#449 | |
Kouki-Monster
I am not worried about this.. it's normal. The problem is with the lack of support from HKS USA, again. HKS USA told me that the restrictor does not alter boost at all and that I needed to buy a new pulley.
Rich Anderson
EMPOWER AUTO |
#450 | |
Drives: Toyota GT86
And stop to quote me each time for saying "HKS is not selling map" as if I said they was selling it. Read again what you posted first. I never said that. I tryed to stop your troll but you quote me again. stop ! ok ? bye !
Koj
S/C HKSv2, HKS R Spec Manifold, Fujitsubo Authorize R Type S Catback, and more... My Journal/Garage |
#451 |
Drives: 2013 Scion FR-S in White
You have problems
#452 |
Drives: Toyota GT86
No I haven't .. and you ?
Koj
| The Following User Says Thank You to Koj For This Useful Post: | HuntingtonFRS (09-29-2016) |
#453 |
Drives: 2025 BRZ, ex-2012 GT86
At last! Reports of failed HKSes from other regions! Here in Russia, where already 7 SCs failed with the exact same symptoms, we also tend to think that traction fluid is the reason which enchances the constructive weakness (to say polite) of the unit in cold weather conditions. The "cold climate" fluid seems to be a must if you have <0C winters, in that case the units might last longer than 4-12 thousand km which seems to be the average life of these blowers here. Just one of the owners managed to get the replacement unit from HKS free of charge. Others, including me, had to buy new blowers or get rid of the kit/car.
#454 |
Drives: Toyota GT86
Efferalgan
![]() I m so sad for those who had to buy a new Kit. ![]() Mine was under warranty but 11 month old, near the limit... I guess yours was already over the warranty day limit. I had that problem with my Fujitsubo Manifold .. it died at 13 months and wasn't taken in warranty. Is there a thread about the HKS S/C problem where we can define all symptoms and maybe solution, do stats over the world, etc.. ?
Koj
| The Following User Says Thank You to Koj For This Useful Post: | Efferalgan (09-30-2016) |
#455 | |
![]() I've been positing photos of the failed unitis earlier in this thread serial numbers etc. But it got little/no interest from the community. I can make a separate thread with photos of all the failed units, maybe then HKS would tell the truth to the world ![]() Lukily, myself and couple of other folks managed to get the so-called rehaul kit which includes the blower, the filter, the fluid + some other spare parts and costs about $1800. So, at least did not need to buy an entire kit anew. 2 guys have done exactly that though - bought the entire kit twice. The replacemed units are holding-up so far. But recently a 15-series (which is the year of manufacture we believe) failed too. Which destroyed our hopes that the new 2015 units are somehow revised or something. Almost like Lana Del Rey sings: they all born to die
#456 |
Drives: HKS
I still wonder what it is causing problems only in Russia, and now France. We've sold hundreds of these kits in the U.S. and haven't had any warranty issues on the supercharger itself that I recall.
#457 | |
Plus, the V2 with the 90mm pulley has never been officially sold in the US as I understand. So as the V1 with 100mm. The V2 rotation speed is much higher than the one for V3 with the stock 110mm pulley => V3 faces less load, less wear. I guess that if you'd sell 100 v2 units with "normal" traction fluid in Alaska and check the statistics a year later (after 5 months of winter), it would be similar to the one we have here
| The Following User Says Thank You to Efferalgan For This Useful Post: | Trap63 (08-07-2017) |
#458 | |
Weight Weenie
Drives: 15 FR-S
There could be another reason here. |
#459 | |
Drives: HKS
But maybe there is something to the oil used and pulley size that is a reason the NA market is not seeing these problems. |
| The Following User Says Thank You to Torry@HKSUSA For This Useful Post: | new2subaru (09-30-2016) |
#460 | |
But the fact that HKS makes two types of this fluid tells that the temperature factor matters. Higher rotation speed of the V2 is also very important I belive. At 7500 rpm the V2 is already slightly beyond the stated max rotation speed of the unit. So, V2 is "overclocked" from the factory. |
#461 |
Sarcastic SOB
I use the thicker traction oil since I do not winter drive my car, and highly suggest people in cold climates use the thinner stuff.
Also, wondering if any of the failures were the result of using non-HKS traction fluid. When I start my car on a cool day (say, under 22C, 74F), the supercharger makes a bit of a squealing sound that disappears within 2-3 minutes of driving. It was like that from the very first day I installed the unit and attribute it to the traction oil being cold and possibly too viscous. Never complained about it but maybe better to just use the thinner oil, which I certainly am not willing to fork out another $265 US ($400 CD) for.
| The Following User Says Thank You to wbradley For This Useful Post: | Efferalgan (09-30-2016) |
#462 | |
| Kraftwerks Supercharger Owners Thread | projek_01 | Forced Induction | 4310 | 04-07-2025 01:12 PM |
| P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 02:31 AM |
| Five Axis Edition FR-S Owners Thread | digital_assassin | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 563 | 07-08-2015 09:22 PM |
| **Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 12:58 PM |
| Supra Owners Build Thread | BoostJunkie | Other Vehicles & General Automotive Discussions | 164 | 03-12-2012 09:37 AM |
