Old 08-26-2016, 06:16 AM   #113
Seba
Drives: BRZ Cosworth SC MY16
My favorite YT channel. Thinking about oem+ audio plus now. I will be replacing my fujitsu ten head unit with a navi system next week.
Seba is offline   Reply With Quote
Old 08-26-2016, 08:42 AM   #114
iggy
Drives: 2014 WRB BRZ Limited 6MT
Would this work with an aftermarket headunit?
I couldn't stand the lag of the stock touchscreen in my BRZ.
iggy is offline   Reply With Quote
Old 08-26-2016, 08:51 AM   #115
oemaudioplus
oemaudioplus's Avatar
Drives: http://bit.ly/Vantage86
Yes @iggy
Completely compatible with your factory or aftermarket head unit (both in terms of installation and sound reproduction). We tune each of our sound solutions specifically to the output characteristics of your current head unit, so you experience our signature sound reproduction the moment you plug your O+ system in.
Wanting to upgrade your system prior to changing out your head unit? Not a problem! We have several owners who change out their head units (a few times) over the course of owning the system. It just a matter of having their O+ Digital Signal Processor retuned to maintain our signature sound.
oemaudioplus is offline   Reply With Quote
Old 08-26-2016, 08:52 AM   #116
oemaudioplus
@iggy what aftermarket headunit are you considering?
Old 08-26-2016, 02:49 PM   #117
iggy
Good to hear! I already have a Kenwood Excelon DDX6902S.
Old 08-26-2016, 02:51 PM   #118
oemaudioplus
Perfect @iggy we have had extensive R&D time with that head unit.
Old 08-28-2016, 10:11 AM   #119
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
Originally Posted by Astral Abyss View Post
It's honestly no better than the 2-way, maybe a lititle worse.. I blame the stupid location of the mid and tweeter in our car. With more sound coming out of the door mid-bass on the 2 way, it avoided some of the nasty reflections off the glass that makes some of my music just sound wrong with the 3-way and I can't EQ it out.
The sound also changes when you have the visor up vs down... annoying.
After I got the upgrade I had one of those eureka moments where I thought, "so that's why they went with a 2-way in this car." And then, "too late now".
This is definitely not a knock on OEM. Their kit and support is top notch. Its just something to consider before anyone thinks more is better.
I have the "system" setup in my FRS and just installed the "reference" setup in my wife's FRS.
The door speakers in the "system" do more work than in the reference and it can pull the sound stage down and to the left with deep-voice vocals. (Chris Jones, long after you're gone)
With the reference setup, the dash speakers seem to handle a larger portion of the sound and bring the sound stage back up and do a better job of centering the (low-voice) image in front of me.
The speakers in the reference system also do a better job with delicate details that is hard to describe, but one of the more noticable instances is the harmonizing chorus in "on this train". On my sytem setup it sounds good, but on my wife's reference setup I can follow Zac Brown through the chourus. (I can pick his voice out more clearly)
Twinz is offline   Reply With Quote
Old 09-16-2016, 08:04 PM   #120
gothdaze86
Drives: Scion FRS
so I was one of the original owners of the system 450Q back in 2013 and it was pretty good using the stock radio.. I finally now decided to finally do the upgrade to the reference 450Q and I have to say I am blown away of the sound that the system is producing it is so clear I sat in my car for over an hour just listening to all types of music WOW if you are still on the fence don't be. the customer support that I received from Daniel was incredible WOW thank you so much for making music sound the way it should LOVE YOU GUYS>>>> Tommie from NJ>>
gothdaze86 is offline   Reply With Quote
Old 09-22-2016, 02:38 PM   #121
oemaudioplus
Old 09-23-2016, 03:51 PM   #122
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
Does your system work with Joying Android head units, and if I want to change head units later, how does that process go?
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
Luftwaffel is offline   Reply With Quote
Old 09-23-2016, 04:17 PM   #123
oemaudioplus
@Luftwaffel thanks for your questions. Yes! Our team has had extensive R&D time with the JOYING head unit and are just finalizing the EQ.
The Reference 450Q is completely compatible with the JOYING head unit both in terms of connectivity (completely plug and play with your factory connectors and applicable receiver adapter) and above all sound (our signature sound reproduction the moment plug you your system in).
If you decide to upgrade down the road, no problem. We'll just want to retune your O+ amplifier so your system maintains our signature sound reproduction with your new head units output characteristics. This is a service we offer gratis, we just ask you cover the cost of shipping if applicable.
Old 09-23-2016, 04:51 PM   #124
Luftwaffel
Boost Creep
Luftwaffel's Avatar
This is great, thanks. I use my head unit for engine monitoring but it's kind of slow due to RAM limits so I'm waiting on a system with more grunt, but it's taking a while for anything new to come out. So, the Joying system is not quite finalized yet, from what I gather?
Old 09-23-2016, 06:23 PM   #125
oemaudioplus
The JOYING EQ is ready when you are You'll just want to specify this radio selection ("Other") when personalizing your O+ sound solution - This allows our team to tune your system specifically for you.
Keep the questions coming.
Old 09-27-2016, 02:54 PM   #126
Racer-X
Drives: 2016 FR-S
What exactly is the "NEW 3-Way O+ Signature sound"? I've seen it mentioned repeatedly with no explanation of what it actually is.
Racer-X is offline   Reply With Quote
amp, audio, music, radio, subwoofer
Audio Equipment Part out! AVH-x4500bt, illusion audio, OEM amp, arc audio and more!!! CamryDS Audio/Visual, Electronics, Infotainment, NAV 25 10-23-2015 09:10 AM
Incriminator Audio 6.4, Sundown Audio SAX-100.4, US Amps Xterminator XT800.2 slicktop Miscellaneous 1 07-11-2014 08:58 AM
WTB: berk dual delete/perrin exhaust. JDL El headers. BBK kit. OEM Audio+/JL Audio YEAHdams Want-To-Buy Requests 0 07-01-2014 11:37 AM
FR-S Audio Build - SQ (Illusion Audio/Mosconi) DekaMori Electronics | Audio | NAV | Infotainment 28 04-17-2013 04:34 AM
'Noobish' questions as I look to upgrade my car audio audio. DkY in Vcr Electronics | Audio | NAV | Infotainment 0 09-22-2012 09:45 PM
