Old 09-14-2016, 12:33 PM   #113
rjgough95
rjgough95's Avatar
Drives: 13 Subaru BRZ, 02 7.3 F350 Diesel
Looking for a straight forward answer.
Who has had a shop flush and change there automatic transmission fluid and know what they paid? Someone who knows a good actually cost it would be to do it all?
I am being told it would cost 275$ - 325$ by someone at a dealership now.
2.5" Non-resonated Perrin catback - Hks dual resonator front pipe - Borla UEL headers - K&N drop in - Supertek intake pipe - Megans Racing strut bar - Racer X Fabrication cylinder brace - Valenti tail lights - Veloxs Motorsports front splitter - Galvez Customs rear diffuser - Open Flash Tuner - GCS paddles - Apex ARC8 Track Wheels
rjgough95 is offline   Reply With Quote
Old 09-14-2016, 12:44 PM   #114
phrosty
My dealership quoted about the same for a combined AT + diff oil change.
phrosty is offline   Reply With Quote
The Following User Says Thank You to phrosty For This Useful Post:
rjgough95 (09-14-2016)
Old 09-15-2016, 02:39 AM   #115
ysu
Drives: Toyota 86 GTS Auto
Australian dealership did the whole job for $260 AUD - not sure if this helps.
Toyota 86 GTS A/T, ACE 250/B header + OP, Apexi air filter, Whiteline camber bolts
ysu is offline   Reply With Quote
The Following User Says Thank You to ysu For This Useful Post:
rjgough95 (09-15-2016)
Old 09-17-2016, 03:46 PM   #116
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Changed it today with Redline D6 ATF (34k miles). Got to say, a bit of a pain in the ass doing on jack stands! Very noticeable difference in the way it shifts, upshifts at WOT feel less aggressive, more spongy if that make sense.
BirdTRD is offline   Reply With Quote
Old 09-18-2016, 06:46 PM   #117
Wayno
Wayno's Avatar
I caved in my oil pan with a rock so while I was getting is repaired I got a shop to do a flush using WS.
$225 AUD for flush/service incl new filter
$80 AUD for 8L of WS
They said the old fluid looked great. This is after doing around 15 25+min track sessions, with a $150 PWR ATF cooler. Never tracked without an ATF cooler.
Personally, I'd prefer to replenish some of the additives every 20k or so with a drain and fill rather than flush the whole lot at 80-100k.
I'm not sure why anyone would throw away take fluid that works perfectly, and replace it with fluid that's unknown. What issue are you trying to solve? What's worse is anyone who only drains the pan and replaces that fraction of the fluid with another brand, that's just asking for problems, especially on a platform that's 4 years old and has all this info already publicly available. The only problem is heat, and that's only solved with cooling.
Old 09-18-2016, 07:49 PM   #118
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
@Wayno - can you post a link or more info about the PWR AT cooler? Thanks!
TofuJoe is offline   Reply With Quote
Old 09-19-2016, 08:19 AM   #119
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Not really trying to solve any particular problem, just a preventative measure. Just supercharged the car at 32K miles on the clock and I'm hammering it a bit more now. (not tracking or autoxing, no aftermarket AT cooler) I'm sure the fluid had plenty of life left in it although it was brown in color. Maybe the "experts" can look at fluid and say whether is good or bad?? I'm sure color is just an indication of age. I haven't read anything negative about the Redline D6 ATF in our cars but if you know something, please share. Trust me, If I start having issues with the transmission now, I'll flush it again and put WS back in. This is how we learn.
When I said "spongy" upshifts in my previous post, maybe I should have used a different word like softer or smoother or less aggressive. Not saying it was harsh before, just it's noticeably different with this new fluid.
Old 09-19-2016, 03:36 PM   #120
SmireyFase
Drives: FR-S White - Smexy.
MY DD is currently sitting on 51.5k miles. haven't changed out trans / diff yet. I don't know whether to switch it or not...
SmireyFase is offline   Reply With Quote
Old 09-19-2016, 06:45 PM   #121
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
@BirdTRD that fluid still looks really good. I'm almost at 100k without a change yet. I'll post pics of my fluid when I get around to it soon
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 09-19-2016, 07:42 PM   #122
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Thanks! Yeah, I figured it was, did it more for peace of mind after adding the extra bump up front. I can fix just about anything that might fail on this car myself....except for the tranny.
Old 09-29-2016, 07:03 PM   #123
Xenith
Drives: Scion FR-S Raven
I just got a quote from my local Toyota dealership of $254.95 for ATF flush/replacement. A bit more than I was expecting it to cost... but I'll probably have it done next week.
Xenith is offline   Reply With Quote
The Following User Says Thank You to Xenith For This Useful Post:
rjgough95 (09-30-2016)
Old 10-04-2016, 06:55 PM   #124
Xenith
ATF flush ended up being cheaper than the estimate I got over the phone. The total was $172.32 at my local Toyota dealership.
Labor...97.75
Parts...62.80
Misc....7.84
Tax.....3.93
(miscellaneous charge was for hazardous waste disposal)
rjgough95 (10-05-2016)
Old 10-05-2016, 03:18 PM   #125
SmireyFase
Labor...97.75
Parts...62.80
Misc....7.84
Tax.....3.93
Ahh this puts my mind at ease. Think I can relay this and get the same price via my local toyota dealership? hahahahahaha
Old 01-03-2017, 04:06 PM   #126
carbonBLUE
Reverse Burnouts
Today is the day! I'll post a pic of my fluid color when I finish. My car just got new fluids in everything and I've been saving this hassle for the very end. I hope it goes well!
(wont forget you)
2011 Infiniti G37x
The Following User Says Thank You to carbonBLUE For This Useful Post:
BirdTRD (01-03-2017)
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 02:34 AM
Transmission fluid swap? flawedchemical Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 09-12-2014 02:23 PM
Mt transmission fluid swap bdanisi Engine, Exhaust, Transmission 8 02-08-2013 02:09 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
