2 Users Say Thank You to sobrz For This Useful Post:
Gunman (02-20-2017), JeremyR (02-14-2017)
Old 02-11-2017, 09:26 PM   #39
Ashikabi
Ashikabi's Avatar
That's a good question. Maybe they will only fit one way? If you put them on the bottom then the nut or bolt head may make it too fat? Experiment and get back to us! I'll be putting mine on when it gets warm
Edit. OP appears to have put them on the bottom
Old 02-14-2017, 11:45 PM   #40
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
mine looks like that too.. let us know how it goes!
has anyone considered attaching these to all 6 of the bumper clips?
JeremyR is offline   Reply With Quote
Old 02-15-2017, 12:14 AM   #41
cjd
cjd's Avatar
Drives: 2017 BRZ
You'd want them on the bottom. Nuts also on the bottom, screw's counter sunk into the plastic. That will lift the bumper up snug.
The Following 4 Users Say Thank You to cjd For This Useful Post:
brandonblt2 (10-02-2018), sobrz (02-18-2017), Trueweltall (04-09-2018), TruRace (03-26-2017)
Old 02-15-2017, 12:56 AM   #42
Ashikabi
Ashikabi's Avatar
Doesn't seem to be necessary
The Following User Says Thank You to Ashikabi For This Useful Post:
JeremyR (02-15-2017)
bumper sag repair, anyone tried this yet? nickmerronesucks Cosmetic Modification (Interior/Exterior/Lighting) 23 07-28-2016 11:14 PM
Bumper repair keneyy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 10-19-2015 06:30 PM
WTB: headlamps, fender garnish/cover/vent, and bumper reinforcement mariolefty1 Exterior Parts (Aero, Lighting, Etc.) 0 05-06-2013 05:52 PM
Front Bumper repair grgonium Scion FR-S / Toyota 86 GT86 General Forum 7 01-15-2013 07:25 PM
Bumper Repair Thatruth2001 Northwest 1 09-12-2012 02:15 AM
