Old 10-28-2015, 01:42 PM   #281
rx3
I've meanwhile contacted our local KW office (KW is the only coil-over company which actually does have an office here) and asked them for an offer regarding the KW competition coil overs (they cost about the same as the clupsports but are just not supposed to be daily-driven since they provide less dirt protection).
(I have to buy from them, otherwise I won't get the paper work required to get this 'road-legalized').
They need to know following:
* Application (track, rally, hillclimb..)
* Tires (road/slick/intermediate and dimensions)
* Weight (front axle and rear axle)
* Lowering (Height from wheel center to fender)
* Camber
* Toe
(I guess they'll figure out the specifics regarding spring rate and damping parameters based on that information.)
I think regarding camber I would have -3 in the front and -2 in the rear and I would have neutral toe in the rear and toe out in the front (not sure how much).
I'm not sure by how much the ride height should be reduced -30mm? Any suggestions?
rx3 is offline   Reply With Quote
Old 01-14-2016, 12:36 AM   #282
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Swifr Spec R
BRZ ZC6 13+ 4T909R
Front: 4.4 kg/mm 245 lb/in drop: -28mm 1.1 in
Rear: 5.3 kg/mm 296 lb/in drop: -25mm 1.0 in
@WingsofWar
Hyper4mance2k is offline   Reply With Quote
Old 08-29-2016, 07:07 PM   #283
Adam_L
Adam_L's Avatar
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
Originally Posted by churchx View Post
Different people have different driving habbits/patterns. Different coilover manufacturers target different niches. There is no 'best' spring rate that will fit best everyone. For some best is 3K, for some 6K, for some - 12K. Some use toyobaru as track-only car, some daily drive it only + have to listen opinion of comfort of significant other, some mix DD & few track days. To each his own, and what is best and who are those 'some' with opinions depends on threads you visit for info .
Totally.
I love how my stock FR-S suspension acts/ reacts to my inputs / road inputs, however at some point I'd like to go with at least a 1" drop (quality springs/struts= about $800 , or possibly coil-overs = going to be $1300+). I doubt I could get a quality coil-over (rebuild-able and good compression settings, and a fair amount of drop settings), for under $1000
So which aftermarket set up best resembles how our cars come from the factory (understood it's not going to be exact) ?
Adam_L is offline   Reply With Quote
Old 08-29-2016, 07:19 PM   #284
funwheeldrive
Originally Posted by Adam_L View Post
Totally.
I never come in this thread, but doesn't lowering the car more than an inch greatly increase the odds of axle failure?
Why not just get TRD lowering springs for the OEM fit and finish?
Old 09-01-2016, 04:26 PM   #285
Adam_L
Adam_L's Avatar
Exclamation
Good question, looks like you stumped everyone here on that question
Old 09-20-2016, 04:32 PM   #286
subaruMike
Drives: 14BRZ(sold)15WRX-STi(sold)->17BRZ
anybody using the road & track Φhlins set up? What are your impressions verse stock? How much lower is the car afterwards?
subaruMike is offline   Reply With Quote
Old 09-23-2016, 05:51 PM   #287
jcygts6
jcygts6's Avatar
Drives: 13 SWP BRZ
I am running the swift Srpings (FRS Version) on OEM Shocks on my 2013 BRZ and they ride and handle great! Smoother than stock with a more aggressive 1" drop.
jcygts6 is offline   Reply With Quote
Old 09-23-2016, 05:58 PM   #288
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Not really. I believe thats when you are getting closer to 2" drop and also on sticky tires and launching.
After 1" you start to lose suspension travel and can end up with a worse ride if your talking springs on stock struts.
Old 10-26-2016, 01:32 PM   #289
neilvosko
neilvosko's Avatar
Drives: Hyper Blue BRZ
based on this info, for DD
seems like placing
the OEM Toyota 86 0.0"/2.3k 0.0"/3.3k
on BRZ rear is best to make it more neutral (balance the rates between front and rear)
thoughts ?
neilvosko is offline   Reply With Quote
Old 10-26-2016, 03:05 PM   #290
Racecomp Engineering
seems like placing
thoughts ?
I would expect a little more understeer if you put those rear springs on with BRZ fronts. But a lot of the cornering balance at the limit with these cars when you're using OEM and lower spring rates is decided by the bumpstops anyway.
- Andrew
Sideways? (10-26-2016)
Old 10-26-2016, 04:36 PM   #291
neilvosko
neilvosko's Avatar
Thanks, i like what you did in having a higher rate in front.
coming from a corvette, in racing, with a heavier engine in the front, some shops recommended a higher spring rate in front. i understand its a different car and other suspension geometry, but similar principal.
The Following User Says Thank You to neilvosko For This Useful Post:
Racecomp Engineering (10-27-2016)
Old 11-04-2016, 09:29 PM   #292
BRZgirl
BRZgirl's Avatar
Drives: Subaru BRZ Silver Limited AT
Hello,
Didn't see Mann Engineering springs and coilovers here so thought I add to your list. Good list!
Lowering springs: https://www.mann-engineering.com/ind...x/detail/id/35
Coilovers: https://www.mann-engineering.com/ind...=&category=174
BRZgirl Subaru BRZ Silver Limited AT
Pages:BRZ & FR-S Girls
Current Builds: Mann Stainless Steel Brake Lines, OEM Audio+, Speedline & Mann Engineering Type-25 Coilovers
Tune by:
Mann That's Delicious Future Builds: Brembo 4-Piston BBK
BRZgirl is offline   Reply With Quote
Old 12-30-2016, 01:56 AM   #293
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
This is a super useful guide, but it hasn't been updated in a really long time... Any chance someone could overhaul it for clarity?
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
Keenercarguy is offline   Reply With Quote
Old 02-14-2017, 12:35 PM   #294
dsc_pat
Drives: Too fast
most of these ots springs are progressive, though nothing about them being progressive or linear have been adressed
dsc_pat is offline   Reply With Quote
brz aftermarket coilovers, brz aftermarket springs, brz coilover, brz coilovers, brz lowering springs, brz springs, brz suspension, fr-s coilover, fr-s coilovers, fr-s lowering springs, fr-s springs, fr-s suspension, frs coilover, frs coilovers, frs lowering springs, frs springs, frs suspension, scion fr-s coilover, scion fr-s coilovers, scion fr-s springs, subaru brz coilovers, subaru brz foru, subaru brz forums, subaru brz springs
Adjustable shocks+ springs vs Coilovers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 06-08-2013 03:59 PM
Canadian FR-S options VS U.S.A's options? Tino Scion FR-S / Toyota 86 GT86 General Forum 15 11-06-2012 10:07 PM
coilovers or springs? koyv90 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 04-01-2012 08:49 PM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 01:11 PM
Subaru BRZ different suspension / springs tuning ahausheer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 12-06-2011 12:52 PM
