Old 06-23-2012, 08:45 PM   #15
Calum
That Guy
Drives: 2013 asphalt FRS MT
http://www.ft86club.com/forums/showthread.php?t=7932
I'm glad your asking question, but try looking around a bit to. RCE has suspension parts on pre order now that would probably be exactly what your looking to do and will work well with the stock dampers. Take a look at their site, the site itself isn't the greastest but their products are well made.
Also be very careful with the spring rates. RCE's and the stockers are even front to rear, 250 lb/in vs 185 lb/in respectively. The motion ratio of the rear vs the front means that you'll need slightly more spring rate in the rear to accomplish the same effect, but the rear is slightly lighter so even spring rates work well. This is very different then most cars that are very nose heavy. We've already seen springs realized that are vastly stiffer in the front, as if they were for different car....
Old 06-23-2012, 08:46 PM   #16
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by F3dzo View Post
would you happen to have a link or a mfr name?
Whiteline or Racecomp Engineering should be able to help.
http://www.whiteline.com.au/
http://racecompengineering.com/
Racecomp is a very helpful vendor here. Check them out in the Commercial sub-forum. Ask questions.
http://www.ft86club.com/forums/showthread.php?t=8823
Because titanium.
Old 06-23-2012, 08:47 PM   #17
Dimman
Kuruma Otaku
Dimman's Avatar
Beat me by a minute! Stupid phone...
Because titanium.
Old 06-23-2012, 09:30 PM   #18
Calum
That Guy
BRZ spotted in lower mainland! kidgogeta CANADA 21 04-29-2012 02:20 PM
Lower ride height in NYC? blur NY / NJ / CT / PA 9 01-19-2012 06:31 PM
