Old 09-09-2016, 04:58 AM   #1
killy
Drives: BRZ Limited
Normal working temperature LSD
Guys does anybody know the average temperature of the oil / diff carrier under normal stock driving conditions?
killy is offline   Reply With Quote
Old 09-09-2016, 10:30 AM   #2
jcw99
Drives: swp mt '14 brz premium
When I get in the car the gauge is usually around the ambient temp. Yesterday the ambient temp was 90F when I got in the car and the gauge was in the 80's. It went up to around 150ish after driving for about 45 minutes. I think the hottest I've seen it this summer is 180. I've only had the gauges since the middle of May. The sweep on all my temp gauges is 60-260F, and I had them made at Speedhut. Yesterday my engine oil was about 200, the trans was 180, and the water was 195ish. I hope this helps.
jcw99 is offline   Reply With Quote
The Following User Says Thank You to jcw99 For This Useful Post:
killy (09-15-2016)
Old 09-09-2016, 01:19 PM   #3
Originally Posted by jcw99 View Post
When I get in the car the gauge is usually around the ambient temp. Yesterday it was 90F when I got in the car and the gauge was in the 80's. It went up to around 150ish after driving for about 45 minutes. I think the hottest I've seen it this summer is 180. I've only had the gauges since the middle of May. The sweep on all my temp gauges is 60-260F, and I had them made at Speedhut. Yesterday my engine oil was about 200, the trans was 180, and the water was 195ish. I hope this helps.
Do you/can you measure the temperature of the differential oil .. ??
I think that's what the OP was asking ... ??
Old 09-09-2016, 04:06 PM   #4
jcw99
Yesterday I drove for 45 minutes and when I got home and shut the car off the temp of the diff lube was 150F.
The Following 3 Users Say Thank You to jcw99 For This Useful Post:
humfrz (09-09-2016), killy (09-15-2016), Ultramaroon (09-09-2016)
Old 09-15-2016, 03:24 AM   #5
killy
Drives: BRZ Limited
Thanks a lot for the info guys!
What temperature do you put A/C on? FRiSson New England 23 06-13-2016 08:55 AM
Outside temperature stopped working fanaticalz Issues | Warranty | Recalls / TSB 7 12-30-2015 01:05 AM
E85 and oil temperature jvincent Engine, Exhaust, Transmission 11 11-12-2014 08:53 PM
Running Temperature? 350matt Engine, Exhaust, Transmission 13 10-29-2013 03:55 PM
Exterior temperature 2thdoc Scion FR-S / Toyota 86 GT86 General Forum 15 04-28-2013 04:45 PM
