| FR-S / BRZ vs.... Area to discuss the FR-S/BRZ against its competitors [NO STREET RACING] |
Drives: Seckksy
Who's driven an rx8 and frs
Those who have driven the rx8 how can you compare it to the frs?
Which is lower and more thrilling to drive? Which is faster? Etc Which do you think is better???? |
Drives: FR-Z
I drove a 2004 RX8 before getting my FRS and the FRS is definitely my favorite choice. The RX8 has a much higher RPM limit of 9K and pushing close to 240HP but the reliability issue makes is one of the worse cars I've ever owned. It handled nice and the rotary sounds sweet when you pin it but nothing has ever put a smile on my face like the FRS does.
| The Following User Says Thank You to myusernameisrob For This Useful Post: | NWFRS (08-30-2014) |
Drives: ‘13 FRS
[ame]http://youtu.be/jImHTWfj8aM[/ame]
I'm sure everyone's already seen ^ that. Most of my friends drove Mazda Rotarys in high school. After watching at least a dozen motors blow in as many months, I wouldn't touch them with a ten-foot-pole. :-( The Renesis was supposed to be the answer, but after watching Mazda struggle with them, I'm still not convinced. Hopefully our little FA20's will hold up in the long term. :-)
#4 | |
Drive From Home
Drives: BRZ STI Performance
So just wondering which car has a lower driving position and hood line, RX8 or FRS? Last edited by krayzie; 08-31-2014 at 07:38 AM. |
Drives: A Rickshaw
To me, the FR-S is what the RX-8 should have been.
I've been told that the RX-8 is a bit faster... However, the 86 improves upon the RX-8 in so many ways. I feel that the rotary engine was the RX-8's achilles heel and its strength at the same time. Aside from the rotary, the styling with the freestyle doors was a toss up... I personally liked the styling and versatility. Also, the handling, balance, and steering feel were much praised on the RX-8... And the 86 is not inferior by any means. Since the 8 is no longer in production and you seem to be considering pre-owned, I'd still opt for the FR-S... But you won't know for sure until you've personally test driven both. That would be an important step. |
this is definitely a thread where opinions are going to be spoken as fact and that is never a good thing.
#7 | |
Proud of Boxer
Didn't check the oil level every 300 miles? That's ok Started the car, moved it 5 feet, turned it off? That's ok Drove it around gently? You got 25 MPG I love the RX8, love the motor that's in the RX8, but ultimately it's DD sports car with a motor that's difficult to live with on a daily basis. |
Drives: 2013 SWP BRZ Limited
I have a BRZ and my gf has a 2006 RX8 Automatic. The reliablity of the RX is all about the owner and previous owners. It drinks oil and you have to stay on top of everything (this car is not dummie proof). The car also floods if you dont let the engine warm up all the way before shutting it off. I end up pushing this car around if I need to move it fast to avoid this issue. Also it gets 18mpg and my car gets 30mpg combined. They are both fun to drive and honestly I wouldnt mind a RX8 as my second car but it would not be my primary DD.
Drives: WRB BRZ
I just drove my BRZ and an RX-8 back to back at an autoslalom event on Sunday. My BRZ is stock, the RX-8 has a couple of mods
RX-8 Impressions: -handles better with the coilovers than my BRZ -grips better with wider tires -less torque but once the RPMs get up, it feels much faster -steering rack is slower -no seat bolsters throws me around the car a little bit more I never got used to the RX-8 since I only had a few runs with it, but I finished with exactly the same time as the BRZ. The RX-8 I was driving had the potential to go 1-1.5 seconds faster with a little practise...but then again, if my BRZ had coilovers and wide tires, I would be able to go even faster. The RX-8 is a little bit more fun to drive with a better balance and an engine that can rev to the moon, but I'd choose my BRZ over the RX-8 for a DD. [ame]http://youtu.be/2gNdlzaapoI[/ame] |
#10 |
Y u do dis?
owned both, Mine was a 40th Anniversary edition. Gotta say that the only thing I liked better about it was... Revs to OVER 9000!
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now. |
#11 |
It's Korea backwards.
Drives: 2014 FR-S Whiteout
I had a 2006 RX8 before I bought my FRS. Honestly other than having to check the oil every 2 fill ups and the lack of head room, it was the best car I have ever owned. It handled and looked great and mine had all the luxuries the FRS doesn't offer. Moonroof, Bose premium sound, heated seats, keyless entry etc.
My RX8 ended up getting totaled and I wanted to buy a NEW car that handled just as well as my Mazda. So the FRS was the only real choice available. (Wasn't going to spend 30k on a BRZ.) By comparison the FRS does feel like a better drivers car. It handles better than the RX8 and to be honest, after driving both, it doesn't feel like the RX8 had more power. Both have no torque but with the 8 there was no dip. Now that I have installed a UEL header and tuned my FRS it is hands down faster than my RX8 ever was, but I think I would still prefer the Mazda. If Mazda hadn't discontinued the RX8 I would probably own a 2014 model now. |
#12 |
Drives: BRZ Pearl White
RX 8 is too cramped for 6 + footers but otherwise is a fantastic sportscar. It'll blow the FRS away easily, by at least a full second to 60 mph. However, the FRS/BRZ is much more the basic sportscar than the RX8.
Of the two the BRZ/FRS will reward the enthusiast more than the RX8 but only because the BRZ is so much more directly connected to the road. From a performance standpoint the RX8 is the one to buy if you're 5' 10" or shorter that is. |
#13 | |
Village Idiot
Drives: '13 FR-S Ultramarine Manual
2009 Mazda RX-8 R3 0-60 mph 6.5 Quarter Mile 14.8 Extra source http://www.0-60specs.com/mazda-rx8-0-60-times/ Wrong. |
#14 |
Drives: meow!
currently own both of them, 2013 FRS and 2010 Rx8 R3.
absolutely LOVE both of them. the rx8 is on tein flex coilovers while the frs is on cusco street coilovers. they both handle great. rx8 however feels a lot smoother whilst the frs gives more road feed back. however i'm sure this can all be tweaked depending what suspension setup one goes with. stock to stock i couldnt tell you which i'd go with, they both have their own personality, however i do like the oem recaro's in the rx8 a lot more than the oem seats in the frs. the 09+ series 2 rx8's have a revamped renesis motor so supposedly they're supposed to be more "reliable" now(doesnt burn oil as much, better oiling system, etc). either way if u dont know your way around or how to take care of a rotary motor you'll find yourself in the "oOOo stay away from rotary, they're scary" crowd. i'm at 78k miles in mine and dont even premix, not one issue. the weird fa20 with DI is just as weird imo. i'm just as paranoid having a DI failure on hard track days as i am blowing an apex seal. lol |
| The Following User Says Thank You to ohayo For This Useful Post: | hmong337 (11-11-2014) |
| Driven: FR-S 6MT, 6AT, BRZ 6MT. | Michael Blue | BRZ First-Gen (2012+) — General Topics | 32 | 05-22-2014 05:20 PM |
| Anyone Driven an MX-5 and BRZ? | Dzeremijs | FR-S / BRZ vs.... | 95 | 06-06-2013 07:26 PM |
| Fastest you've ever driven | thorlius | Other Vehicles & General Automotive Discussions | 211 | 11-05-2012 11:41 AM |
| Most fun cars you have driven under 200 HP | Thunderchicken | Other Vehicles & General Automotive Discussions | 65 | 08-03-2012 08:36 PM |
| Question for those who have driven FR-S/BRZ | Sport-Tech | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 04-10-2012 11:59 PM |
