Old 08-31-2016, 07:50 PM   #15
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
You guys all talking about rev matching for first gear need to learn the distinction between double clutching and rev matching.
Rev matching doesn't do shit for a rolling first-gear downshift.
I have LITERALLY no idea what you're on about. I rev match into 1st and it works fine. I don't have to double clutch at all...
Here, I even made a video for you where I simply rev-match into 1st at 15 and 20 MPH smoothly and without any drama.
[ame]http://youtu.be/vcxhxA5RtGw[/ame]
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Swagopopotamus (08-31-2016)
Old 08-31-2016, 08:22 PM   #16
Swagopopotamus
Swagopopotamus's Avatar
Drives: Not an FRS, but same initials.
I don't get it either. I've never had a problem dropping to first at the proper revs either. I think there's a couple people in this thread who aren't sure how a clutch works. It's not like it engages more on the second pump.
Swagopopotamus is offline   Reply With Quote
The Following User Says Thank You to Swagopopotamus For This Useful Post:
Stang70Fastback (08-31-2016)
Old 08-31-2016, 08:24 PM   #17
I am with you. I have never once double clutched this car for any gear. Never found a need to.
Dom would scold me I am sure!
Old 08-31-2016, 08:34 PM   #18
There is nothing wrong with double clutching and some may prefer it I just never found a need. Now my old Talon TSI was a different creature completely. Double clutched so much my left leg was huge!
Old 08-31-2016, 08:41 PM   #19
Swagopopotamus
I only double clutch when the music is just right and I want to get my Fred Astaire on.
Tcoat (08-31-2016)
Old 08-31-2016, 08:43 PM   #20
In the sequence of events of your downshift, when do you blip the throttle?
If your clutch is disengaged and you blip the throttle while you're in neutral, it does nothing to help you get into gear. If you've already downshifted into first and you blip the throttle before you engage the clutch, sure, that's a legitimate rev match.
I cannot shift mine into first above maybe 7 MPH without double clutching. I've driven some friends' cars which are very easy to downshift into first. There is quite a bit of variation in the first gear limit. I have a theory that some units were assembled without the limit ball but it's probably bullshit.
Old 08-31-2016, 08:44 PM   #21
Swagopopotamus (08-31-2016), Ultramaroon (08-31-2016)
Old 08-31-2016, 08:53 PM   #22
Stang70Fastback
A.K.A. Starlord
Sequence of events:
Push clutch in.
Blip throttle while moving shifter from 2nd to 1st.
Release clutch.
I am not double clutching. The clutch gets pressed exactly once. Maybe your car is borked, lol.
Old 08-31-2016, 09:05 PM   #23
Sequence of events:
Push clutch in.
Release clutch.
It is an engineered feature which prevents shifting into first if the speed difference between the input and output sides is not close enough.
Old 08-31-2016, 09:11 PM   #24
Or ours are!
I have participated with Ultra in many of these hard shift threads and I have never experienced any of the things people talk about. No gear lock outs, no hard shift to second when cold, down shift easily to first and not a single grind (that wasn't self imposed that is). As much as I would love to attribute all this to my highly skilled, above average , stupendous, ultimate highway warrior driving skills I just don't believe that (I tried to take off in third today and boy does clutch smell bad when heated). What I do believe is that there is a huge range of quality in these transmissions with some at a much better build level than others. I have never really paid much attention to the year of the cars where people had the most complaints but would not be at all surprised to find they are mostly 13s and early 14s.
Old 08-31-2016, 09:11 PM   #25
Stang70Fastback
A.K.A. Starlord
Okay. Sooooo if you rev match properly, you will minimize the speed differential...
What am I missing here? Double clutching serves to bring your transmission input shaft up to the speed of your engine, but synchros do that for you in modern transmissions. Blip the throttle so that the engine speed matches the speed you are traveling in relation to first and the shifter will eagerly snap into 1st gear.
Old 08-31-2016, 09:13 PM   #26
Stang70Fastback
A.K.A. Starlord
That's an interesting theory. What years are yours? Mines a 2015.
EDIT: Just realized our profile info to the left states this information, lol.
The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post:
Tcoat (08-31-2016), Ultramaroon (08-31-2016)
Old 08-31-2016, 09:18 PM   #27
More of a hypothesis than an actual theory and based purely upon anecdotal evidence so should be taken with a grain of salt.
Old 08-31-2016, 09:35 PM   #28
Your first statement is incorrect. Revving the engine does nothing if the clutch is disengaged. That's my whole point.
The first gear limit ball reacts against the first gear synchro and keeps it from making contact. It's there not only to keep you from killing yourself but also to keep you from killing the synchro.
I've looked at the exploded view. I can't really make sense of exactly how it works but it's real.
Help! Oil filter isn't coming off smoothly ShoGun Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 40 11-26-2015 08:58 AM
How to Smoothly and Quickly Up-shift from 1st to 2nd Gear? DemonRawr BRZ First-Gen (2012+) — General Topics 20 10-20-2014 04:51 PM
brake pedal doesn't return smoothly chenshuo Issues | Warranty | Recalls / TSB 6 08-14-2013 06:06 PM
(6MT) Getting into 2nd smoothly l0aded Scion FR-S / Toyota 86 GT86 General Forum 16 04-19-2013 05:10 PM
shifting and down shifting feel Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2012 05:09 PM
