Old 09-24-2013, 09:27 PM   #43
forwallblakmail
Troll Level: Expert
forwallblakmail's Avatar
Drives: '13 BRZ, '18 F150 3.5EB, '07 Cayman
Nick Kelly/STX 30
Misery Bay Region SCCA (104)
Suspension -
Shocks: Off the shelf Racecomp Engineering Tarmac II's (replaced RCE Tarmac springs on Koni yellows) those are in the pictures
Springs: 400/400 (previous 280/290)
Camber plates: HVT
Rear camber: Stock bushings
Anti-roll bars: Racecomp Engineering 25mm front bar (soft)
End links: Stock
Upper strut bars: N/A
Bushings: Whiteline rear subframe inserts
Alignment & suspension settings -
Ride height: As the coilovers come
Rake: zero
Alignment: (Front)-3.1 camber/0 toe (Rear)-1.4/ 0 toe
Shock settings:close to the way they came
Weight:2645 last winter.
Tire pressures: 32
Engine & drivetrain -
Header: Stock
Over pipe: Stock
Front pipe/cat: Stock
Axle back: Nameless 5" mufflers
Intake: Perrin CAI (ordered)
ECU: Stock
Crank pulley: Stock
Motor mounts: Stock
LSD: Stock
Wheels/Tires, etc -
Wheels: Gold 17x8 Enkei RPF-1 45mm offset
Tires: 245 BFG Rivals
Wet tires: Same
Brakes: Carbotech XP12 F/R, DBA Club Spec T3 front rotors. Motul RBF 600 Fluid
Battery: Stock
Seats: stock
Nick K.
NASA ST5/TT5 #130
Southeast Region
forwallblakmail is offline   Reply With Quote
The Following 4 Users Say Thank You to forwallblakmail For This Useful Post:
feldy (09-24-2013), fstlane (09-24-2013), Racecomp Engineering (09-25-2013), Stevo22 (09-25-2013)
Old 01-12-2015, 07:07 PM   #44
vroom4
Anyone have thoughts on 245 vs 255 rs3?
vroom4 is offline   Reply With Quote
Old 01-12-2015, 07:10 PM   #45
vroom4
Looks like simmons went back to the 245 over the 255 with the z2...which I believe has a stiffer sidewall. Which goes towards the 245/40 17 argument with the rs3.
Old 01-13-2015, 11:23 AM   #46
conedodging
conedodging's Avatar
Drives: '14 BRZ
Most of the folks I know were on 245/40 RS3 last year. I'll likely start there.
(do we really need two STX threads?)
conedodging is offline   Reply With Quote
Old 03-09-2015, 06:17 AM   #47
Jetbill
Drives: 2013 FRS, 2014 BMW 335 M-Sport
Originally Posted by neurokinetik View Post
Has anybody attempted to make roll couple calculations yet? I'm considering trying it to get some idea of what the balance might be with different combinations of swaybars and springs. Since I already have that number available from my old Miata (using the old FatCat Excel sheet), it might give me a better idea of what direction I need to go with setting this car up.
I think all we need is the wheel rates for the various springs and swaybars, and we should be able to calculate the roll couple for our cars.
Didn't want to bump and old thread but searched and couldn't find anything...anyone know what the stock FRC% calculates too? I've done the calculation using FCM's calculator but seems arbitrarily low.
Jetbill is offline   Reply With Quote
Old 06-16-2015, 11:02 AM   #48
rx3
The KW v3 appears to be most popular choice regarding coilovers in STX.
Why aren't the KW clubsports applied? Does this have monetary reasons or are there technical reasons too (for example spring rates too high)?
rx3 is offline   Reply With Quote
Old 06-16-2015, 11:33 AM   #49
justint5387
Drives: 4 wheels
I think because v3 offers the best value relative to performance. Driven a friend's car on v3, i think the response is a little slower than monotube gas charged shocks.
justint5387 is offline   Reply With Quote
The Following User Says Thank You to justint5387 For This Useful Post:
rx3 (06-17-2015)
Old 12-14-2015, 02:10 PM   #50
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
any and all feedback is much appreciated...
Bryan Walsh
2013 FR-S 10 Series / #860 STX
New York Region
Suspension -
Shocks: KW v3
Springs: out-the-box KW v3 340/400
Camber plates: Vorschlag
Rear camber: SPC Lower Control Arms
Anti-roll bars: Perrin front / TRD rear
End links:Front: Perrin front links / stock rear links
Upper strut bars: Homemade 2-point (similar to Grimmspeed bar)
Bushings: Whiteline Rear Subframe Inserts
Ride height: 1" Drop from Stock
Rake: 10mm rake
Alignment: FRONT: -3.1 camber/7.3caster/.12 toe out ... REAR: -2.0camber/-.10 toe-in
Shock settings: FRONT- +3 compression, +5 rebound / REAR- +2 comptession, +4 rebound (from full soft)
Weight: Stock minus trunk junk
Tire pressures: 27.5-29psi hot
Header: OpenFlash Header
Over pipe: Stock
Cat-Back: TRD Cat-back (factory installed)
Intake: Grimmspeed
ECU: OpenFlash Tablet w/ off-the-shelf 93oct Stage2 OFH
Crank pulley: Perrin
Shifter: Stock
Shifter bushings: Perrin
Motor mounts: Stock
LSD: Stock
Dyno results: never dynoed
Wheels/Tires, etc -
Wheels: 17x9 +35 Varrstoen ES2
Tires: BFGoodrich RE-71R 245/40R17
Wet tires: Same.
Brakes: Front- Hawk Street Performance 5.0 // Rear- Stock
Battery: Stock
Seats: Stock
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
The Following User Says Thank You to Silver Ignition For This Useful Post:
smg1138 (12-14-2015)
Old 09-26-2016, 10:27 AM   #51
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
I noticed some of you guys are using a 5mm wheel spacer. Are you also using extended studs or can the stock studs handle that much spacer?
smg1138 is offline   Reply With Quote
Old 09-26-2016, 10:36 AM   #52
MarkR171
MarkR171's Avatar
Drives: '05 Elise
The max recommended on stock studs is 3mm (and I wouldn't even risk that for just 3mm.) I use ARP extended studs with a 10mm spacer in front and 5mm rear because I have 45mm offset wheels and stock size spring perch (C-Street, not STX car.)
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
MarkR171 is offline   Reply With Quote
The Following User Says Thank You to MarkR171 For This Useful Post:
smg1138 (09-26-2016)
Old 09-26-2016, 11:32 AM   #53
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I also run APR studs. My RPF1s are 45 offset so i run 15mm spacer in the front 10 in the rear.
Sent from my SM-G550T using Tapatalk
Old 09-26-2016, 12:55 PM   #54
renfield90
The Stig's German cousin
I'm confused? +45mm offset wheels with a 10mm spacer gives you +35mm total offset. Spacers subtract from offset, not add to it.
+35mm total offset is not legal in C Street.
Agreed that I would not run a spacer on stock studs. That's asking for trouble.
Old 09-26-2016, 01:07 PM   #55
MarkR171
MarkR171's Avatar
Drives: '05 Elise
You're correct. That's for my daily driver 17x9 et45 enkei rpf1s that didn't rub when I was on coilovers, but with -1.3ish negative camber and stock size dampers (koni w/ trd springs) they rub the spring perch.
I don't use a spacer when autocrossing on the stock 17x7 wheels.
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
Old 09-26-2016, 01:16 PM   #56
renfield90
Gotcha, thanks for clarifying.
Yeah, for anyone running stock sized springs and a 9" wheel, you're gonna need to get pretty far under the stock offset.
results Calum Site Announcements / Questions / Issues 2 02-15-2013 03:52 PM
Sharing my lights bgibbsunc Cosmetic Modification (Interior/Exterior/Lighting) 25 12-17-2012 02:07 AM
AT/MT Dyno Results with/without Mods blackfireball5 Engine, Exhaust, Transmission 0 07-04-2012 02:34 PM
