Pat.Thornton
Old 09-03-2016, 01:39 PM   #463
Bach415
Bach415's Avatar
Drives: Whiteout FRS
@shellslinger, @Stang70Fastback, @SuperDave, One more question for you guys. What part of warranty was it cover under? 3yr bumper to bumper or 5 yr powertrain?
Bach415 is offline   Reply With Quote
Old 09-03-2016, 02:04 PM   #464
SuperDave
SuperDave's Avatar
Drives: DAT Rally Blue BRZ
Powertrain
SuperDave is offline   Reply With Quote
The Following User Says Thank You to SuperDave For This Useful Post:
Bach415 (09-05-2016)
Old 09-03-2016, 02:15 PM   #465
Originally Posted by SuperDave View Post
mine happened all the time, and my throwout bearing looked "perfect" according to my advisor and the clutch was good to go, but they replaced it anyhow.
Your issue turned out to be exactly what I described. One more time for the tl:dr crowd - lubricant failure plain and simple.
Old 09-03-2016, 02:35 PM   #466
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Mine was still under 36k, so I was covered under the bumper to bumper warranty. The actual clutch is a wear item, and is only covered up to 36k; it isn't covered under the powertrain warranty. Perhaps the TOB and other parts are different, but the clutch disk itself isn't covered past 36k.
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Old 09-12-2016, 08:25 PM   #467
shellslinger
Well everyone, I replaced my clutch to a Exedy stage one clutch. Squeaky clutch never came back after lubing it a month ago but after ordering the stage one clutch, I was like why the heck not. My throwout bearing looked fine and didn't look like it was bad or anything. I didn't get any photos but my new clutch feels exactly like my brother's NC Miata's clutch just a tad bit springier maybe @humfrz might want to do this
shellslinger is offline   Reply With Quote
Old 09-12-2016, 08:53 PM   #468
Well, shellslinger, thanks for thinking of me ...... but, these days, if my clutch got any springier, I'd have to trade it in for an auto ......
Old 09-17-2016, 07:38 PM   #469
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
At about 76k. Noticed a squealing noise when I started the car up on Friday morning. Would only make the noise when the clutch is depressed and would go away with about 2 mins of driving. Tried adding some Lucas Red and Tacky under the boot near the clutch fork and it still makes the noise. The noise gets worse if I rev the engine while the clutch is depressed. Looks like the TOB is finally about to go.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 09-17-2016, 08:33 PM   #470
That's the TOB seizing up. If it takes as long as 2 minutes to let go it has probably already damaged the PP fingers.
Old 09-17-2016, 10:13 PM   #471
Stang70Fastback
A.K.A. Starlord
How about a whining noise when my foot is OFF the clutch, but goes away when I depress the clutch pedal? Input shaft bearing?
Old 09-17-2016, 10:43 PM   #472
Whining, or screeching? My backup transmission whines twice as badly as my original which I removed to rebuild. It started making a little noise after I gave it a good whack.
I knew better but was in the moment. :/
Old 09-17-2016, 11:14 PM   #473
Stang70Fastback
A.K.A. Starlord
Whining, whirring noise. Not a screech. I'm talking about a sound that occurs when the car is stationary or moving. The whine increases with RPMs, then resets when you change gears. It definitely seems input shaft related.
Old 09-17-2016, 11:28 PM   #474
Yeah, same same. Volume of the whine increases with torque. It could be a bearing on either the input or mid shaft. It could also be due to some axial misalignment. My spare even complains when I upshift. I can hear the rapid decrease of the input side as the syncro pulls it down.
Old 09-18-2016, 12:01 AM   #475
Stang70Fastback
A.K.A. Starlord
Exactly. Same here. I guess it's "normal" then. I have no problem with hearing those noises (I know there isn't much sound deadening) but it's just something I swear I only started hearing recently.
Old 09-18-2016, 12:11 AM   #476
It's not normal but if you're just cruising along, it won't suddenly grenade. It may take many tens of thousands of miles to get worse.
Loud 'Squeak' Noise From Clutch? Brndn704 Issues | Warranty | Recalls / TSB 23 07-20-2020 08:58 AM
Upgraded Clutch Squeak Rybot Issues | Warranty | Recalls / TSB 116 10-09-2019 02:10 PM
Clutch pedal adjustment gone wrong? Clutch issues. PulpBrah Engine, Exhaust, Transmission 12 03-06-2017 04:08 PM
Clutch Squeak CatDaddysBBQ Issues | Warranty | Recalls / TSB 4 07-14-2015 06:44 AM
Clutch pedal squeak. merino_frs Engine, Exhaust, Transmission 1 08-25-2014 01:00 AM
