Old 08-09-2016, 11:18 AM   #925
86Tony
Drives: 2015 AOZORA EDITION
I wouldn't recommend it.
alright i hold off on installin it for now thanks
86Tony is offline   Reply With Quote
Old 08-09-2016, 12:00 PM   #926
Reamer
Drives: 2015 FRS
The OFT and EcuTek through Counterspace Garage and Delicious Tuning has OTS tunes for ACE headers though. I'm currently running OFT with a custom tune with my type B 350 header but when I go flexfuel I'm going to switch over to DT and EcuTek. I don't have personal experience with the OTS tunes yet, but I hear they're solid in the meantime of getting it tuned on a dyno.
Sent from my ONE E1005 using Tapatalk
Reamer is offline   Reply With Quote
Old 08-30-2016, 10:42 AM   #927
Trust86
Drives: 2016 Halo FRS
Moto-East does not have an Ace specific tune that I am aware of. CSG/DT does.
I got a remote tune from Moto east, was planning on getting a dyno tune through them in 3 weeks... would the dyno tune be worth it? Or can CSG do the same if not better remotely? If so how much would it cost for an revised tune through CSG? Moto east is 6+ hours away, that's why I did a remote tune in the first place. My car is not a DD anymore.... Bought it brand new a year ago and already have over 31,000 miles lol
Trust86 is offline   Reply With Quote
Old 08-30-2016, 01:06 PM   #928
CSG David
CSG David's Avatar
Dyno tested and refined through many cycles of testing in real world application. We've been supporting clients overseas in racing series with these tunes and they are winning.
The Following 2 Users Say Thank You to CSG David For This Useful Post:
Jonsey (09-02-2016), Trust86 (08-30-2016)
Old 08-30-2016, 01:10 PM   #929
Trust86
PM sent!
Old 08-31-2016, 03:56 PM   #930
CSG David
CSG David's Avatar
PM sent!
Replied! Thanks for your support!
The Following User Says Thank You to CSG David For This Useful Post:
Trust86 (09-02-2016)
Old 09-02-2016, 12:22 PM   #931
X Factor
Drives: 2013 Red BRZ Limited
Any thoughts/experience on the 350 with OEM front pipe, midpipe & nameless axleback.
X Factor is offline   Reply With Quote
Old 09-02-2016, 12:51 PM   #932
-Phil
Drives: Rb25 neo brz
Why don't we do both and find out . Without being biased its obvious we will make more power with your car here on the dyno than a remote tune.
-Phil is offline   Reply With Quote
The Following 2 Users Say Thank You to -Phil For This Useful Post:
Jonsey (09-02-2016), Trust86 (09-02-2016)
Old 09-04-2016, 04:28 PM   #933
will300
will300's Avatar
Drives: Subaru BRZ SE Lux
I've just had an ACE CS400 fitted to my car, here is the dyno graph. Showing the car before and after.
Green is stock with panel filter
Purple is ACE CS400, AVO 2.5" Cat back and panel filter
will300 is offline   Reply With Quote
Old 09-04-2016, 05:57 PM   #934
ohmai18
ohmai18's Avatar
Drives: Subaru BRZ
Why is there a second torque dip before 3k?
Sent from my SAMSUNG-SM-G900A using Tapatalk
ohmai18 is offline   Reply With Quote
Old 09-04-2016, 07:14 PM   #935
Lantana frs
Drives: 13 frs red
Peak difference on graph doesn't show 32 hp. Is that pre and post tune?
Lantana frs is offline   Reply With Quote
Old 09-04-2016, 11:26 PM   #936
xwd
I think the lower numbers on the graph are labeled HP but is supposed to be torque. In the end the peak HP/TQ is the same but the curve is obviously very different.
The spike in the beginning could be a dyno anomaly.
Old 09-05-2016, 12:42 AM   #937
ysu
Drives: Toyota 86 GTS Auto
Sorry, that graph does not make sense to me.
If green is before, why is there a 164 & a 197 HP written in green a the top?
And why both green & purple lines show a 197 HP max?
Toyota 86 GTS A/T, ACE 250/B header + OP, Apexi air filter, Whiteline camber bolts
ysu is offline   Reply With Quote
Old 09-05-2016, 02:05 AM   #938
DeaconRoc
Drives: GT86
Green is before 164hp at the wheels, 197hp at the fly. Both green and purple show a 197hp max as the after figure was no higher than the before but the after has a lot more area under the curve for power and torque apart from at the start which, as stated earlier, is probably a dyno anomaly.
DeaconRoc is offline   Reply With Quote
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 10:34 PM
