#463 |
Drives: Whiteout FRS
@shellslinger, @Stang70Fastback, @SuperDave, One more question for you guys. What part of warranty was it cover under? 3yr bumper to bumper or 5 yr powertrain?
#464 | |
Drives: DAT Rally Blue BRZ
| The Following User Says Thank You to SuperDave For This Useful Post: | Bach415 (09-05-2016) |
#465 |
Your issue turned out to be exactly what I described. One more time for the tl:dr crowd - lubricant failure plain and simple.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Bach415 (09-05-2016) |
#466 | |
A.K.A. Starlord
Drives: 2015 Series.Blue
| The Following User Says Thank You to Stang70Fastback For This Useful Post: | Bach415 (09-05-2016) |
#467 |
Well everyone, I replaced my clutch to a Exedy stage one clutch. Squeaky clutch never came back after lubing it a month ago but after ordering the stage one clutch, I was like why the heck not. My throwout bearing looked fine and didn't look like it was bad or anything. I didn't get any photos but my new clutch feels exactly like my brother's NC Miata's clutch just a tad bit springier maybe @humfrz might want to do this
#468 | |
![]() humfrz |
#469 |
Drives: Whiteout FR-S
At about 76k. Noticed a squealing noise when I started the car up on Friday morning. Would only make the noise when the clutch is depressed and would go away with about 2 mins of driving. Tried adding some Lucas Red and Tacky under the boot near the clutch fork and it still makes the noise. The noise gets worse if I rev the engine while the clutch is depressed. Looks like the TOB is finally about to go.
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
#470 | |
#471 |
A.K.A. Starlord
How about a whining noise when my foot is OFF the clutch, but goes away when I depress the clutch pedal? Input shaft bearing?
#472 | |
I knew better but was in the moment. :/
#473 |
A.K.A. Starlord
Whining, whirring noise. Not a screech. I'm talking about a sound that occurs when the car is stationary or moving. The whine increases with RPMs, then resets when you change gears. It definitely seems input shaft related.
#474 |
Yeah, same same. Volume of the whine increases with torque. It could be a bearing on either the input or mid shaft. It could also be due to some axial misalignment. My spare even complains when I upshift. I can hear the rapid decrease of the input side as the syncro pulls it down.
#475 |
A.K.A. Starlord
Exactly. Same here. I guess it's "normal" then. I have no problem with hearing those noises (I know there isn't much sound deadening) but it's just something I swear I only started hearing recently.
#476 |
It's not normal but if you're just cruising along, it won't suddenly grenade. It may take many tens of thousands of miles to get worse.
| Loud 'Squeak' Noise From Clutch? | Brndn704 | Issues | Warranty | Recalls / TSB | 23 | 07-20-2020 08:58 AM |
| Upgraded Clutch Squeak | Rybot | Issues | Warranty | Recalls / TSB | 116 | 10-09-2019 02:10 PM |
| Clutch pedal adjustment gone wrong? Clutch issues. | PulpBrah | Engine, Exhaust, Transmission | 12 | 03-06-2017 04:08 PM |
| Clutch Squeak | CatDaddysBBQ | Issues | Warranty | Recalls / TSB | 4 | 07-14-2015 06:44 AM |
| Clutch pedal squeak. | merino_frs | Engine, Exhaust, Transmission | 1 | 08-25-2014 01:00 AM |
