#4159 |
Drives: FRS
Will bedding in track pads improve braking performance?
Specifically at high speed threshold braking I notice abs kicking in what seems like fairly easily and car starts to move around a bit. I'm guessing a big part of it is tires. I'm on michelin PSS and W5 pads. I'm thinking technique is a big part too. Any tips on how to brake from straights into chicanes etc. |
#4160 | |
The tire is the larger factor; that's not a very sticky tire for hard driving. |
#4161 | |
Drives: 2023 BRZ
#4162 | |
Dismember
Drives: 2013 Red Scion FR-S
#4163 |
Drives: 2013 STI
Using RS-3s for the track, which of course are directional.
If it is bone dry, is there any issue with running them on the wrong side? (as in left tire on the right side.....) thanks |
#4164 |
Dismember
The car will only drive in reverse.
#4165 | |
Drives: Velocity Orange 86 GT
Basically try braking a couple metres shorter, being smoother and getting excellent apex's and exits. Then try pushing it later and harder. That's just what I've found works well for me. |
#4166 |
#4167 | |
Drives: FRS
Thanks! Yes I've been running with pedal dance. I think I am being too harsh on initial brake application. Smoother application yet firm on the limit before abs is what I have to work on. Good to know about bumps too. Thanks for the tips on how to get faster!
#4168 |
Drives: 2015 AOZORA EDITION
does anyone have any recommended track settings for kw 3way clubsports
#4169 |
Drives: frs
Has anyone here played with rear trailing arm /traction arm lengths?
I'm currently trying to figure out how to put power down better on the frs. I would have to be very late and gentle on throttle on corner exits because the rear end tends to step out very easily. I have spc lower control arm spl toe arm, when set to the desired alignment settings both arms end up being longer than stock. I'm thinking that since both toe and lower control arms are longer does that inturn make the traction arm "shorter" and induces excessive toe in under compression, and causing lack of grip accelerating out My rear alignment is currently at - 3.0 camber and zero toe Front is - 3.5 with - 2.2 adjusted at the knuckle with camber bolts and the additional - 1.3 with hvt top hats, also at zero toe Any advice would be much appreciated |
#4170 | |
Drives: 2017 BRZ
C Last edited by cjd; 09-11-2016 at 11:10 PM. |
#4171 |
Drives: 2013 white limited BRZ
I have a track specific question, the track I go to is somewhat L shaped. At both ends of the L, there is a sharp low speed corner that then goes up a steep hill. I just can't climb the hill as well as most cars. What would be a good solution besides getting another car?
What I tried lately is to turn in late so I can take a straight line through the apex and then go up the hill. Seems to work better if I don't have to turn the wheels until later going up the hill. I am below 4k rpm in 3rd gear maybe going between 40 and 50 mph at the slowest and just don't have the torque at the low end to accelerate better. Going to 2nd does not seem to work since I feel I am losing time and also banging the transmission more than I like. In the flatter corners, I seem to running with most cars unless the drivers are really experienced. This if for PDE and not doing any racing. Any ideas would be appreciated. I have a JRSC and PSS tires. I am going to talk to my tuner and see if anything can be improved from that end if that could help. Thanks in advance. |
#4172 | |
Shibby!
Drives: '14 White FR-S, '01 turbo mini taco
I'm sure other track rats will chime in with more insight |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
