Old 09-21-2016, 08:35 PM   #407
lostpanda
Drives: FT86
Originally Posted by Tomita San View Post
Considering the V3 too. Where did you get the maps for OFT?
When the OFT is appeared.
I contact the saler at once.
but they said OFT can not support supercharger.
I donot know the condition now.
lostpanda is offline   Reply With Quote
Old 09-22-2016, 04:40 PM   #408
Koj
Koj's Avatar
Drives: Toyota GT86
Originally Posted by Scott@HKSUSA View Post
HKS doesn't have anything published specific to the FR-S s/c kits, but they do have this chart showing boost, hp, and tq with various restrictor diameters:
http://www.hks-power.co.jp/en/produc...estrictor.html
Flow increases with a square curve and can be interpolated by an area ratio so even without knowing an actual airflow value, we can calculate (R2xPi=area2):
43mm x .5 = 21.5mm x 21.5 x 3.14159 = 1452.19mm2
45mm x .5 = 22.5mm x 22.5 x 3.14159 = 1590.43mm2
1590.43/1452.19 = 1.095 (9.5% flow increase)
I just picked 45mm as an example to run through, but based on the % you want to increase, you should be able to calculate the restrictor area (diameter) you'll need from there.
And I guess I should qualify - increasing flow into the supercharger by 9.5% won't increase boost pressure by 9.5% because airflow across the intake valves is on its own square curve. But at least this will give you reference for what changes to expect.
Hi Scott
Based on your example, I tryed to see what we can wait about a new restrictor
Diameter mm......Surface mm˛......Ratio Vs Before.....Ratio Vs 39 mm
39......................1194,59
40......................1256,64............105,19%
41......................1320,25............105,06%
42......................1385,44............104,94%
43......................1452,20............104,82% ...............121,56%
44......................1520,53............104,71%
45......................1590,43............104,60% ...............133,14%
46......................1661,90............104,49%
47......................1734,94............104,40%
48......................1809,56............104,30% ...............151,48%
Without restrictor, what is the max diameter ?
Based on your example, a modification of the 39 mm restrictor to 43 mm will incrase the air flow by 21.5%.
Am I right ?
Koj
S/C HKSv2, HKS R Spec Manifold, Fujitsubo Authorize R Type S Catback, and more...
My Journal/Garage
Koj is offline   Reply With Quote
Old 09-22-2016, 08:46 PM   #409
makinen
makinen's Avatar
Drives: Toyota 86
DIY with some members.
makinen is offline   Reply With Quote
The Following User Says Thank You to makinen For This Useful Post:
Yobiwan (09-23-2016)
Old 09-23-2016, 08:18 AM   #410
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
Originally Posted by Koj View Post
Hi Scott
Am I right ?
ID of intake charge pipe in V2 kit is about 48mm
without restrictor , V2 can make 14~15PSI .
you can use 43mm restrictor with stock maf & stock port injector.
but above that, you should change many things.
2012 Toyota 86 6MT / 11:1 CR block by Outfront / SBD500x Turbo 17PSI@93gas /Avo 2.5 overpipe+Avo 2.5 catted frontpipe /MAP 3" CBE/ Tein Mono sport / STI brembo Front /OS技研 LSD/SSR GTX01 18x9.5
Yobiwan is offline   Reply With Quote
The Following User Says Thank You to Yobiwan For This Useful Post:
Koj (09-24-2016)
Old 09-23-2016, 11:33 PM   #411
HuntingtonFRS
Drives: 2013 Scion FR-S in White
Running V3 what's the best option to add power before needing to add injectors, fuel pump, e85?
Current mods:
HKS V3
Exhaust
Header
HKS spark plugs
Oil cooler
HuntingtonFRS is offline   Reply With Quote
Old 09-23-2016, 11:59 PM   #412
makinen
makinen's Avatar
Drives: Toyota 86
Current mods:
HKS V3
Exhaust
Header
HKS spark plugs
Oil cooler
I'm running with V3+100mm pulley+FD4.5+weight reductions.
If you are not able to calibrate ECU for 100mm pulley with petrol, only last two options.
Old 09-24-2016, 09:26 AM   #413
Koj
Koj's Avatar
Drives: Toyota GT86
Ok Thanks Yobiwan
I already changed the spark plugs (HKS M40HL) when I installed my HKS v2 compressor and the Omnipower 3 bar MAF.
Now I think to change :
- 750cc ecuteck injector
- 43 mm restrictor, so air flow surface +21%
- ECU reprog with the Ecutek Kit
- 235/40 back tires and 225/40 front tires
- new set rotor/pad/caliper
I will drive with "Super Sans Plomb 98" available here in Europe.
The 3 bar MAF (Omnipower) will work ?
Some advices ?
How many PSI I will have with the 43 mm restrictor ?
Diameter mm......Surface mm˛......Ratio Vs Before.....Ratio Vs 39 mm....PSI
39......................1194,59................... ............................................???
43......................1452,20............104,82% ...............121,56%...........???
45......................1590,43............104,60% ...............133,14%...........???
48......................1809,56............104,30% ...............151,48%...........14/15
Koj
My Journal/Garage
Old 09-24-2016, 10:10 AM   #414
Apex-Apex
Apex-Apex's Avatar
I have a V2 injector/restrictor plate for sale if anyones interested.
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
Old 09-24-2016, 10:36 AM   #415
Yobiwan
Yobiwan's Avatar
Ok Thanks Yobiwan
Some advices ?
HKS m40hl is same as ngk #8
You should use ngk #10 for FI (stock plug is NGk #9)
And that is hks m50hl.
@43mm restrictor , you can tune with your stock Port injector
Omni sensor is MAP sensor , yes 3 bar sensor will work.
Here is log of 43mm restrictor
You can see boost level.
http://www.datazap.me/u/yobiwan/hks-...9&zoom=440-567
Koj (09-24-2016)
Old 09-24-2016, 10:55 AM   #416
Koj
Koj's Avatar
Drives: Toyota GT86
Thanks a lot for your chart.
I see 10.xx to 12.xx boost (11.76), means 10-12 PSI ?
I will check with my tuner for the spark plug
I updated the table
Diameter mm......Surface mm˛......Ratio Vs Before.....Ratio Vs 39 mm......PSI
39......................1194,59............100,00% ..........................................???
43......................1452,20............104,82% ...............121,56%.............10/12
45......................1590,43............104,60% ...............133,14%...............???
48......................1809,56............104,30% ...............151,48%.............14/15
Koj
My Journal/Garage
Old 09-24-2016, 02:10 PM   #417
renesis808
Drives: 2014 BRZ Limited
i am planning on getting the v3 kit as well.
current engine mods are:
gruppe-s UEL headers and OP
stock mid pipe
Invidia N1 (catted)
mishimoto oil cooler
mishimoto radiator
mishimoto fans
mishimoto thermostat
perrin high flow drop in filter
OFT
planning on getting:
HKS v3 w/ ECU flash (yes, i know i will have to get rid of the OFT)
HKS spark plugs
radium dual catch cans
this is just for a daily driver/weekend car. are there any other supporting mods i should be looking into.
renesis808 is offline   Reply With Quote
Old 09-24-2016, 07:09 PM   #418
Koj
Koj's Avatar
Drives: Toyota GT86
stock mid pipe
Invidia N1 (catted)
mishimoto radiator
mishimoto fans
OFT
HKS spark plugs
You need to change your Air Flow Sensor (MAF) 1 Bar to 3 Bars. example: 3 bars Omnipower MAF.
Add tires, pad, rotor, caliper, and all things to avoid roll
If you don't puch too much your engine that's a good beginning.
Else over 300hp you will need to change more things.
And Tires will depend if you do :
- street & rendez vous
- track
- drift (on wet track, on dry track, etc..)
Koj
My Journal/Garage
Old 09-24-2016, 07:17 PM   #419
Yobiwan
Yobiwan's Avatar
- track
Omni 3 BAR sensor is MAP sensor, not MAF.
we can use stock MAF untill 300g/s .
Koj (09-25-2016)
Old 09-25-2016, 09:49 AM   #420
Koj
Koj's Avatar
Drives: Toyota GT86
Manifold Absolute Pressure ? (my fault)
http://omnipowerusa.com/store/#!/Sub...=0&sort=normal
Koj
My Journal/Garage
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 09:22 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 09:37 AM
