#589 |
Drives: runs&drives
DELETE THE THREAD
wait what |
#590 |
Drives: 2014 Scion FR-S LS3
Its too late now. The hype is to big. Deleting this thread wont do a thing.
2014 scion FR-LS3 lol
#591 |
Drives: FRS Silver LS1 swapped.
In the process of sending Data logs with MRS equipment to have can-bus intergration.......to be clear.....this information is for a LS1 with an 05 GM E40 ECU.......E40 ECU of another year are quite different and would require seperate logs to decipher.......And yes this is my thread not Vorshlogs......they as many others refuse to fall into the keyboard expert cross examinations of so called experts on the internet who can easily hide behind a moniker.......I dont own a business nor call myself an expert on car builds or can-bus ......but sharing my build so others who would like to learn or avoid mistakes or know the right contacts to do this as well will have the resources.
| The Following 5 Users Say Thank You to cf6mech For This Useful Post: | Aaronimoe (08-28-2016), djjd42 (08-28-2016), Draco_PR23 (08-29-2016), Nickosport (08-29-2016), Zer0 (08-29-2016) |
#592 | |
Drives: 2001 Impreza 2.5 RS
Colin Beck
| The Following User Says Thank You to MRS-Colin For This Useful Post: | cf6mech (08-29-2016) |
#593 |
Flight booked to TX to do final testing and integration into Rick's car.
Colin Beck
| The Following 13 Users Say Thank You to MRS-Colin For This Useful Post: | 8686 (09-13-2016), ATL BRZ (09-14-2016), Calum (09-13-2016), carbonBLUE (09-13-2016), cf6mech (09-13-2016), civicdrivr (09-14-2016), Floggin Tires (09-13-2016), kch (09-13-2016), MaximeT (09-13-2016), Nickosport (09-14-2016), Sportsguy83 (09-14-2016), wooly35 (09-13-2016), Zer0 (09-13-2016) |
#594 |
Drives: 2015 frs
Good to hear more progress is being made. Keep the updates coming.
#595 |
Done a lot of little things to the car......Texas heat is nasty and have been focused on cooling things down.
| The Following User Says Thank You to cf6mech For This Useful Post: | civicdrivr (09-14-2016) |
#596 | |
Drives: ZC6, Junk of ALL sorts
BTW I'm excited for how far you come along, good choices and congratulations on where you're at.
# 1. Always know where your towel is.
ZC6-CBS, is home |
| The Following User Says Thank You to Floggin Tires For This Useful Post: | cf6mech (09-13-2016) |
#597 | |
Drives: 2015 frs
Right now I'm going to manual brakes. I got the dual circuit master cylinder, fabed up a adapter plate, actuator rod ,and changed the pedal ratio. I removed the abs block retaining the electronics that were attached to the block. Just need to fab up the lines to complete brakes. Redoing the wire harness in the engine compartment to get more room and clean it up a bit. Next I want to move to cooling components, and then fuel system. I already removed the spot welds for the old mounts on the Cross member and the tunnel. @#$& I need to start a build thread. |
#598 |
The SquadWhisperer
Lsx swap thread with emblem mods?
Shame.. SHAME!
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion 2017 Bluenose Autosport Club Overall Rallycross Champion Powered by Great North Performance, Jani-King Canada, and OK Tire. |
#599 | |
| The Following User Says Thank You to cf6mech For This Useful Post: | Zer0 (09-13-2016) |
#600 | |
Drives: 2015 frs
Thanks for the heads up on the oil cooler. I have a Setrab oil cooler sitting at the house now. Time to start designing and fabricating brackets i guess. |
#601 |
Drives: 2015 frs
| FS: KW V3 Coilovers w/ Vorshlag Front Camber Plates | Steeze_Its | Brakes, Suspension, Chassis | 7 | 06-27-2014 09:32 PM |
| FS: Vorshlag Front Camber Plates | h4nh | Brakes, Suspension, Chassis | 1 | 03-01-2014 10:49 PM |
| FS: KW V3 w/ Vorshlag camber plates & oem stock suspension (SF bay area) | serial gixxer | Brakes, Suspension, Chassis | 18 | 05-20-2013 08:51 PM |
| WTB: Front Vorshlag Camber Plates | YDNA | Brakes, Suspension, Chassis | 0 | 05-03-2013 05:31 PM |
| Maybe a repost, but have you seen the Vorshlag project car? | Bart1 | BRZ First-Gen (2012+) — General Topics | 3 | 01-07-2013 01:19 PM |
