Old 09-06-2016, 12:37 PM   #365
HotLavaDude
Character is Destiny
Drives: 2015 FR-S Hot Lava Metallic
Originally Posted by Torry@HKSUSA View Post
From my understanding, you may run into problems with one of the pulleys on an automatic version. I'm not sure what that problem is, but I've been told one of the pulleys is different which can cause an problem during install on an auto. If anyone has more details on that, please let me know so I can make note of it!
Also, just to clarify, the HKS Flash Editor will not work on an AT car. So you if you do install the V3 kit, you will need custom tuning.
Torry, Thanks a lot. I will research to see if anyone has mentioned this pulley issue with automatics.....Hopefully easier than searching for a a needle in a haystack...
HotLavaDude is offline   Reply With Quote
Old 09-07-2016, 07:21 AM   #366
lostpanda
Drives: FT86
Originally Posted by Yobiwan View Post
Part no. for 90mm pulley is HKS 12999-AK003
And you can order from here http://www.rhdjapan.com/hks-gt-super...lley-90mm.html
Without restrctor, v2 can make 14-15psi@7500.
V3 kit has larger intake charge pipe(than v2)
So if you use 90mm with v3, you should watch your boost level. It will make more boost than v2.
Thanks for you to provide me the part number for pulley kit.
I still have a question the the pulley kits.
Is there a belt in this kit 12999-ak003?
If this kit has a belt I will order at once.
Also in China we only have the number 92 petrol like USA.
So 700CC is enough for me ?
lostpanda is offline   Reply With Quote
Old 09-07-2016, 07:26 AM   #367
lostpanda
Drives: FT86
My car is AT also Please make a note for us thanks a lot.
The good thing is I must have a custom tune....
Old 09-07-2016, 07:51 AM   #368
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
no , it's just pulley.
V3(110mm stock pulley) use 2160mm size belt
V3+100mm pulley use 2135mm belt
V3+90mm pulley? I don't know exactly, maybe 2110mm?
V2 stock belt is 2110mm size
.so you must figure out about this =)
2012 Toyota 86 6MT / 11:1 CR block by Outfront / SBD500x Turbo 17PSI@93gas /Avo 2.5 overpipe+Avo 2.5 catted frontpipe /MAP 3" CBE/ Tein Mono sport / STI brembo Front /OS技研 LSD/SSR GTX01 18x9.5
Yobiwan is offline   Reply With Quote
Old 09-07-2016, 11:32 AM   #369
Gearbanger
Gearbanger's Avatar
Drives: Lexus is300 celica gts
So got my HKS kit with the smaller pulley making 11.5 lbs of boost but stock MAP sensor only reads 5.5 max. I picked up omni 3 bar but the HKS can tune doesn't read it. So I order the analog boost tap for the P3 kit just curious if any one with the HKS kit or P3 gauge has any tips. HKS can tuned for e85. I ordered an analog boost accessory from PS wheres a good place to pick up the boost reading from the HKS kit? Boost gauge port or Vacuum tap. Thanks
Gearbanger is offline   Reply With Quote
Old 09-07-2016, 11:41 AM   #370
HuntingtonFRS
Drives: 2013 Scion FR-S in White
I don't understand why you are only getting 5.5 considering the V3 runs like like 8lbs of boost as is. I'm using a vacuum based boost gauge and it is accurate. HKS tune never states that you would need a new MAP sensor.
HuntingtonFRS is offline   Reply With Quote
The Following User Says Thank You to HuntingtonFRS For This Useful Post:
zeal86 (09-07-2016)
Old 09-07-2016, 01:25 PM   #371
Gearbanger
Gearbanger's Avatar
Stock MAP senor only reads too 5.5 its making 11.5 on the smaller pulley (everything is running fine its just a secondary gauge issue) . Just trying to get my P3 gauge to read the correct number. Best place to Boost gauge port or Vacuum tap?
Old 09-07-2016, 07:22 PM   #372
lostpanda
Drives: FT86
So the point is how can I get the 2110mm belt.
I saw on hks manual they recommend us to use their belt only.
Is there hks has a kit like 100mm (incloud belt and pulley) ?
Old 09-08-2016, 09:24 AM   #373
Torry@HKSUSA
Torry@HKSUSA's Avatar
Drives: HKS
The HKS 6PK2110 belt that is the one that comes with the V2 kit is 24996-AK032.
I answered this somewhere, it must have been in a different thread.
Torry@HKSUSA is offline   Reply With Quote
The Following User Says Thank You to Torry@HKSUSA For This Useful Post:
Yobiwan (09-08-2016)
Old 09-08-2016, 10:35 AM   #374
Gearbanger
Gearbanger's Avatar
Now what about this? Best place to Boost gauge port or Vacuum tap
Old 09-08-2016, 10:37 AM   #375
HuntingtonFRS
Tap the vacuum line coming from the Bypass Valve by HKS. You can tap with a "T" tap behind the intake manifold for an easy location.
Old 09-08-2016, 11:35 AM   #376
Gearbanger
Gearbanger's Avatar
Thanks any special size etc?
Old 09-08-2016, 11:44 AM   #377
HuntingtonFRS
Special size?
Old 09-08-2016, 11:45 AM   #378
Torry@HKSUSA
Drives: HKS
It's just standard 4mm vacuum line. Nothing special.
The HKS kit comes with a 10mm/4mm/10mm T-fitting and vacuum line to install it. If you want to add a boost gauge, just pick up another fitting from Autozone or O'Reilly's and splice into the line again to run the gauge off of it.
The Following 2 Users Say Thank You to Torry@HKSUSA For This Useful Post:
HuntingtonFRS (09-08-2016), Yobiwan (09-08-2016)
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 09:22 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 09:37 AM
