Old 09-02-2016, 11:01 PM   #85
Zoh
Drives: None
Lugging is basically when you leave the car in a high gear and try to accelerate. If you want to speed up when you're already coasting, you should downshift.
I notice a lot of new manual drivers don't feel comfortable with rev matching and downshifting, but it's how the car is meant to be driven.
Ah, I don't do that anyway, haha
I've been downshifting, even though it seems scary sometimes haha
- Zoh
Zoh is offline   Reply With Quote
Old 09-02-2016, 11:06 PM   #86
prj3ctm4yh3m
Drives: CRV AWD 5MT
watch vids on you tube on "rev matching" and "heel and toe" - the idea when downshifting is to make a clean transition into engaging the clutch (i.e. releasing the pedal) to avoid wearing the clutch and worse, "shocking" the drivetrain with too abrupt of an engagement (where the engine is spinning much slower than the wheels/transmission).
prj3ctm4yh3m is offline   Reply With Quote
Old 09-02-2016, 11:16 PM   #87
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Originally Posted by Oxyg3n View Post
I find that the biting point is really high up (towards driver direction) and is really small so its hard to get 1st and 2md without jerking..
Sent from my SAMSUNG-SM-G920A using Tapatalk
No offense, but there is nothing wrong with the clutch in the BRZ. I test drove one a few times and was able to make the shifts perfectly smooth - and you can easily do rev matching in it too.
I always emphasize to new manual drivers that you need to be super slow and smooth when releasing the clutch. You will develop a natural feel for the grab zone and be able to make it smoother than an automatic eventually. If you drop it too quickly, you'll give the drivetrain a whiplash! And just remember, ONLY go into first when stopped or BARELY moving! It is an extremely short gear and can't handle the massive speed variance. I remember when I was teaching my brother to drive a manual, he started shifting down into 1st when we were still going like 25 mph, and I was like WOAH! Keep it in second bro!
So yeah, it's just a matter of practice. You'll eventually be able to release quickly up to the grab zone, then slow down and finesse it as needed until it fully grabs and then let it go completely.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 09-02-2016, 11:19 PM   #88
Oxyg3n
Oxyg3n's Avatar
Drives: 2017 BRZ - WRB
Yea i agree its totally because of my skill level that im jerking right now. However, i think the way the gas pedal feels significantly different in the 2017 compared to the previous generation from my test drives.
Oxyg3n is offline   Reply With Quote
Old 09-02-2016, 11:25 PM   #89
Bristecom
Bristecom's Avatar
Yeah, I saw your video and that does not look normal. Maybe try resetting it by unplugging the battery for a bit. The ECU mapping may have gotten funky. But either way, it might be able to smooth itself out as it learns and breaks in over time. Hopefully it's not actually an engine problem.
Toyota + Subaru =
Old 09-04-2016, 10:25 PM   #90
WWFT86
Drives: 2017 BRZ Limited
Pg. 220 of the manual says - "This chart is intended for reference only and does not show the actual engine torque or output" ...
Originally Posted by BWilky View Post
Wonder if the torque and power curve display would adjust if you made upgrades to the engine?!!?
WWFT86 is offline   Reply With Quote
Old 09-04-2016, 10:32 PM   #91
WWFT86
Hmm i see! But did you also get the message saying turn power off along with the blue coolant indicator?
I figured it out. Page 430 of the manual said "after the push button ignition switch has been turned off with the select lever in a position other than P, the select lever has been shifted to P." Corrective procedure - turn the push button ignition switch off.
Old 09-04-2016, 10:53 PM   #92
funwheeldrive
I've been driving manual since I was 16. The 86 clutch leaves a lot to be desired. It's vague and the pedal sits relatively high at rest.
That's why so many people adjust the pedal height, remove the clutch spring, or replace the cylinder.
Old 09-04-2016, 10:58 PM   #93
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
The BRZ looks better than the 86
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Old 09-05-2016, 01:41 AM   #94
Bristecom
Bristecom's Avatar
How old are you now? 17? LOL JK.
To each their own I guess but I am usually pretty sensitive to things and have felt a lot of bad clutches but with this one, I was able to easily adapt with no problems. I feel like it doesn't take an extreme in any direction (too heavy, too light, too high, or too low) and is a good compromise to satisfy most people. But yeah, at least there is a way to adjust it.
Toyota + Subaru =
Old 09-05-2016, 03:46 AM   #95
surfwaxsmitty
Drives: '14 BRZ 6MT
Honestly, if you want to learn the clutch characteristics.. Go to a parking lot that is flat> from a stop, using only your left foot on the clutch, no additional throttle, begin to manage the engagement point and as you begin moving you can release more on the pedal and engage the drivetrain more.
Rpms start to drop too low, engage more clutch; not moving anywhere, disengage the clutch more. So on and so forth.
In summary, learn to start moving with no added throttle; just idle.
surfwaxsmitty is offline   Reply With Quote
Old 09-05-2016, 09:49 AM   #96
WWFT86
FYI for those will change the alarm to be on by default - the door has to be opened quite a bit for this procedure to work. I started with just a little gap, enough for the car ro recognize door is open, and wondered why it didn't work...
Originally Posted by WWFT86 View Post
Thanks for the tip. Were these the steps you followed?
- close all doors trunk
- push button to on
- open driver side door while holding the door lock button
- hold button for 10 seconds
- 1x horn chirp means alarm is active
2x means it's disabled?
Not sure why they wouldnt default to active. Same with the door handle should default to opening both doors... To me that is what most people want/prefer?
Old 09-05-2016, 09:50 AM   #97
WWFT86
Also FYI the hill start assist is not on by default
Old 09-05-2016, 09:55 AM   #98
funwheeldrive
We'll see how you feel when you actually own one.
BTW, are you buying an MY17 or waiting?
Who's driven an rx8 and frs sci3 FR-S / BRZ vs.... 56 04-29-2015 03:20 PM
Anyone driven a 15 GTI 6MT yet? phobos512 Other Vehicles & General Automotive Discussions 2 12-31-2014 11:49 AM
Driven: FR-S 6MT, 6AT, BRZ 6MT. Michael Blue BRZ First-Gen (2012+) — General Topics 32 05-22-2014 05:20 PM
Anyone Driven an MX-5 and BRZ? Dzeremijs FR-S / BRZ vs.... 95 06-06-2013 07:26 PM
