Old 09-28-2016, 10:38 AM   #15
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
When I installed my Borla exhaust, the center resonator was just a couple mm from making contact with the tunnel. I ended up having to loosen and shift the last stock part before theBorla parts (over-pipe I think) to gain enough clearance. I am almost sure it would have vibrated otherwise.
*and there was nothing in the instructions or online video's I watched that mentioned needing to touch that part at all.*
I was almost ready to go Bubba on the spot until I found all that slack available to adjust upstream.
Twinz is offline   Reply With Quote
OFT stg 2 UEL 91 vs 93 - noticeable difference? alanhung85 Software Tuning 2 10-22-2014 09:48 AM
DIY: Installing Pioneer AVIC Z150BH Aftermarket Head Unit tiz22 DIY (Do-It-Yourself) Guides 35 07-24-2014 07:03 PM
How do you keep cruise control after installing a aftermarket hub and steering wheel? Timtamtt Cosmetic Modification (Interior/Exterior/Lighting) 1 11-30-2013 07:17 AM
BEWARE when installing aftermarket tail lights, you must seal the area ! Kayzer Soze Cosmetic Modification (Interior/Exterior/Lighting) 5 08-27-2013 01:52 PM
Installing TRD Parts / Locating a good shop Re~Mix Engine, Exhaust, Transmission 9 06-12-2012 12:05 PM
