Southern California SoCal
Old 10-27-2015, 10:58 PM   #43
8R6
8R6's Avatar
Drives: FRS
Originally Posted by cycleboy View Post
Unless someone tried it for a test, I doubt it. We're exempt for 6 years, so the 2012's won't require it until 2019. I wonder if you get a fix it ticket for being too loud if they could force you to get a smog check early? Seems unlikely.
I thought about doing that type of mod since I wouldn't have to undo it for at least another 5 years or so. It'd suck after that to have to reset everything every other year though.
if the cop issues you a ref ticket for your car, then it dont even matter about smog test... you need to put the stock cat back on or the ref wont pass your inspection anyway. fuck the smog at that point, you wont be allowed to drive the car on the road or risk getting impounded lol
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
Phantobe (10-27-2015)
Old 10-27-2015, 11:18 PM   #44
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Aaaaand this is why I went back to stock haha.
I'm still wondering if a stock gutted header would pass the OBD2 scan. Trying to find more information about it, ready diagnostics or some crap.
I miss catless header sounds
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 10-27-2015, 11:25 PM   #45
ExxelDistributions
ExxelDistributions's Avatar
Drives: 2014 FR-S 6MT Monogram Series
Where are you located. It would take me 2 mins to check and see if its actually possible or not. PM me if you want to try it. We won't be actually testing the car just want to check and see what happens to the monitors after a tune
ExxelDistributions is offline   Reply With Quote
The Following 2 Users Say Thank You to ExxelDistributions For This Useful Post:
8R6 (10-28-2015), imaguitar (10-28-2015)
Old 10-28-2015, 11:37 AM   #46
Phantobe
Phantobe's Avatar
Anaheim - Orange County
I'll def. consider it.
Old 10-28-2015, 12:36 PM   #47
ExxelDistributions
let me know
Old 11-02-2015, 08:01 PM   #48
nova.86
Legendary Member
nova.86's Avatar
Drives: HyperBlue BRZ
I'm going to try and get a cutback exhaust with a front pipe, hopefully it won't be loud enough and pass smog in the future. Has anyone taken the new Works CARB legal turbo kit stage 2 to a smog shop yet? I'm thinking about grabbing that kit being it's the only turbo that's carb legal.
nova.86 is offline   Reply With Quote
Old 09-09-2016, 08:35 PM   #49
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
mmh soon maybe.. I have the stg 2 works carb compliant kit sitting in my room right now just waiting for an opportunity to install the thing
turtlefeeder is offline   Reply With Quote
Old 09-09-2016, 09:32 PM   #50
ronboogieon
BReeZy Hunter
ronboogieon's Avatar
Drives: 13 DGM BRZ Limited 6MT
Since the smog station only checked OBDII I was able to pass the BRZ with high flow cat. Everything in engine bay was put to stock tho so nothing visual to catch the tech's eye.
ronboogieon is offline   Reply With Quote
Old 09-10-2016, 12:11 AM   #51
Pekingduck
Drives: 4 wheels
As long as you have the proper documentation then it shouldn't be an issue. I pass a referee with my supercharger, but everything else was bone stock.
Pekingduck is offline   Reply With Quote
Old 09-15-2016, 02:02 AM   #52
nova.86
Legendary Member
nova.86's Avatar
Installing this, http://perrinperformance.com/i-13324...-fr-s-brz.html On Friday..Pretty sure I gotta return to stock for SMOG when it happens..that's gonna suck.
Old 09-20-2016, 08:56 AM   #53
Gabzor
Drives: Don't own one yet.. but work on em
Catchcan is illegal? I mean AN fittings are shiny and all, but what if you still have an OEM pcv system and stuff?
Gabzor is offline   Reply With Quote
Old 09-20-2016, 10:43 AM   #54
ExxelDistributions
Catch can would require a CARB label because you are modifying the PCV system which is a tamper meaning no CARB label then they can fail you on the visual unless you get lucky and tech doesn't know what that is.
Old 09-21-2016, 05:46 AM   #55
Gabzor
That sucks.. least its easy to disconnect.. would I have to change the whole valve cover (if catch can fittings are on valve cover) or would I get away with just closing off the AN fittings or whatever fittings you're using
Old 09-21-2016, 11:58 AM   #56
ExxelDistributions
It shouldn't be a problem but that is up to the tech if he wants to make it a big deal or not. Usually if it is just a fitting which is capped off and nothing is hooked to it I would just ignore it.
Smog check for out of state people? goshem Southern California 4 09-25-2015 06:20 PM
CA Smog Check?? JG Southern California 22 06-08-2015 11:05 AM
WARNING!!!! Monday 1/26 CHP SMOG check in Orange County-Cross streets-Lambert/Idaho continuecrushing Southern California 13 01-26-2015 11:19 PM
Need advice on passing smog in California rmak321 Northern California 7 07-12-2014 12:52 AM
Smog check and visual inspection help Corradooo Northern California 24 05-19-2014 11:57 PM
