Old 08-27-2016, 02:35 PM   #15
Kris86
Kris86's Avatar
Drives: RHD Gt86
I'd love to see more videos of this kit!
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
Old 08-28-2016, 07:01 AM   #16
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
You're tag should be "I'd love to see more videos of this" haha
But I agree
COO86L is offline   Reply With Quote
The Following User Says Thank You to COO86L For This Useful Post:
Kris86 (09-02-2016)
Old 09-01-2016, 06:28 PM   #17
Cuztomizer
Drives: ZN6
I'm running t620z for 3k miles on stock motor, tuner has limited the boost to 10 psi through grimspeed EBCS, it perform well on mid range rpms but acceleration is not that much responsive on high rpms, anyone know how to fix this issue?
Cuztomizer is offline   Reply With Quote
The Following User Says Thank You to Cuztomizer For This Useful Post:
Kris86 (09-02-2016)
Old 09-01-2016, 09:24 PM   #18
TRACE_on
TRACE_on's Avatar
Drives: 2023 GR86 - Track BRed Premium 6M
Just posted my setup in the dyno thread: http://www.ft86club.com/forums/showp...&postcount=129
Loving the kit so far, will probably go E85 next year.
STR also-ran
TRACE_on is offline   Reply With Quote
The Following User Says Thank You to TRACE_on For This Useful Post:
Kris86 (09-02-2016)
Old 09-02-2016, 05:24 PM   #19
Cuztomizer
Drives: ZN6
Do you have any video of test run? And how it feel on high end rpms?
Old 09-02-2016, 05:37 PM   #20
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
I should be able to show you a few test runs on e85 once I get motoeast's flexfuel installed.
Just broke the 10k miles boosted. Runs great. If I remember correctly, My dyno was at around 287 with 10 lbs of boost. Stock internals with a catless invidia n1 set up.
Soloside is offline   Reply With Quote
Old 09-03-2016, 11:47 AM   #21
TRACE_on
TRACE_on's Avatar
Here is the video Dynosty made:
https://www.facebook.com/Dynosty/vid...0060979342634/
The car pulls hard all the way to redline. That is probably the difference between the T518 and T620 kits; the T518 gets into boost sooner but the T620 kit has a bigger turbo so it gives a big kick once the RPMs are up. I have 255's in the rear and they can break loose at high RPMs in 1st and 2nd gear. Will likely go to 265's next year, especially before getting an E85 tune.
STR also-ran
Old 09-03-2016, 08:36 PM   #22
Cuztomizer
Drives: ZN6
Your ride making good numbers👍🏼. Its right now on 93 octane?
The issue on my side is its goes awesome on 1st and 2nd gear till readline, but it feel slushing and laggy on higher gear on high rpms, as you said once boost come it should give big kick but its not happening on my ride, its feel amazing on 4000-5000rpms, after that its not that much responsive as it should be
Old 09-03-2016, 08:39 PM   #23
Cuztomizer
Drives: ZN6
You got your ride tuned from motoeast? And you got 287 whp on 93 ?
Old 09-04-2016, 09:54 AM   #24
TRACE_on
TRACE_on's Avatar
Yep, using 93 octane.
I am still getting used to the car but I'd say it pulls hard in 3rd and 4th gear when nearing redline.
STR also-ran
Old 09-06-2016, 09:45 AM   #25
Soloside
I had everything done there. I got the turbo kit from them and the install and tune as well.
Mine would be a bit higher, but of course it's an AT. So I'm missing out a little bit of power.
Old 09-06-2016, 09:46 AM   #26
Soloside
mine starts the pull at around 4000-5000 in third. It feels REALLY nice.
Old 09-06-2016, 11:09 AM   #27
TRACE_on
TRACE_on's Avatar
My previous ride was a 2008 Evo X 5MT with a turboback exhaust and off-the-shelf "Stage 2" tune. The car ran 12.8 @108 with a 2.0 60ft.
I'd say the FR-S pulls a bit harder than the Evo. Assuming I can put the power on the ground I'm thinking a 12-second pass is possible. I hope to find out at the track in a month or two.
STR also-ran
Old 09-06-2016, 04:07 PM   #28
Kris86
Kris86's Avatar
Drives: RHD Gt86
VIDEOS!!
Greddy Base Map for FRS Greddy Turbo Kit hiranak Software Tuning 10 10-27-2014 06:55 AM
*** [DECIDED] GReddy *** Full Blown vs GReddy slisgrinder Forced Induction 31 08-13-2014 02:24 PM
GReddy T518z+Greddy CS GTS Ver 2. Video + pics (not tuned) NOTORIOUS.BRZ Engine, Exhaust, Transmission 21 09-24-2013 06:09 PM
GReddy in on-deck circle. GReddy turbo for FR-S/BRZ first up. 2JZ-DNA Engine, Exhaust, Transmission 46 04-19-2012 08:13 PM
