Old 09-20-2016, 12:08 PM   #29
pepe
Drives: gt86
if headers have thermal coating, reduce heat engine compartment? It would be less hot than headers original?
JDL headers can be installed preserving OEM overpipe?
pepe is offline   Reply With Quote
Old 09-20-2016, 12:56 PM   #30
kch
Senior Misanthrope
kch's Avatar
1) Maybe. Stock header has a heat shield. I don't know how thermal coating compares to those shields. But the thermal coating is definitely worth doing.
2) Yes, but because the pipes are a different diameter, you might get some strange noises--that is, it may sound even more like a diesel at low RPMs than it does now.
Old 09-20-2016, 01:08 PM   #31
pepe
Drives: gt86
overpipe change is best option ?
Old 09-20-2016, 01:27 PM   #32
Amputechture
Drives: 2014 BRZ
Keep in mind that header wrap will help muffle the sound a bit also.
Amputechture is offline   Reply With Quote
Old 09-20-2016, 01:30 PM   #33
pepe
Drives: gt86
What do you mean?
Old 09-20-2016, 03:00 PM   #34
CSG Mike
CSG Mike's Avatar
Not really; if anything it'll make it louder due to the higher exhaust gas energy.
Old 09-20-2016, 03:09 PM   #35
pepe
Drives: gt86
jdl uel sounds same a diesel????
Old 09-20-2016, 03:30 PM   #36
bfrank1972
Drives: 2013 FR-S Argento
Bare aftermarket headers tend to 'ring' a bit more, especially the thinner walled ones. Not much of a difference outside the car, but in cabin you hear a lot more noise from them without heat shields and sitting above that thin metal panel. Not sure if header wrap will do much, maybe dampen the resonance a bit, but overall the shield on the stock headers is one of the reasons stock headers are quieter *in cabin*.
Old 09-20-2016, 03:34 PM   #37
pepe
Drives: gt86
but not unbearably so, no? You can do many kilometers without going crazy?
not scare all the chickens, cats, dogs and grandmothers to happen?
Old 09-20-2016, 04:46 PM   #38
Lantana frs
Drives: 13 frs red
As I recall, my p&l header (catted) was no louder than stock. Everything in back of header was stock. I will get another header but leave everything else alone. I like quiet. Lol
Lantana frs is offline   Reply With Quote
Old 09-21-2016, 12:37 PM   #39
kch
Senior Misanthrope
kch's Avatar
The noise isn't specific to the header. The engine itself sounds diesel-like at low RPMs.
Old 09-21-2016, 01:20 PM   #40
CatDaddysBBQ
Drives: '13 FR-S
I have the topspeed catted header. It's marketed as UEL. It's TECHNICALLY unequal length, but by like 10%, not the drastically different length UELs that have the burble.
I'd classify it as EL, since it has more of a top-end power bump and sounds like an EL.
However, it still did wonders to fix the torque dip (with a OFT tune), and sounds great. It is louder than stock, for sure... But it's really quiet as far as headers go.
I have it paired with an axleback - so between the high-flow cat on the header and the factory mid-pipe/resonator it's got a GREAT growl under acceleration and has the occasional pop/burble under deceleration but idles and cruises at a near-stock volume. ZERO drone, as well. I honestly think it's perfect.
CatDaddysBBQ is offline   Reply With Quote
Old 09-21-2016, 01:30 PM   #41
pepe
Drives: gt86
I have the axleback topspeed, i am very Happy, sound perfect
Old 09-23-2016, 11:58 PM   #42
Amputechture
Drives: 2014 BRZ
Makes sense in that regard. Only first hand experience I have is going from unwrapped to having my downpipe, overpipe, and manifold wrapped. It definitely seemed to attenuate a lot of the unpleasantries although it could have just been from the pipes being new.
Greddy SP Elite + Borla UEL Headers = Very Quiet NoFear99 Engine, Exhaust, Transmission 52 06-01-2016 02:22 AM
WTT: N1 catback for something quiet Zixxerguy Engine, Exhaust, Bolt-Ons 21 05-21-2015 08:10 PM
Quiet FI Lord-Hydro Forced Induction 58 03-06-2015 08:34 PM
'Quiet' Header SpeedyJay Engine, Exhaust, Transmission 24 06-11-2014 05:46 PM
WA orders gone quiet? Bounce AUSTRALIA 8 12-05-2012 12:54 AM
