Old 09-06-2016, 04:12 PM   #43
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Originally Posted by MaximeT View Post
I like it.
Do you think packaging for international shipping will be an issue ?
Should be doable. We're putting joints in the rear down tubes specifically to allow us to flat-pack it for easier shipping.
Jake
GSpeed is offline   Reply With Quote
Old 09-06-2016, 04:15 PM   #44
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
That should work I guess.
Time will tell
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 09-07-2016, 10:35 AM   #45
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
My bad. Ur quite correct. Good notes.
- When men make plans the gods laugh.
Brzzee is offline   Reply With Quote
Old 09-12-2016, 09:42 AM   #46
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Fitment is done, finishing up the production jig and some final welding before it goes to powdercoat this week.
How many people would be interested in a pre-order for the first run?
Jake
The Following User Says Thank You to GSpeed For This Useful Post:
batlwagn (09-12-2016)
Old 09-12-2016, 09:54 AM   #47
MaximeT
MaximeT's Avatar
I might be.
It will depend of the price of having it flying over the ocean
The Following User Says Thank You to MaximeT For This Useful Post:
GSpeed (09-12-2016)
Old 09-12-2016, 10:16 AM   #48
Gliderx
Drives: 2014 BRZ Limited
I may be also pending NASA approval of design and price. The most competitive I'll ever be is TT if I ever reach that high.
Gliderx is offline   Reply With Quote
Old 09-12-2016, 10:24 AM   #49
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
The roll bar will be NASA CCR compliant. NASA rules are actually pretty easy (part of why they've gained so much popularity lately over SCCA). So long as it's the right tubing size (which it is, for the 2500-3000 lb category) and is properly padded and close to the roof, you're good. (See CCR 11.4.7)
SCCA has been a little more of a hassle, but we're SCCA compliant as well. No sense making a roll bar if you can't go racing with it.
Brzzee (09-12-2016)
Old 09-12-2016, 12:39 PM   #50
byun
byun's Avatar
Drives: 2015 BRZ CWP
I am interested in picking one up
byun is offline   Reply With Quote
Old 09-12-2016, 08:13 PM   #51
Jonsey
Jonsey's Avatar
Interested.
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
Jonsey is offline   Reply With Quote
Old 09-12-2016, 10:44 PM   #52
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Interested as well
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 09-12-2016, 10:52 PM   #53
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Now that the prototype has made it into production, is there an idea of price? Progress looks great!
The Racers Line is offline   Reply With Quote
The Following User Says Thank You to The Racers Line For This Useful Post:
byun (09-12-2016)
Old 09-13-2016, 07:09 AM   #54
Alan
Alan's Avatar
Drives: 2013 SWP BRZ Ltd. / E60 M5
Very interested. Looking forward to seeing it in a car with fixed seats harnesses.
2013 BRZ Limited | SWP | Verus Ventus 1 and High-Efficiency Rear Wing | Invidia N1 Ti | JR Oil Cooler | RCE T2 | RaceSeng Cas/Cam | SPL LCA & TA | Wilwood/RR Racing Stage II/Sport Performance | XP10 | Apex ARC-8 | Toyo R888R | 245/40-17 | Sparco Ergo II/Evo II | AIM MXP | SmartyCam GP HD 2.2
Alan is offline   Reply With Quote
Old 09-15-2016, 07:57 AM   #55
Brzzee
Brzzee's Avatar
I'm not ready to select a fixed back seat, but one will be installed for the driver side then for passenger. GSpeed has a seat mount with slider that I intend to use with seat install.
I'll be installing Schroth Clubman III 6pt with OEM seats. GSpeed is installing harness mount points on the inboard seat sides for the snap-on lab belts. The shoulder harness will be wrapped on the cross bar with clamp-on web sliding stops.
Pictures to follow.
Old 09-15-2016, 08:47 AM   #56
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I may be interested in a first run pending the price
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
GSpeed Roll Cage Kit Development GSpeed Tracking / Autocross / HPDE / Drifting 66 07-14-2016 12:59 PM
Finally looks like there is a proper bolt-in roll bar solution! OkieSnuffBox Tracking / Autocross / HPDE / Drifting 47 08-23-2015 07:13 PM
FS: Battle Version BOLT IN roll bar/cage Fortunate Few Brakes, Suspension, Chassis 22 07-22-2014 02:35 PM
Bolt in Roll cages. Ludacrits Cosmetic Modification (Interior/Exterior/Lighting) 8 01-26-2014 06:19 PM
86/BRZ/FR-S Bolt In Roll Bar by Alex Pfeiffer-Battleversion 03Z33 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 61 01-28-2013 04:57 PM
