Old 06-23-2012, 02:25 PM   #71
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by jedibow View Post
That is one hypothysis, atleast my log shows that the VE of the engine drops in that area. So I believe that yes it is linked, now we just have to figure out why the VE drops in that area, and causes the torque dip. What is interesting is that the factory tune increases timing in that area, which in most cases increases VE, but for some reason it doesn't in this car
From a bike tuning book:
Where the pipe produces a flat spot, cylinder filling sags and so does flame speed, thus requiring more advance.
Because titanium.
Old 06-23-2012, 03:56 PM   #72
johnbradley
Drives: Turbocharged
Don't tell me you jumped the Evo also? John were the scalings in EvoScan made specifically for the Evo X? for some reason certain values do not log correctly for this vehicle, I.E. Maf reading 10,000 ???? throttle percentage 80, at WOT, O2 feedback 65****,
Thanks John
P.S. I don't mean to put you to work HaHA
Not jumped, but I tune Nameless' cars and they use our dyno. John and Jason involve me in the projects though and I had this the other day for the header testing. They narrowed the gap in the flat spot from stock and the reason I feel is that the scavenging has been improved (i.e. airflow is up) and fills the cylinders better. If I can log MAF voltage we can overlay the stock one you have vs their car on monday when it comes back. Can you PM or email what I need to log the BRZ?
sales@englishracing.net
Thanks
JohnBradley
johnbradley is offline   Reply With Quote
Old 06-23-2012, 04:08 PM   #73
jedibow
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
Thanks
JohnBradley
You have evoscan correct?
I have also already posted two difference .csv files for Arghx7, they are earlier in the post
jedibow is offline   Reply With Quote
Old 06-23-2012, 04:16 PM   #74
johnbradley
Yeah I have EvoScan 2.6 I think is the newest..I can look and see I might have 2.9 right now.
Old 06-23-2012, 04:23 PM   #75
jedibow
If you don't you do now HaHa, check your email,
George
Old 06-23-2012, 04:58 PM   #76
serialk11r
Drives: '06 AM V8V Coupe
Is absolute load a reading that comes (essentially, calculated) from the MAF then?
Old 06-23-2012, 05:02 PM   #77
jedibow
Partially yes, there is also compensation from the barometric sensor (MAP), intake air temp sensor (IAT), and the crack position sensor to determine stroke (CPS), arghx7 posted the formula for the calculation above, post #67.
George
Old 06-23-2012, 05:39 PM   #78
serialk11r
George
Ah, so it's the ECU calculated volumetric efficiency, right? Thanks!
Old 06-23-2012, 06:25 PM   #79
johnbradley
In the Evolutions for reference (and other Subarus as far as that goes) its a derivation of MAF reading / Rpm * X
where X is a predetermined constant
The Evo uses a Karman so its Hz/rpm*852, this uses other variables but you get the basic idea. Load itself is also a form of gram/s (g/rev) which in the GD/GR Subaru is a Grams Per sec * 95 = load (as found in the Mitsu as the listed percentage of 0-400%).
Old 06-23-2012, 06:31 PM   #80
arghx7
Drives: car
Originally Posted by E92M3Guy View Post
If it will help, I've been taking complete data logs of the engine CAN bus and reverse-engineering the data locations. I suspect your tool communicates with the ECU via D-CAN (diagnostics CAN) and that's why you're sending PIDs to the ECU and getting response data. I'm looking at the raw data on the bus itself. Let me know if there's any of the raw data might be helpful.
What are you using, CANalyzer? Are you passively listening across the bus only or also requesting data using the info I posted earlier in the thread? For a simple car like this, most of these engine-specific diagnostic parameters are not normally reported across the bus in normal operation. Now for expensive German cars with a lot of control modules there will probably be more data being exchanged there.
What you will find are engine speed, vehicle speed, torque reduction requests, steering angle and probably yaw rate, possibly wheel speed, tire pressure, and operation from the body control modules. Trust me on this from firsthand experience with actual manufacturer CAN message libraries...
The sensor itself might have a slow refresh rate. In this case, the ECU is reading the sensor data at a slower rate, and that's why it only updates in your logs at such a slow rate as well. For example, RPM data on my BMW CAN bus is updated every 1ms, but temperature data is updated every 1s. D-CAN pulls the data down every 70ms (on the BMW), but you can clearly see temperature sensor refresh rate matches the engine CAN bus at 1s update intervals.
The cat temperature is an estimate based on a model. There is no exhaust temperature sensor. Even if there were a sensor (like some of the older turbo Subarus, 2005 Legacy GT for example) there would still be a model. The model could actually be a simple look up table, or more likely it is pretty involved.
I suspect it is just the bus reporting it at a slow rate as you mentioned.
Your log of MAF voltage parallels the powerband perfectly. The dip in torque is related to Airflow and I would wager its AVCS dropping cylinder pressure to prevent knock at peak load.
Just FYI, MAF airflow is reported in grams/sec when you request it as a universal diagnostic parameter. There is no raw MAF voltage available when you request data in this manner. From page 14 of the parameter list I posted:
If you want raw voltage, you will need equipment to measure it at high speed or you will need to read it directly from the ECU.
After reading the rest of the thread and seeing the ignition screenshot from ECUtek, the timing is low there but I havent ever seen ignition timing affect airflow. It wont be helping of course but I am not sure thats the whole cause.
Generally speaking, ignition timing affects combustion phasing more than anything else. That means it affects the crank angle degree at which max cylinder pressure occurs and it affects the mass fraction/heat release curves.
The other thing I wonder is if its like the GTR and not a real number anyway but a calculated burn rate vs ignition timing number.
The GTR's ignition timing control system is greatly misunderstood... those offering tuning solutions for it figured out just enough to make some adjustments, but they do not really understand the calculations that go on inside the ECU. Unless something drastic has changed with the BRZ software (compared to prior Subarus that we understand), the BRZ is not even close to the way the GTR calculates timing.
Old 06-23-2012, 06:31 PM   #81
Dimman
Kuruma Otaku
Dimman's Avatar
Which means that fueling and ignition will not be flattening the dip out.
Because titanium.
Old 06-23-2012, 06:44 PM   #82
jedibow
shouldn't the maf voltage be linear? What I'm getting at is if we know the lowest voltage, and the highest voltage couldn't we calculate the voltage corresponding to the g/sec reading by creating an excell sheet with ploted points?
Example
xmin=0 (0 compared to g/s), xmax=5 (655.35 compared to g/s), plot the sensor readings and choose the best fit equation in excell to give us or conversion formula?
Just a thought, this has been the direction I've been attempting to take to get the scalings corrected in Evoscan as long as I know the readings are on a linear sensor.
Old 06-23-2012, 06:48 PM   #83
jedibow
Not completely no, however by changing the cylinder pressures and temperatures with adjusting timing, and fuel I think that we can atleast make it better.
However some will see this as a band aid, instead of a fix, as of right now I think your Cam phasing idea is the most likely candidate as the culprit.
Dimman, hurry up and design new Cams that will eleviate the torque dip, increase power across the board, and save gas!!!!
No pressure BTW!
Old 06-23-2012, 06:49 PM   #84
arghx7
Drives: car
It doesn't report voltage. It reports mass flow. Plug a universal scantool (like the orange Actron ones used at Autozone) into any vehicle equipped with a MAF sensor, and you will read MAF sensor airflow in grams/sec. You can't read voltage using this type of request.
MAF calibration curves are never linear, they are logarthmic/exponential to have higher resolution in lower airflow ranges.
Great dealership in NE Ohio.. (still has multiple pre-order slots open) eikond BRZ First-Gen (2012+) — General Topics 15 03-02-2012 01:03 PM
Open Air FR-S Concept Rampant FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 22 02-01-2012 11:01 PM
Open Deck Block nrclptcnsmniak Engine, Exhaust, Transmission 36 01-27-2012 01:00 PM
Keep your eyes/cameras open in SoCal? Buggy51 Scion FR-S / Toyota 86 GT86 General Forum 14 10-10-2011 10:21 PM
