| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 2013 subaru brz limited
Need help figuring something out
Soooooooooooooo for some reason my abs light and my traction control light come on after a bit of driving but not when i immediately start the car. it could be a speed sensor(on my guess) but could it be something else? the car doesnt drive any differently or anything but id rather not have lights on my dash. it also prevents me from using my cruise control or sport mode.
Thanks in advance everyone! |
#2 | |
Weight Weenie
Drives: 15 FR-S
| The Following User Says Thank You to new2subaru For This Useful Post: | go_a_way1 (09-22-2016) |
#3 |
| The Following User Says Thank You to Jrevans1992 For This Useful Post: | new2subaru (09-22-2016) |
#4 | |
Sarcastic SOB
Do you have a way to get an OBDII scan done?* Do you have a check engine light? (It appears not). *most likely will tell you the cause, maybe a sensor or something. And lastly, if you are within warranty, just take it to the dealer. You might have an issue with a sensor, possibly ABS/wheel speed sensor. I had issues with my tune not cancelling the check engine light for one cat removed. Also, had a dirty MAF sensor. When the CL light went on, so did the traction light (but not ABS) and also cruise would not operate.
#5 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Me too, but only when I go fast around corners
#6 |
Geezer
Drives: 2016 Subaru BRZ Sport Tech
I'm about to make what is going to seem, on the surface, the stupidest post of the day, and possibly of this forum's existence:
Check your brake fluid level. |
| The Following User Says Thank You to geezerbrzeezer For This Useful Post: | humfrz (09-22-2016) |
#7 |
Weight Weenie
Drives: 15 FR-S
#8 | |
![]() humfrz |
| The Following 3 Users Say Thank You to humfrz For This Useful Post: |
#9 |
Drives: 2016 Oceanic, "base" model
Staggered wheel/tire sizes?
#10 | |
As asked, any mods? Intake, header, anything?
#11 | |
Geezer
Rent a hanger. Disassemble your car completely - the scene should look like a Mayday NTSB crash investigation. Analyze the flight data and voice recorders for clues. Reassemble your car. Check brake fluid. |
#12 | |
i think it could be a speed sensor though since its delayed though. and no mods totally stock to those asking. |
#13 |
No CEL?
#14 |
| Need help figuring out if I can afford an FR-S. | BrianFRS | Scion FR-S / Toyota 86 GT86 General Forum | 57 | 03-31-2014 08:55 PM |
| Need help figuring our how to remove these pieces. !! | Cowbun | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 10-17-2012 05:44 PM |
