Old 09-30-2016, 10:54 AM   #127
mdm
not a twin owner
mdm's Avatar
Drives: 2016 Veloster Turbo DCT
Originally Posted by Slade View Post
Sorry guys, but are there any dashcams that record both front towards the road and inside the car at the same time?
I don't know specific models, but I recall Russian dashcam videos that showed both.
mdm is offline   Reply With Quote
Old 09-30-2016, 11:18 AM   #128
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Quite a few - you can start here:
http://www.thedashcamstore.com/buyer...uyers_guide_q1
Also search uber or rideshare dashcams.
shiumai is offline   Reply With Quote
Old 09-30-2016, 11:52 AM   #129
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
yeah get dash cam...even cheaper will do the job.
my parents' van was hit by some spanic guy with no license + no insurance. he ran RED LIGHT. not even single word of fault or blah blah non-sens from insurance since video shows everything
hope OP's getting better!!
Old 09-30-2016, 12:00 PM   #130
FX86
nope, not from one device..it usually will be a separate camera pointing to the rear
Old 09-30-2016, 12:01 PM   #131
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
https://dashboardcamerareviews.com/5...ams-2015-2016/
Current DD: M235i
8RZ is offline   Reply With Quote
Old 09-30-2016, 01:55 PM   #132
HunterGreene
Hail Magnet
HunterGreene's Avatar
To those of you who were wondering about heat vs. dash cams--I had mine mounted 24/7, uncovered parking at work, and the camera lasted about 2 years before the battery was shot and I now have started getting glitches where the camera will shut off in the middle of my drive. I am going to guess that heat is the primary culprit. Thanks to this thread, I just purchased a replacement.
My recommendation--if you are parking out side on a hot day (>70*F), stow your dash cam while you're parked, it will last longer.
It has priests in it?
Old 09-30-2016, 03:13 PM   #133
Racer-X
Drives: 2016 FR-S
I would recommend getting a dashcam with a capacitor instead of a battery. They are much more resistant to heat. Mine have lasted years without issue even when the temp is over 110f outside for a couple of weeks.
If you stow it, the one time you need it it won't be plugged in.
Racer-X is offline   Reply With Quote
The Following User Says Thank You to Racer-X For This Useful Post:
mdm (09-30-2016)
Old 09-30-2016, 05:40 PM   #134
HunterGreene
Hail Magnet
You are correct, capacitors are superior to batteries when it comes to dash cams, but as I recall make the price a bit too much for my liking. Maybe next dash cam I get will have a capacitor.
I only stow it when I am parked. Any time the car is turned on, my dash cam is mounted. Its become habit at this point.
Old 09-30-2016, 05:56 PM   #135
Racer-X
Drives: 2016 FR-S
An A119 on Amazon is $90.
HunterGreene (09-30-2016)
Old 10-08-2016, 10:50 AM   #136
WWFT86
Drives: 2017 BRZ Limited
Thanks for the advice. Got mine installed yesterday.
Be well.
WWFT86 is offline   Reply With Quote
Old 10-08-2016, 03:30 PM   #137
HI
HI's Avatar
Drives: 2013 FR-S Ultramarine
Sorry about the car! Glad you're alright! Mines currently in the shop for 8k worth of damage, work truck sideswiped my whole drivers side as it was parked in my parking lot. This is the third time someone's his my car while it was parked. Twins curse!
HI is offline   Reply With Quote
Old 10-10-2016, 01:59 AM   #138
Kaotic Lazagna
Drives: GR Corolla
Thinkware F50. Pretty decent for being 100 bucks shipped. Came with a 8GB micro SD card that I used until my SanDisk card came in the mail.
Day quality using the SanDisk card.
[ame="https://www.youtube.com/watch?v=GIp8hbTNW-Q"]Thinkware F50 Day Quality SanDisk - YouTube[/ame]
Night quality using the SanDisk card.
[ame="https://www.youtube.com/watch?v=tWM_lG1M7PM"]Thinkware F50 Night Quality SanDisk - YouTube[/ame]
It records in one minute intervals. Has a parking mode (if you hardwire it in). Records "events" using a g-force meter. I had to set that sensitivity to the lowest since it was thinking every pot hole was an incident (I'm lowered on Tein Flex Z coilovers). It does record sound, but for the upload, I removed the audio. It does pick up conversations as well as the music playing in the car pretty well.
It also uses a capacitor instead of a battery, so it should fare better in the heat. I'm satisfied with it in the mean time until I find a dash cam that meets all my requirements (which isn't realistic, lol).
The Following 2 Users Say Thank You to Kaotic Lazagna For This Useful Post:
86geek (01-28-2017), MJones_RB (02-20-2017)
Old 10-10-2016, 03:20 AM   #139
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Originally Posted by geezerbrzeezer View Post
I found a schematic that shows the airbag module, and was surprised to see that it does extend down into the A pillar by several inches - it's not limited to just the headliner over the side window.
Which means my power wire on the driver side, and the wire going to the rear camera on the pass side, cross the side curtain airbags.
This poses a dilemma:
As the BRZ is my wife's daily driver, do I reroute the wiring for her safety, or do I increase the life insurance?
And, as I am generally a lazy person, does anyone know of a good dating website for widowers?
My 2 cents... The airbags are deployed via explosives. If you just tucked the wiring in there, and not affixed using the clips + 3m tape, then there is no way loose wiring is going to stop that airbag from fulfilling its purpose.
aegisdrgn is offline   Reply With Quote
The Following User Says Thank You to aegisdrgn For This Useful Post:
geezerbrzeezer (10-10-2016)
Old 10-10-2016, 08:52 AM   #140
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I did some "spririted driving" things and brought my dashcam inside to d/l the video. It worked fine. Then the next day (I hadn't put the cam back in my car yet) I tried to hook my cam up to my computer again to get another clip and it would not start up. I tried with 3 different known good power sources, ,y webcam just up and died.
It's a Cobra CDR820 I got from a work rewards program and they always seem to give us shit products. I am getting a replacement from Cobra for free (GG Cobra) but I have read about this happening a lot to people now that the dashcam has been out for a while.
I should have it Wednesday, not having a dashcam has kind of sucked for the past couple weeks.
guybo is offline   Reply With Quote
Totaled or Nah? Bones36 BRZ First-Gen (2012+) — General Topics 24 08-27-2015 09:13 AM
Think it's totaled? Nickd123 Scion FR-S / Toyota 86 GT86 General Forum 19 01-09-2015 06:34 PM
Is it totaled? If not, will it be the same? mynameisnick4 Scion FR-S / Toyota 86 GT86 General Forum 34 12-06-2014 12:05 PM
Totaled out. Luftmeister Member's Car Journals 12 05-19-2014 04:13 AM
My FRS Totaled.... FRS is down... jgonx213 Southern California 70 03-11-2014 01:42 PM
