Old 08-30-2016, 02:55 PM   #57
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
By request, Fujitsubo has updated this front pipe to include a wideband O2 sensor bung.
New part number 110-23127
Mr.Impreza (08-30-2016)
Old 08-31-2016, 02:06 AM   #58
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm. O2 bung pre-cat? What for? If it were after 2nd cat, then it might work as O2 spacer reducing CEL chances, but why weld bung before it?
Old 08-31-2016, 02:44 AM   #59
mav1178
mav1178's Avatar
there's no cat on this front pipe.
double resonator. Plus, this is meant more for wideband tuning than anything else. Without some type of O2 extension cable, you can't get any of the factory sensors this far back anyhow.
Old 08-31-2016, 03:46 AM   #60
churchx
churchx's Avatar
Drives: 2014 GT86
I just recall (IIRC) Apexi cylinder back exhaust with catless header + o2 extention cable + bung after 2ndary cat in frontpipe, hence thought if bung addition on this was intended for similar reasons.
Old 08-31-2016, 03:03 PM   #61
mav1178
mav1178's Avatar
Apex'i header system is meant to replace entire OEM header/OP/front pipe setup, and have a functional catalytic converter for street use in Japan.
Their O2 is before the primary cat, which is now located in the secondary cat location on the front pipe.
The Fujitsubo front pipe is just straight through design with resonators. I had suggested to them that adding wideband O2 bung would make the front pipe a better investment for buyers, since not all headers on the market have wideband O2 sensor bung.
-alex
Old 10-02-2016, 07:10 PM   #62
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
@mav1178 - where can I buy the Fujitsubo front pipe?
TofuJoe is offline   Reply With Quote
Old 10-02-2016, 08:55 PM   #63
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
http://www.frsport.com/Fujitsubo-110...p_1213521.html
or
contact info@cuscousainc.com for further details or to find a retailer.
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 10-02-2016, 09:23 PM   #64
TofuJoe
Ohne Titel
TofuJoe's Avatar
@Mr.Impreza - not in stock at FR Sport. I'll email Cusco, but it sure seems like a hassle to get one of these. Hopefully worth it.
Old 03-30-2017, 03:02 AM   #65
reeves
-alex
Could you also suggest to them to make the bolt holes A LOT bigger on the flange connecting to the mid-pipe (spring bolts). They are ridiculously SMALL!! Can't even fit a 14mm bolt through there. I think the OEM nut/bolt on that flange was 17 or 19mm.
Yes you can drill a bigger hole there yourself.. but for a "high end" brand, this is an unacceptable oversight.
Old 03-30-2017, 02:28 PM   #66
mav1178
mav1178's Avatar
This front pipe is designed with OEM spring bolt in mind. I don't think this is an oversight at all.
The OEM spring bolt is 14mm on the midpipe side and 12mm on the front pipe side.
-alex
Old 03-30-2017, 05:01 PM   #67
reeves
-alex
You're absolutely right, found my old stock front pipe today just to compare. Guess I've been using the bigger aftermarket bolts & nuts for too many years now.
The pipe is 'stock-quiet', as advertised! I noticed a welcomed change in the tone of my exhaust too. But without the noise!
Old 07-06-2017, 12:19 PM   #68
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
-alex
My mid pipe flange was too thick to use with the stock hardware. If anyone else runs into this problem with the front pipe head to advanced auto and buy part #03143, that should fit.
Trueweltall is offline   Reply With Quote
Old 06-17-2018, 11:23 AM   #69
gpvecchi
gpvecchi's Avatar
I may have found the perfect setup...
Tomei UEL + Fujitsubo front pipe + Blitz VSR exhaust.
Absurdly quiet! And no cats if you aren't into cats.
-alex
Do you have a video, please?
Old 06-17-2018, 10:22 PM   #70
mav1178
mav1178's Avatar
Static:
[ame]https://www.youtube.com/watch?v=58YOMheNM_0[/ame]
Driving:
[ame]https://www.youtube.com/watch?v=jDf0bUg-bpQ[/ame]
gpvecchi (06-18-2018)
Once in a lifetime shot mrha BRZ Photos, Videos, Wallpapers, Gallery Forum 25 10-27-2012 05:53 AM
One iPhone shot BlaineWasHere FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 08-09-2012 01:44 AM
ING's FR-S Spy shot! vividracing FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 44 06-30-2012 02:51 PM
I had a shot at an fr-s today mauricio Scion FR-S / Toyota 86 GT86 General Forum 31 05-27-2012 01:09 AM
worth a shot pkptd447 Off-Topic Lounge [WARNING: NO POLITICS] 1 12-23-2011 05:01 PM
