Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 06-24-2012, 01:39 AM   #15
Toy86
Toy86's Avatar
Drives: 2013 VW Scirocco R
Originally Posted by Kenno View Post
OMFG THATS HAWT!
Toy86 is offline   Reply With Quote
Old 06-24-2012, 01:59 AM   #16
JDM-dono
JDM-dono's Avatar
Drives: WRB BRZ '13
JDM-dono is offline   Reply With Quote
Old 06-24-2012, 02:07 AM   #17
nix
nix's Avatar
Drives: AVO BRZ
What's the law in qld regarding flushness? That offset looks a few mm low for SA.
nix is offline   Reply With Quote
Old 06-24-2012, 02:17 AM   #18
Nardi330
Nardi330's Avatar
Drives: 86
Flushness looks ok but the issue might be too wide over stock. That's 2.5" wider....
Nardi330 is offline   Reply With Quote
Old 06-24-2012, 02:37 AM   #19
QIK86
Drives: Brabus E-Class - FT86(ordered)
if there is a decent dicount with a group buy count me in.
QIK86 is offline   Reply With Quote
Old 06-24-2012, 03:07 AM   #20
Kenno
Kenno's Avatar
Drives: Toyota 86 GTS 6M
Damn, you might be right regarding the width (please note this is for Queensland):
"The maximum tyre width for a car or car derivative must
not be more than 1.3 times the vehicle manufacturer’s
widest optional tyre.
However, for an off-road passenger vehicle fitted with
front and rear beam axles, the maximum tyre width
must not be more than 1.5 times the vehicle
manufacturer’s widest optional tyre.
The nominal width of the narrowest tyre fitted to a
vehicle must not be less than 70 per cent of the nominal
width of the largest tyre fitted and never less than the
vehicle manufacturer’s narrowest optional tyre as
indicated on the manufacturer’s tyre placard."
Just did some calculations, the GTS stock tyres are 215/45/R17. So 1.3 x 215 = 279.5 it should be ok then?
Kenno is offline   Reply With Quote
Old 06-24-2012, 03:36 AM   #21
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
FYI. TRD Wheels which are an option right right
18 inch Aluminum Wheel 'SF2' (Forged) *5 *6
(Size : 18x7.5J , 100-5H , Inset46)
*Reference Tire Size 225/40ZR18
*TRD Monoblock Brake Kit compatible
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 06-24-2012, 03:37 AM   #22
Nardi330
Nardi330's Avatar
Drives: 86
Cool. Only max tyre width? No max wheel width?
Is that's the case us QLDers are safe!!
Bring it on!!!!
How about group buy for coilovers?? Lol
Old 06-24-2012, 04:25 AM   #23
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
That's CR Kai and not CR Kiwami.
exactly the same design. different sizes and colour.
btw is the 86 5x120 PCD?
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
Old 06-24-2012, 04:43 AM   #24
Nardi330
Nardi330's Avatar
Drives: 86
Similar design but not exactly the same. Kiwami has deeper concave.
Cai is being phased out and they might not produce custom size.
PCD is 5x100
Old 06-24-2012, 05:25 AM   #25
sirus
86 Owner
sirus's Avatar
Drives: White GTS 86
Kiwami are lighter than Kai.
From JDMConcept web site:
WORK Wheels has introduced a new version of Emotion Cr Kai, EMOTION CR KIWAMI. This new wheel utilizes WORK Flowforming Technology.
The key benefit for flow forming is the ability to reduce the barrel thickness, thus reducing the weight of the wheel without compromising the strength of the rim barrel.
WORK flow forming wheels start with low-pressure cast construction, whereas some of our competitors use lower quality gravity casting.
Low-pressure cast construction has a denser material property over gravity cast wheels, thus allowing a greater strength advantage over gravity cast with flow-forming barrel.
Work 35th Anniversary special for the whole year of 2012.
Possible PCDs and offsets available:
15 X 5.0 - was $370, now $335 per wheel [4-100 +45]
15 X 6.5 - was $390, now $345 per wheel [4-100 +42, +52]
16 X 5.5 - was $400, now $355 per wheel [4-100 +45, +44]
16 X 6.5 - was $410, now $365 per wheel [4-100 +42, +52]
17 X 7.0 - was $490, now $430 per wheel [4-100, 4-114.3, 5-100, 5-114.3 / +38 +47 +53]
17 X 8.0 - was $510, now $450 per wheel [4-100, 4-114.3, 5-100, 5-114.3 / +35, +47]
17 X 9.0 - was $530, now $470 per wheel [5-100, 5-114.3 / +17, +28, +38]
18 X 7.5 - was $520, now $460 per wheel [4-100, 4-114.3, 5-100, 5-114.3 / +38 +47 +53]
18 X 8.5 - was $540, now $480 per wheel [5-100, 5-114.3 +30, +38, +47]
18 X 9.5 - was $560, now $500 per wheel [5-100, 5-114.3 +12, +20, +30, +38]
18 X 10.5 -was $580, now $520 per wheel [5-100, 5-114.3 +23]
Colour available:
Dark Bronze [AHG] - Standard
Matt black [MBL] - Standard
White [WHT] - Standard
Glim Silver [GTS] - Standard
Work Metal Bright [WMB] - $100 additional per wheel - Premium [1]
[1] Premium - more expensive than standard or custom colour
[2] Custom - same price as standard colour but takes longer to make
Included in the wheel set:
Valve stems [Black - default colour]
Center cap is not included by default from Work Japan
On the road. Check your mirrors!
sirus is offline   Reply With Quote
Old 06-24-2012, 07:13 AM   #26
Gir
Gir's Avatar
Drives: 86 GT Manual - Sonic Blue
I'm up for a group buy if the discount is good enough.
Gir is offline   Reply With Quote
Old 06-24-2012, 07:24 AM   #27
click_lenny
Good bye 86.....
click_lenny's Avatar
Drives: Evo X
Same here....i want the mat bronze color though.....
click_lenny is offline   Reply With Quote
Old 06-24-2012, 07:36 AM   #28
sirus
86 Owner
sirus's Avatar
Yeah me too I will probably look at 18x9.5+30/38 Matte Bronze. I'm going to need to give ol wifey a good excuse for this one!
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x9.5 +30 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 179 11-20-2015 12:12 AM
New Spec - WORK Emotion Kiwami 18x8.5 +38 / 18x9.5 +38 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 58 01-24-2013 12:51 PM
Work CR Kiwami/Ultimate danscar Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 09-11-2012 12:24 AM
WORK Emotion Kiwami - 18x8.5/9.5. Staggered For FRS/BRZ *** Available Now *** RavSpec Wheels and Tires 59 07-24-2012 12:07 PM
WORK Emotion Kiwami - 17x9.0 +38mm 5x100 *** BRZ/FRS Spec *** RavSpec Wheels and Tires 5 07-19-2012 06:44 PM
