Old 08-28-2016, 08:14 PM   #43
Originally Posted by StOpNG0x View Post
Will do.
Are you referencing the damage potentially caused from the obvious noises I am hearing?
Yes. They are two distinct problems. If they say there's only one ask them to explain how it causes one sound where you're in gear with the clutch disengaged at a standstill, and a second slower one that matches the RPM of the drive shaft.
Old 08-29-2016, 07:53 PM   #44
StOpNG0x
StOpNG0x's Avatar
Drives: Firestorm MT FR-S
Had to leave it at Toyota. The lead tech (supposively) sat in my car with me while I test drove it and basically said something isn't right. They took it back there and 45 minutes later came back and said I need to leave it so I have a rental for however long it takes them to fix it.
Will keep you all posted.
Thank you all again.
StOpNG0x is offline   Reply With Quote
The Following 3 Users Say Thank You to StOpNG0x For This Useful Post:
humfrz (08-29-2016), Teseo (08-30-2016), Ultramaroon (08-29-2016)
Old 08-30-2016, 07:28 PM   #45
StOpNG0x
StOpNG0x's Avatar
Small update: Got the car back and everything is back to normal.
They didn't admit they messed up or the exact cause, but the notes say:
"ADJUSTED AND RETOURQUED SHIFTER LINKAGE, BUSHINGS, AND MOUNTING."
Thank you all again for your responses and feedback.
The Following User Says Thank You to StOpNG0x For This Useful Post:
Teseo (08-30-2016)
Old 08-31-2016, 01:25 AM   #46
renfield90
The Stig's German cousin
People are human. I left one of my endlinks only finger tight the other night. Almost an expensive mistake - and not my first time either.
Old 08-31-2016, 02:35 AM   #47
.......... pay attention to what your do-en.
Should I get my HPFP replaced? hmong337 Scion FR-S / Toyota 86 GT86 General Forum 25 04-08-2015 08:52 AM
Had to get one tire replaced, where to put it? malave7567 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-29-2014 07:33 AM
Chirp Gone Nothing Replaced Employee CANADA 6 08-04-2013 01:25 PM
Can this part be replaced? czar07 Cosmetic Modification (Interior/Exterior/Lighting) 17 11-07-2012 02:46 PM
I may have had the first ever manufacturer-replaced FR-S VZ86 Scion FR-S / Toyota 86 GT86 General Forum 12 05-13-2012 01:39 AM
