Old 09-08-2016, 08:03 PM   #1
Mr_YUzU_FRS
Drives: 2015 Scion FRS RS 1.0
Oil grade opinion please.
Hello, I have WORKS Stage 2 turbo kit, oil cooler, and running e85 flex-fuel kit.
I was told by WORKS to use 5w-30 instead of 0w-20 for engine oil. WORKS used ENEOS 5w-30 and the car seems to be running good for few months now. They told me I can use any synthetic brand as long as 5w-30.
Now its time for my first oil change since the turbo and I want to switch to Amsoil (based on many good reviews about them). I called a local Amsoil dealer and they told me to use 0w-20 and not 5w-30 because it will just create extra heat and may not perform as well as running 0w-20s. He said their oils are not like many other brands and are made to not break down during heavy driving and high temps.
I daily drive my car and do some spirited driving up/down mountain roads. I am not tracking my car but probably one day i might.
Can someone with more experience point me in the right direction? Thanks
Mr_YUzU_FRS is offline   Reply With Quote
Old 09-08-2016, 08:12 PM   #2
Trust86
Drives: 2016 Halo FRS
your boosted and in CA. Stick with 5w-30.
Use motul
Trust86 is offline   Reply With Quote
Old 09-08-2016, 08:24 PM   #3
menikmati
Drives: 2015 BRZ, 2005 STI, 2024 Type R
Run a quality synthetic 5w-30 from any brand you like.
menikmati is offline   Reply With Quote
Old 09-08-2016, 08:32 PM   #4
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I run Mobil 1 5w-30. It hasn't let me down yet!
MS, CSCS, TSAC-F, CPT
Old 09-09-2016, 08:02 AM   #5
Fred E
Drives: WRB BRZ
Remember, even with FI, engine tolerances haven't changed. If your oil is properly cooled...
What worries me on this higher weight oil is that engine clearances don't change after you boost it like @CSG Mike said.
It worries me that heavy oil will not be able to make it inside the tight clearances under all conditions. The goal of oil is for it to be present between metal parts and prevent them from contact.
The way I see oil is, the thinnest possible that will not break down at the intended use temperature.
What benefit is there from running 10-XX from 0-XX when COLD? I see none.
The advantage a XX-40 would have over an XX-20 is resistance to break down at higher temperatures which can be achieved with a good oil cooler keeping those temperatures in check.
I would agree for extreme conditions, a 5-30 would be an acceptable choice. But why go higher than that if you have an oil cooler that will keep oil temps below 230 at the worst possible?
I'm willing and open to reading/learning other people's knowledge on the subject.
As long as your oil temperature is kept in check (by an oil cooler), there's no reason to switch to a heavier oil. For whatever it's worth, I've been using either Motul or Amsoil 0w20 in my engine for about 45000 turbocharged miles (also with the Works kit) and a proper oil cooler. I haven't seen oil temperatures over ~190 while driving even in 90+ degree heat and I'm making (and using) close to 400 whp.
Fred E is offline   Reply With Quote
The Following User Says Thank You to Fred E For This Useful Post:
CSG Mike (09-09-2016)
Old 09-09-2016, 08:37 AM   #6
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Run 0w20 on a turbo and youll blow your shit up. All boosted subis run 5w30 and never seen a boosted car run 0w20. I have see alot of QQ people running 0w20 and blow there shit up though.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 09-09-2016, 01:42 PM   #7
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I've ran 5w-30 for over two years boosted at 500+ whp, still running strong.
Old 09-09-2016, 01:50 PM   #8
Mr_YUzU_FRS
Yes, I've heard many stories of boosted frs/brz blowing their motor when running 0-20. Don't know the details of reason why, it could be numerous reasons. Some saying 0-20 if I have proper cooling which i do have oil cooler. And some say do not run 0-20. lol
Works do recommend 5-30 though.
Old 09-09-2016, 02:19 PM   #9
GsxrMe
GsxrMe's Avatar
Turbo's kill and break down the 0w20 oil as it passes through the Turbo. I don't care what the temp of the engine is but once oil gets to hot and breaks down its never the same, It needs to be replaced because it's properties is no longer valid.
You can look at any... turbo'd car on the market and you'll never see anyone running 0w20. I personally use the same exacted oil as the Forester XT or WRX uses from Subaru with there ej20, ej25 and fa20 turbo's engines. I also use the same oil/water block to bring the oil up to temp super fast and maintains the oil at the perfect temp for street use.
This summer has been super shitty at 100f and I was super close to dropping 5w40 in the car.
0w20 for NA cars is fine it heats up quickly. No 1000f turbo is heating of the oil.
If you have the money to rebuild your motor by not taking the advice from you turbo kit manufacture then go for it. It's kinda of fun to use the search on the forums and look at all the people who would go over and over about using 0w20 and then don't have any problems and BOOM one day they post a new thread "OH noes my motor spit out a rod!".
Also noted Subaru recommends oil changes every 3000 miles, which is way cheaper than a new motor & your time. Oils cheap, Engines aren't.
2014 Subaru BRZ
Old 09-09-2016, 02:54 PM   #10
Mr_YUzU_FRS
My first intention was to go with WORKS recommendation. If you read the post it was the AMSOIL oil adviser that told me to run 0-20.
Its good to hear some useful advice from this forum. The AMSOIL adviser went kinda nuts at me over the phone and saying that mechanics do not know oil and that AMSOIL does not break down like other oils, and also running 5-30 will just create the extra heat.
Maybe I probably change my mind go with a different brand.
Old 09-09-2016, 05:39 PM   #11
GsxrMe
GsxrMe's Avatar
No i run AMSOIL all my Suzuki GSXR's. Its great, i personally should run the 5w30 in my car.
2014 Subaru BRZ
Old 09-09-2016, 08:19 PM   #12
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
Originally Posted by Norville Rogers View Post
More experience than WORKS that built your set up and have clearly advised you already? Who would that be?
Why do you have to shit-post everywhere
Toyarzee is offline   Reply With Quote
The Following User Says Thank You to Toyarzee For This Useful Post:
swarb (09-09-2016)
Old 09-09-2016, 08:32 PM   #13
wbradley
Sarcastic SOB
wbradley's Avatar
Yeah sometimes when he interjects I shake my head, then I look at his picture and see what looks like a confused bloke, consistent with some of his posts. He is polite though, most Brits are except, after the pub LOL
Old 09-09-2016, 09:16 PM   #14
steve86gt
Drives: 2014 Toyota gt86 avo stg 2 e85
Motul 5w-30 to 40 for boosted fa20's
steve86gt is offline   Reply With Quote
Vette-Powered BRZ by Weapons Grade shiud BRZ First-Gen (2012+) — General Topics 28 04-28-2015 02:53 PM
Weapons Grade Performance BRZ06 meet! PRORICAN New England 8 07-16-2013 07:34 AM
Has anyone driven Laurales Grade in Monterey 1FunFR-S Southern California 0 09-30-2012 02:04 AM
Grand Opening Sale @ Weapons Grade Performance Doug@WGP Announcements, Contests, Giveaways 2 08-22-2012 09:51 AM
Weapons Grade Performance Intro Doug@WGP Announcements, Contests, Giveaways 2 07-21-2012 05:24 AM
