Old 03-09-2014, 04:00 PM   #15
DesertFrs
DesertFrs's Avatar
Drives: Scion FRS 10 Series AVO Turbo
I'm using PurÖl elite 0w-20 on mine. Till this day I don't believe their enough clearance for anything thicker
DesertFrs is offline
Old 03-09-2014, 04:46 PM   #16
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
I'm sticking with ow-20 as well for street.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline
Old 03-09-2014, 06:37 PM   #17
carlossanchez89
2Supras1FR-S
Drives: 13 Scion FR-S, 87 Supra
Motul 5-40
carlossanchez89 is offline
Old 03-09-2014, 10:08 PM   #18
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Amsoil 5w30 dominator. Subaru recomends 5w30 for the turbo fa20dit.
Reaper is offline
Old 03-09-2014, 10:29 PM   #19
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
I think the best way to judge the best oil weight is to look at the blueprint of the engine. Someone must know the clearance. Although if they are using 5w30 on the new fa20 wrx that's probably the best way to go.
cjsporl1996 is offline
Old 03-09-2014, 10:54 PM   #20
CSG Mike
CSG Mike's Avatar
Remember, even with FI, engine tolerances haven't changed. If your oil is properly cooled...
CSG Mike is offline
Old 03-10-2014, 11:43 AM   #21
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
We know that any high end synthetic is going to "lubricate" the engine surfaces properly but common sense should lead you to make some judgement calls on the OEM oil viscosity with OEM HP levels of 150 whp on my dyno compared to 400 whp on the same dyno.
The biggest concern in any engine is going to be the force from the piston and rod being exerted on the "oil wedge" between the rod, rod bearing, and the crank. So the force being exerted on that oil wedge at 150 whp is not the same as the force trying to squeeze that oil out of the bearing at 400 whp. So many don't understand the job of the crank and rod bearings is not to act as bearings but to maintain the oil wedge which is the actual bearing.
Now track guys are seeing huge oil temps so oil pressure can drop significantly at these temps so cooling and increasing viscosity under these conditions is critical in maintaining high oil pressure so this "oil wedge" is maintained.
Look at the boosted guys who have spun bearings and realize they didn't have enough oil pressure to maintain the wedge and that's why the bearings failed so take note of their oil weights.
I'm on Redline 40w Race for racing and on a 10w40 for street as I know exactly how much oil pressure is required to keep from squeezing out the wedge on an STi motor. Problem is on the FA the rod bearings are narrower and therefore I know more pressure per square inch will be required than on our STi race engines.
Synthetics flow so well these days at cold temps you would be surprised at how a higher viscosity can still work well for street where OEM/EPA fuel/emissions requirements are not your requirement.
My 2c.
Phil Grabow
Element Tuning is offline
Old 03-10-2014, 01:51 PM   #22
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
@AVOturboworld @Drift-Office
Paul and Bob, what oil are you guys using?
cdrazic93 is offline
Old 03-10-2014, 01:54 PM   #23
lexusb3
Drives: FRS
My 2c.
Phil Grabow
And ppl called me crazy for using 10-40w thank you lol
lexusb3 is offline
Old 03-10-2014, 02:01 PM   #24
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Well, logically thinking after a certain level of power, the OEM oil won't be able to hold up to the increase of pressure and heat, requiring a thicker weight oil. Question is, which is best. No one would know until someone does a tear down of two engines at the same hp driven for the same miles using different oil.
Old 03-10-2014, 02:09 PM   #25
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by cdrazic93 View Post
I ran Amsoil Signature 0w20 in mine.
King Tut is offline
Old 03-10-2014, 02:10 PM   #26
cjsporl1996
I can't see how a 10w40 in this engine is a good idea at all. I mean I run a 10w40 in my Chevy 350 that puts out 320 whp and 360 pounds of torque at the wheels. We need a engineer on this forum lol.
Old 03-10-2014, 02:34 PM   #27
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
What worries me on this higher weight oil is that engine clearances don't change after you boost it like @CSG Mike said.
It worries me that heavy oil will not be able to make it inside the tight clearances under all conditions. The goal of oil is for it to be present between metal parts and prevent them from contact.
The way I see oil is, the thinnest possible that will not break down at the intended use temperature.
What benefit is there from running 10-XX from 0-XX when COLD? I see none.
The advantage a XX-40 would have over an XX-20 is resistance to break down at higher temperatures which can be achieved with a good oil cooler keeping those temperatures in check.
I would agree for extreme conditions, a 5-30 would be an acceptable choice. But why go higher than that if you have an oil cooler that will keep oil temps below 230 at the worst possible?
I'm willing and open to reading/learning other people's knowledge on the subject.
Sportsguy83 is offline
Old 03-10-2014, 03:00 PM   #28
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
would a 0w-40 be any different than a 5w-30?
forced induction, oil, oil weight
going forced induction ft86me Forced Induction 14 02-05-2014 08:23 AM
Forced induction for ATs? Lokutus Forced Induction 10 02-26-2013 03:42 PM
NOS or Forced Induction? v3rgil AFRICA 1 11-08-2012 07:17 AM
6AT (+) Forced Induction RYU Forced Induction 18 09-09-2012 11:14 PM
Forced Induction Primo86 Engine, Exhaust, Transmission 11 05-29-2012 07:50 PM
