Old 09-22-2016, 06:19 PM   #715
dchan
Drives: DGM BRZ
Is there a way to make the OFT boot to the real time data display? I want to use it as a gauge, but don't want to have to navigate to that menu every time.
dchan is offline   Reply With Quote
Old 09-22-2016, 06:21 PM   #716
FLESH KILLA
Mr Cool Guy
FLESH KILLA's Avatar
Drives: 2013 Scion FR-S (Raven)
+1 would like to know this myself
Sent from my Nexus 6P using Tapatalk
- RAVEN 86 -
FLESH KILLA is offline   Reply With Quote
Old 09-22-2016, 08:12 PM   #717
vinhdt
If i get the OFT header then get the 350 turbo kit down the track, can i still use the OFT header??
vinhdt is offline   Reply With Quote
Old 09-22-2016, 08:24 PM   #718
phrosty
OFT350 has its own exhaust manifold.
phrosty is offline   Reply With Quote
Old 09-22-2016, 11:11 PM   #719
JW843
JW843's Avatar
Drives: 2013 BRZ Limited
Any reason why i still get errors "Update Template Files" when going to the diagnostics page on the tablet? Firmware Version has been updated to 140
JW843 is offline   Reply With Quote
Old 09-23-2016, 03:27 AM   #720
steve99
Drives: FT86
might need to plug in oft to pc again might need more updates or manually uplad template file see here
http://www.ft86club.com/forums/showp...79&postcount=2
unzip it and load via openflash manager
Old 09-23-2016, 08:23 AM   #721
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
You could just leave it plugged in with the ignition off while in the gauge screen and it will start up displaying the same screen upon restart of the ignition, but it will drain the battery.
Intent > Content
Old 09-23-2016, 04:51 PM   #722
JW843
JW843's Avatar
Manually updating template file was the answer. Found that out shortly after posting this question from one of your other posts. Thanks for the help!
Old 09-23-2016, 04:55 PM   #723
JW843
JW843's Avatar
Also, saw an older thread recommending MAF scaling with a Grimmspeed CAI, and some newer comments saying it would be fine without. Thoughts?
Old 09-23-2016, 07:23 PM   #724
SullyStyle
Drives: Hyperblue BRZ 2016
I just got my new OFT directly from the site and I can't marry it to the car. It says "Choose your car" and only gives me the option of a mazda mx5. Is there something that I just missed completely..?
I have a 2016 brz hyperblue. Never been flashed/tuned.
SullyStyle is offline   Reply With Quote
Old 09-23-2016, 09:58 PM   #725
steve99
Drives: FT86
of you dont get the option of toyota mazda and bmw
Sounds like the oft guys did nor set up the oft correctly, i think you can sort it by downloading the brz\86 openflash manager and connecting oft to pc running that software, oft will update and give you the 86\brz option
download from here
http://www.openflashtablet.com/downloads/
if still no go ring the openflash guys
Old 09-23-2016, 10:00 PM   #726
steve99
Drives: FT86
grimspeed cai is very close to stock maf scaling you should be fine.
many other cai are not and require maf scaling.
The Following 2 Users Say Thank You to steve99 For This Useful Post:
JW843 (09-24-2016), Teseo (09-23-2016)
Old 09-25-2016, 09:35 AM   #727
akyp
Drives: 2012 86
Been running OFT for close to 3 years and it has been good.
However, it has come to a point where it's next to impossible to do any kind of logging without the car throwing a CEL and U0073 code.
It could be any of these 3 things going bad: The OBDII port, the cable, or the OFT unit. I am hoping it's the cable.
So anyone have a similar experience and/or any suggestions? Is the cable a generic one that I can buy somewhere?
akyp is offline   Reply With Quote
Old 09-25-2016, 11:12 AM   #728
Teseo
Drives: frs
My bet its your obd port, early model have some problem with it
The Following User Says Thank You to Teseo For This Useful Post:
akyp (09-27-2016)
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 07:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 08:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 02:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 02:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
