Old 09-08-2016, 08:00 PM   #1
Ashikabi
Ashikabi's Avatar
Brace FRS/BRZ/86 trunk for GT Wing/Trunk lateral movement
This is my first DIY so bear with me. I'll try to be thorough...
I have the Rocket Bunny V1 GT wing on my FRS. I noticed I had a spot on my quarter panel, inside the trunk cavity, that had no paint! Only primer is left.
upload gambar
I determined that the extra weight of the wing was causing the trunk to "slide" sideways under heavy cornering. To solve this problem, bracing was needed. Not a big chassis mounted rack but something simple to keep the trunk in place yet fully functional. On the trunk shock/strut brackets there is a small tab. I drilled and tapped this tab (7/32 drill, 1/4 28 tap) to receive a socket head cap screw and a nut to lock it in place.
upload images
I got reinforced rubber boots from McMasterCarr(part number 2517T35 http://www.mcmaster.com/#catalog/122/1414/=14326za ) To cushion/protect my trunk lid.
free upload
Additionally I did a little welding/grinding on my trunk latch loop to make it better fit the latch mechanism. Its just a tiny bit wider but it made a big difference in the stability of the trunk lid.
how to do a screen shot
So there you have it folks! My trunk has almost zero movement now as tested by grabbing my wing mounts and prying sideways. If you have any questions feel free to ask
The Following 3 Users Say Thank You to Ashikabi For This Useful Post:
Dadhawk (09-08-2016), Pointmutation (09-15-2016), soulreapersteve (09-08-2016)
Old 09-09-2016, 12:07 PM   #2
Bach415
Bach415's Avatar
Drives: Whiteout FRS
@Ashikabi Did your trunk come with oem spoiler? If not then you probably didn't have the additional two rubber standing mounts(one on each side of the trunk lid) that actually came with oem spoilers that suppose to prevent the problem from occuring. Those without oem spoiler does not have those holes drilled. Here are two pictures comparing the trunk. If you look where the spoiler is located on the white brz, you'll see two rubber grommets and a rubber standing mount on each side on the trunk. If you look at the same spot for the ultramarine frs, it does not have the rubber standing mounts. If I'm correct, those two rubber standing mounts sit on top of the tabs that you tapped and drilled.
Bach415 is offline   Reply With Quote
The Following User Says Thank You to Bach415 For This Useful Post:
Old 09-09-2016, 04:04 PM   #3
Ashikabi
Ashikabi's Avatar
I wondered why there was a little spot on the trunk lid... no I did not have a spoiler. Thanks for the info!
The Following User Says Thank You to Ashikabi For This Useful Post:
Bach415 (09-10-2016)
Trunk Swap (My trunk w/ Limited spoiler to non wing) SWP Kuujo Southern California 4 09-18-2015 01:34 PM
Trunk and wing swap for trunk and cash SavingManuals Canada Classifieds 7 07-23-2015 05:03 PM
Trade my Crystal Black Silica BRZ limited trunk (w/ wing) for wingless trunk (SF Bay) Iamthebatman Exterior Parts (Aero, Lighting, Etc.) 2 07-18-2013 02:12 PM
WTT: SoCal SWP BRZ BRZ Limited Trunk with Spoiler for Trunk without Wing wollview Exterior Parts (Aero, Lighting, Etc.) 1 12-30-2012 03:14 PM
WTT: SoCal SWP BRZ BRZ Limited Trunk with Spoiler for Trunk without Wing wollview Southern California 0 12-16-2012 02:46 AM
