Old 09-27-2016, 11:24 AM   #1
boredjester
boredjester's Avatar
Noticeable vibration after installing aftermarket parts.
Hello all,
I changed my exhaust system this past weekend, now I'm running a skunk2 header with perrin overpipe and 2.5 catback exhaust. It sounds amazing, but now there is a noticeable vibration in the cabin. Is this to be expected when having aftermarket parts?
Sidenote, when the parts were all installed I checked for exhaust leaks and couldn't find any, but I have some doubts. I'm going to a tuner this weekend to get the most out of the new parts. Would it be too much to ask the tuner to check for exhaust leaks as well?
Thanks for the feedback.
boredjester is offline   Reply With Quote
Old 09-27-2016, 11:27 AM   #2
Originally Posted by boredjester View Post
Hello all,
I would ask them to check and doubt they will say no.
All the exhaust mounts in place and secure? A missing or improperly attached mount will let the system vibrate like a sonofabitch.
Old 09-27-2016, 11:35 AM   #3
jasonojordan
Drives: 2013 satin white brz limited
You could also be feeling a change in resonance as well. Everyone is more sensitive to different frequencies.
jasonojordan is offline   Reply With Quote
Old 09-27-2016, 11:40 AM   #4
Good call!
Old 09-27-2016, 11:45 AM   #5
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
I'm guessing the new exhaust system is much lighter than factory, therefore, causing an imbalance and that can add to the vibration.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 09-27-2016, 12:25 PM   #6
boredjester
I did have to remove the mount on the engine to allow space for the overpipe. I'll check that out again.
Old 09-27-2016, 12:26 PM   #7
boredjester
Wow, did not know that was a thing. Noted.
Old 09-27-2016, 12:28 PM   #8
boredjester
Hmm, overall the new parts were slightly lighter. Could anything be done to remedy an imbalance?
Old 09-27-2016, 12:31 PM   #9
8RZ
The Gunshine State
8RZ's Avatar
Stiffer urethane exhaust hangers (if anyone even makes any yet) instead of the flimsy stock rubber ones.
Current DD: M235i
Old 09-27-2016, 01:36 PM   #10
Hello all,
Hello @boredjester and welcome to the forum and modding your car.........
In addition to what has already been mentioned, I would ask the tuner (if they have a rack) to check for potential places where any part of the exhaust system could be vibrating against another part under the car.
Bubba says to find the exhaust part that is "almost" touching the frame and take a crowbar and bend it away from that part. Be advised that Bubba's main automotive tools are a crowbar, vice grips, bailing wire and duct tape.
The Following 3 Users Say Thank You to humfrz For This Useful Post:
DarkSunrise (09-27-2016), finch1750 (09-27-2016), Kwaziekeller (09-27-2016)
Old 09-27-2016, 01:43 PM   #11
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
^that Bubba guy has a point, and not just the one at the end of his crowbar
humfrz (09-27-2016)
Old 09-27-2016, 02:41 PM   #12
Kwaziekeller
Kwaziekeller's Avatar
Drives: '13 Argento MT FR-S
You forgot Bubba's favorite tool... a BFH! (Big F'ing hammer for those who are slow).
Kwaziekeller is offline   Reply With Quote
Old 09-27-2016, 02:51 PM   #13
Oh yes, thanks, I forgot about his BFH and his blow torch ......
Old 09-28-2016, 11:29 AM   #14
Dirtydan75
Dirtydan75's Avatar
Drives: Asphalt/Primer Turbo Widebody BRZ
Hello all,
I wouldn't think too much into it. I had the same issue on both BRZ's that I've owned and both times it ended up being the rattling of plastic panels within the cabin. The first time is was an issue with the rear deck and the second was with the passenger door panel. Putting some dynamat in any area where metal makes contact with plastic should solve this issue for you. I freaked out too and thought it was something mechanical, but it ended up being something as simple as a little panel rattle. Check it out, it won't hurt and it'll only cost you about $20 for the small patches of dynamat and a few minutes of your time
Sent from my SM-G900V using Tapatalk
Dirtydan75 is offline   Reply With Quote
OFT stg 2 UEL 91 vs 93 - noticeable difference? alanhung85 Software Tuning 2 10-22-2014 10:48 AM
DIY: Installing Pioneer AVIC Z150BH Aftermarket Head Unit tiz22 DIY (Do-It-Yourself) Guides 35 07-24-2014 08:03 PM
How do you keep cruise control after installing a aftermarket hub and steering wheel? Timtamtt Cosmetic Modification (Interior/Exterior/Lighting) 1 11-30-2013 08:17 AM
BEWARE when installing aftermarket tail lights, you must seal the area ! Kayzer Soze Cosmetic Modification (Interior/Exterior/Lighting) 5 08-27-2013 02:52 PM
Installing TRD Parts / Locating a good shop Re~Mix Engine, Exhaust, Transmission 9 06-12-2012 01:05 PM
