Old 09-09-2016, 05:38 PM   #1
Phil0rd
Drives: 2016 WRB BRZ
OFT Overheat Problem??
Talking about the tablet itself, not the car.
It happened to me twice, both on pretty warm days. When I start the car and turn on OFT, it couldn't boot normally. Once it stayed at the boot screen forever and the other time the screen even gradually turned all white.
I freaked out, thinking that I permently lost this device. Then I realized the case was pretty hot. So held it again a AC vent for a minute then it booted successfully. I was surprised how sensitive to temperature it was.
Anyone had run into similar incidents before? Presumably OpenFlash doesn't mauafacute the tablet device themselves (correct me on this) so I guess there's really little they can do about this.
BTW I used an OBD2 extension with a switch so the OFT wasn't powered when the car was parked.
Phil0rd is offline   Reply With Quote
Old 09-09-2016, 07:38 PM   #2
steve99
Drives: FT86
Oft goes into that weird white screen if power is turned on\off\on quickly, might be contact bounce on your extension cable. To get it out of that mode turn power off or unplug for at least 30 seconds then turn back on. Often happens if you wiggle plug as your connecting to obd port
Old 09-12-2016, 12:56 PM   #3
golfyankee2121
Always Moving Forward
golfyankee2121's Avatar
Drives: 2013 Argento Scion FR-S
Steve99 hit it right on the head. I think it has more to do with wiggling around while plugging/unplugging than it does the heat. I have gotten the white screen many times when plugging my OFT back in, and it happens only when I don't get the teeth connected perfectly and they wiggle.
-J.B.
golfyankee2121 is offline   Reply With Quote
Old 09-12-2016, 01:04 PM   #4
rjgough95
rjgough95's Avatar
Drives: 13 Subaru BRZ, 02 7.3 F350 Diesel
Yeah I've had this issue couple of times with lose connection or from the heat. I tend to sit it in the back seat of the car if i know its going to be out in the sun light for an extended period of time.
2.5" Non-resonated Perrin catback - Hks dual resonator front pipe - Borla UEL headers - K&N drop in - Supertek intake pipe - Megans Racing strut bar - Racer X Fabrication cylinder brace - Valenti tail lights - Veloxs Motorsports front splitter - Galvez Customs rear diffuser - Open Flash Tuner - GCS paddles - Apex ARC8 Track Wheels
rjgough95 is offline   Reply With Quote
TRC problem Toyota GT 86 Scion FR-S / Toyota 86 GT86 General Forum 6 05-15-2014 08:42 PM
Big Problem jpit Engine, Exhaust, Transmission 156 05-13-2014 09:21 PM
Problem with car Atticus808 Other Vehicles & General Automotive Discussions 1 02-20-2014 12:14 AM
AT overheat safeguard? Tracking the Auto Transmission. Tye300 Engine, Exhaust, Transmission 8 10-14-2013 01:16 PM
Problem! axss Scion FR-S / Toyota 86 GT86 General Forum 32 11-24-2012 03:31 PM
