Old 09-07-2016, 10:05 PM   #127
Deadrik
Drives: 02 Mustang, Hopeful BRZ soon
Originally Posted by Zaku View Post
Sounds like it some mistake :/ guess their configuration isn't bug free yet
Thats disappointing although completely understandable.
The description for the rims also is the description for the WRX. Doesn't look like there was too much QA/QC before they made the site live.
Unfortunately i cannot copy/paste the description over.
Deadrik is offline   Reply With Quote
The Following User Says Thank You to Deadrik For This Useful Post:
Zaku (09-07-2016)
Old 09-07-2016, 10:12 PM   #128
funwheeldrive
That sounds like a fair trade to me since the automatic doesn't get the extra horsepower.
Old 09-07-2016, 11:29 PM   #129
Jakinit
Drives: 2017 CWP BRZ Limited (MT)
To me it seems that Subaru doesn't really care for the automatic. And because I'm manual-biased i can't say I blame them. This car is all about control and your connection to the road and an automatic takes away from that. Plus it'll add a lot of weight messing with the balance.
Sent from my Nexus 6P using Tapatalk
Jakinit is offline   Reply With Quote
Old 09-07-2016, 11:37 PM   #130
Si_Chris
Drives: 2016 ISM BRZ Limited, 2000 Civic SI
Originally Posted by Oxyg3n View Post
Hey guys, I didn't want to make a new thread, so I'll just post it here. I experienced my first traffic in my brz today and to my surprise it was hard to drive in 2nd gear. When slowing down (without throttle or brakes, but just in gear) the car will chug back and forth anywhere under ~13-14mph in 2nd gear. I thought 2nd gear should be able to tolerate that well since everyone says they don't go into 1st until they get under 5mph. Or am I wrong? And it seems like anywhere under 20mph is just too slow to go into 3rd gear. How do you guys do it? This is based on a 2017 brz btw.
Keep it in gear if traffic is moving along, but keep it in the right gear. Get used to matching the traffic speed, gear, and appropriate RPMs (ideally between 2-3K RPM). Once you do, the car won't chug if you're on and off the throttle.
If traffic slows down, just pop it into neutral and coast. If you need to speed up, engage it 2nd gear, never 1st gear, and feather the clutch to get some momentum, then pop it back into neutral and coast. If you don't want to keep going in and out of neutral, just find the right gear like I said earlier and learn how to feather the throttle.
Si_Chris is offline   Reply With Quote
Old 09-11-2016, 04:27 AM   #131
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by Zoh View Post
How bad (if at all) is it to rev the engine over 4k during the break-in period?
I'm at about 200-250 miles on mine right now; I haven't redlined it, but I've definitely gone up to 5k-6k on occasion when overtaking on the highway, etc., and over 4k maybe a couple times a day so far. Never for extended periods, mind.
I seem to read conflicting reports on it. I'm essentially just driving it as I would after the break-in. (I guess I'm going a little easier on it than I would, especially since I'm still getting used to driving stick.)
No issue if it is occasional. Most important is to drive it with different rpms. Some drive constantly in 2k rpm or 2.5k rpm which is not good. You need to drive in all the rpm ranges during the break in period (2k - 4k).
Old 09-11-2016, 05:01 AM   #132
Zoh
Drives: None
Ok, good.
I've probably revved it a little high a little more often than I should, bust most of my driving is spent between 2k-4k
I get to spend the weekends in the upper half of the RPMs, and the weekdays in the lower half due to being in traffic most of the time. It feels pretty balanced.
- Zoh
Zoh is offline   Reply With Quote
The Following 2 Users Say Thank You to Zoh For This Useful Post:
nikitopo (09-11-2016), Zaku (09-11-2016)
Old 09-11-2016, 01:29 PM   #133
Jakinit
Ok, good.
I would try and keep it under as much as possible. I'm at ~700 miles and I've only went over 4k like twice or three times.
Old 09-13-2016, 01:30 AM   #134
Oxyg3n
Oxyg3n's Avatar
Drives: 2017 BRZ - WRB
The feeling of getting gas for your new car! If anyone is interested in how the 2017 car is doing on gas.. I'm pretty happy with how far the tank takes me so far, 354 miles on one tank. Although that is like 75-80% highway. I got nearly the same with my previous car which had a 17.1 gallon tank.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Oxyg3n is offline   Reply With Quote
The Following 2 Users Say Thank You to Oxyg3n For This Useful Post:
Bristecom (09-13-2016), chaoskaze (09-13-2016)
Old 09-13-2016, 01:44 AM   #135
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Does anyone know if the headlights and the front bumper will fit on 13-16s models? What if some of us want the new models but don't wanna buy it lol.
I'm sure it most likely would as the car basically looks the same all around, but I'm just curious as to how easy would it fit.
Alltezza is offline   Reply With Quote
Old 09-13-2016, 03:06 AM   #136
bleox
Drives: 2015 Subaru brz
The cluster looks Crammed I thought it was gonna look a lot better
bleox is offline   Reply With Quote
Old 09-13-2016, 04:09 AM   #137
CJRhoades
Drives: 2017 BRZ Limited 6MT WRB
It really looks very nice in person. The premium cluster seems kind of cheesy in comparison. The nicer gauges and info display are one of the main reasons I opted for a limited.
CJRhoades is offline   Reply With Quote
Old 09-13-2016, 04:11 AM   #138
bleox
Oh their is 2 different displays ? Didn't know
Old 09-13-2016, 09:34 AM   #139
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Does that digital portion still show coolant or anything?
The digital portion doesn't look as good as I imagined, but I'm sure it looks better than the base level trim.
Old 09-13-2016, 01:34 PM   #140
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
I thought the last part where it says 11 miles was miles until empty? But your fuel gauge shows full. Is that something else or is it just delayed?
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Who's driven an rx8 and frs sci3 FR-S / BRZ vs.... 56 04-29-2015 04:20 PM
Anyone driven a 15 GTI 6MT yet? phobos512 Other Vehicles & General Automotive Discussions 2 12-31-2014 12:49 PM
Driven: FR-S 6MT, 6AT, BRZ 6MT. Michael Blue BRZ First-Gen (2012+) — General Topics 32 05-22-2014 06:20 PM
Anyone Driven an MX-5 and BRZ? Dzeremijs FR-S / BRZ vs.... 95 06-06-2013 08:26 PM
